Question about Electrolux EL7020A Oxygen 3 Ultra Canister Vacuum Cleaner Bagged Vacuum
What size torx driver for electrolux oxygen - Electrolux EL7020A Oxygen 3 Ultra Canister Vacuum Cleaner Bagged Vacuum
Electrolux Oxygen Ultra Vacuum Cleaner: What size torx driver is needed to open case?
If you treat yourself to a small set of torx drivers you wouldn't need to ask. Common size drivers for such work is numbers 10, 15, 20, 25 and sometimes 27.
It is worth mentioning lots of small appliances use a single anti-tamper fixing that is different to the other fixings.Tri-wing, like a phillips head but with three rather than four points, is a fairly common type but there are about half a dozen different types, some of which are available in two or three different sizes.
It is advisable those who take appliances apart own a selection of such tools.
May 06, 2017 | Electrolux Vacuums
What exactly is the name of the tool to remove the one screw on the handle of the Electrolux Renaissance C134A vacuum?
It's not a particular tool, it's simply a type of screwdriver bit. They are called either "Torx" or T-Star and come in a range of sizes, e.g. T15, T20, T25, T30, etc.
I think the one on your vacuum is a T20, but it's hard to remember the size of every screw on every appliance. I've attached a picture below to assist you. If this isn't the right tool, please describe the shape of the recess in the head of the screw and I will post back with the correct answer.
Regards,
BElectric
Nov 11, 2010 | Electrolux Vacuums
I'm looking for an electrolux oxygen repair manual
i have 2, 1powers up and all 3 lights flash change hoses from the good one that work fine and it still wont run and the three blue lights continue to flash and wont run
Aug 08, 2010 | Electrolux EL7020A Oxygen 3 Ultra Canister...
9 month old electrolux oxygen vacuum just quit
my electrolux oxygen canister just quit- i think it's the sumo board and the whole fuse problem why does this keep happening over and over (my 4th time w/ this model) and where can I buy a replacement sumo board myself?
Jun 19, 2009 | Electrolux EL7020A Oxygen 3 Ultra Canister...
Auto rewind for the electrolux oxygen 3 ultra
HI
If this isnt working correctly, take it back. It wont get better
Feb 20, 2009 | Electrolux EL7020A Oxygen 3 Ultra Canister...
Need source for Electrolux Oxygen parts!
Some parts can be found here: http://www.vacuums24x7.com/elox3ulcocav.html
Unfortunately they don't have the part I need.
Jul 15, 2008 | Electrolux EL7020A Oxygen 3 Ultra Canister...
Oxygen 3 will not turn on
This is often caused by a failure of a fuse on the Sumo board, or occasionally by a failure of the cord reel. I just posted a rather extensive set of instructions on how to check these things as a response to a different thread, but I will repost them here:
There is a board in the back (called the "SUMO board") which has a fuse hardwired to it. Most of the "no go" problems with this machine are related to this.
In order to check it, you'll want to take a thin flat-head screwdriver, and gently pry up the silver panel on the top of the machine. The easiest place to do this is on the side of the panel, as far toward the rear of the machine as possible.
You will then need to remove the 2 Torx screws on the rear panel, and the top body of the machine should then be able to be removed. There are two clips in the bag chamber, directly under the back portion of the bag compartment lid, which can be pressed in to facilitate removal of the back cover.
The sumo board will be sitting directly on the top of the machine, and the fuse in question will be on the right if you are looking at it from the rear of the machine. Unfortunately, if the fuse is blown, you will have to replace the entire circuit board. (Unless you feel very comfortable with soldering a new fuse onto it, which I do not recommend for safety reasons.)
You can also check continuity of the cord reel from here. On the right hand side of the board are two spade terminals leading to wires running down into the cord reel assembly. One black, one white. Checking the continuity between these terminals and the ends of the power supply cord will allow you to determine if the cord reel is providing power to the machine.
Accessing the cord reel will require you to remove the six Torx screws holding the main body to the base. Two of these are on the rear of the machine, and are very deep inside; so you will require a very long-shanked Torx driver to get at these. Two more are inside the bag chamber at the rear, and the other two are on the front handle assembly. This will allow you to lift the main body away from the base, and if you are replacing the cord reel you can pull the wires from the spade terminals and the socket on the sumo board, and feed them back down into the cord reel chamber to remove the old cord reel.
Reassembly is simply a reverse of the previous. Beware, however: getting the cord reel to align is something of a chore, so make sure that you have the retraction system functioning before you put the whole thing back together, or you'll be bummed when you finish reassembly and the cord won't retract.
(I've definitely never done that. Nope. Never.)
Hope that helps, good luck.
-R
Dec 31, 2007 | Electrolux EL7020A Oxygen 3 Ultra Canister...
Electrolux EL7020A Oxygen 3 Ultra Canister Vacuum Cleaner Bagged Vacuum Logo
Top Electrolux Vacuums Experts
Mack Baxter
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
