Question about Samsung SP50L7H 50" HDTV-Ready Television
BLACK SCREEN HAVE SOUND SP50L7HX
SENT TO SAMSUNG RECOMENDED REPAIR CENTRE HAD IT 3 WEEKS RECOMEND REPLACING OPTICAL BLOCK AND NEW DMD BOARD COSTING HUNDREDS OF POUNDS ALSO ASKED IF I WANTED THEM TO PUT TV IN SKIP WHEN I SAID DID NOT WANT THEM TO REPLACE PARTS TOLD THEM TO RETURN TV CAN ANYBODY HELP SAMSUNG VERY UN HELPFULL
  • 3 Answers
same problem, sent to comet homeserve, fobbed off by them.
Major component failure, common fault !
Samsung not interested unless you want to pay even more money for their people to give you the same bad news !
Time samsung held up their hands and admitted this tv has major component issues and should recall it !
Im in exactly the same boat as you.... a £2000 tv sitting in my front room that doesnt work properly because they use short shelf life parts to build !
Posted on Dec 16, 2009
I have a 50" Samsung tv. The tv turns on and the screen comes on, then within 1 minute the screen goes black. I can still hear sound.
Samsung HL-R5087W TV screen goes blank -tv/sound on - Forums ...
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - About a month ago, the at various times the tv screen would go blankeven though the tv ... Try turning off the cable/sat box when the happens. ... In reply to: Samsung SP50L7HX DLP TV linked to Sky HD box - same problem .... on it comesback to normal. however, once it went off again (Black Screen) after only 2-3 minutes. ln-t4069f picture problem lcd warmup - Forums - CNET
Jun 11, 2015
Samsung LCD TV LN-T5265F Black Screen Diagnosis Help ...
Jun 11, 2015
More results from www.cnet.com
TV with Black Blank Screen Repair How to Troubleshoot ...
? 3:16
https://www.youtube.com/watch?v=kFdVi2ejfzA
May 8, 2014 - Uploaded by ShopJimmy.com
TV Repair Help for a TV With a Black No Image on the Screen ...Sign in to add this video to a playlist. ... LCD & LED TV Repair - No Image & Blank Black Screen Flashlight ... Easiest TV repair - How to Fix Power [TV turns off, freezes, or won't ... 1:26.Samsung LED TV Blank Screen & No Backlights Basic ...
Samsung TV screen goes black w/ audio still playing ...
? 1:49
https://www.youtube.com/watch?v=L9cjcsysdW4
Sep 11, 2012 - Uploaded by Roberto Ramos
TV screen begins to flicker then screen turns black while the audio continues to heard. I'm unable to see the TV Menu options when screen turns off. ... After turning the TV OFF then back ON again, the screen will flicker and then ... 1:26. Samsung LEDTV Repair - T-Con Board Replacement - No Picture on ...
Jan 28, 2016 | Samsung Televison & Video
50 inch samsung HLN5065
I would strongly recommend you to go ahead and replace the ballast.That's the only option you are left with.If you fail then there are two options get it repaired by a technician or buy a new one.
Goodluck,
Please don't forget to rate the solution.
Mar 27, 2008 | Samsung HLN5065W 50" Rear Projection...
White and black vertecal lines
There is nothing you can do for it, it HAS to go in for repair. That is, if it is still under warranty. It is NOT a minor issue.
Either the DMD chip or the image processor is failing and that is something that requires assembly replacement, very expensive.
hope this helps a little =] i know you want to do it on the cheap but yeah,
sorry! :)
-had this prob myself- sent it for repair (under warrenty) fixed within 2 weeks.
Try and use your projector for under 3-4 hours per day
Or the connection of the DMD assembly to the main board is failing. And that is something that most people are ill-equipped to deal with. Those connections are extremely tiny and take a very tiny soldering iron and great care. It is very easy to bridge multiple connectors and do more damage.
Nov 21, 2012 | NEC LT 260K Multimedia Projector
Looks like a black thumbprint blocking 1/3 of the screen. No LED's lit on front of TV. Started as black dots, and filled in almost completely. Initial lamp lasted 2 years. The replacement lamp lasted 3...
It looks like DLP chip is failing. It is installed on DMD board that in turn belongs to optical engine. Issue should get progressively worse. If you look at screen up close - you see that "tumbprint" consist of little small dark-gray squares, some of them flickering.
Cheapest solution - to replace DLP chip. instead of replacing whole optical engine.
This repair have to be confirmed (by running test patterns in service mode first) and done by professional.
Repair could cost aroung $400.
During procedure I would recommend to turn ceiling fans and other air blowing devices off. Single little dust speckle landing on the chip surface will ruing all effort and same amount of labor have to be applied yet again just to get rid of it (been there, done it).
Good luck.
Russ.
Apr 06, 2010 | Samsung DLP HL-P5663W 56" TV
I have white dots on the screen of my hsl4266wx/xaa?
If these dots are only seen when the picture is on I would look for the Optical Block to be causing it. Are the dots in the same place each time you turn it on?
Jul 17, 2009 | Samsung HLS4266 TV
I have black spots on my samsung dlp tv
I had the same problem with my Samsung DLP tv a couple of weeks ago. I had to clean the lenses, mirrors and the DMD sensor to fix it, you must remove the rear cover to do this. If the mirrors and lenses were cleaned but the spots were still there, the final thing to do is to clean the sensor chip on the DMD board. It is located under the heat sink behind the small fan in the lower center of the rear of the TV. The DMD board will have to be removed to get to the back of the sensor. All you have to do is blow some dry canned air across it to remove the dust, do not wipe it with anything. The repair is somewhat complicated and you will probably have to realign the picture by adjusting the position of the DMD board when finished.
Jul 16, 2009 | Samsung HLP4663W 46" Rear Projection HDTV
Turns on but eventually freezes in black and white
is better if u replace the optical block cost less money , also it come with new lamp and color wheel and new ballast , all this parts go bad after couple years
May 06, 2009 | Televison & Video
Samsung SP50L7H 50" HDTV-Ready Television Logo
394 people viewed this question
Jerry Greenberg
Jerry Greenberg
