Question about GE Profile 36" Electric Induction Cooktop - Black
Why does GE Profile model PHP960SMSS makes a noise when pan is placed on burner?
GE Profile
3 Suggested Answers
  • 221 Answers
SOURCE: Have a four burner gas GE Profile cooktop. How do
The igniter module is working fine. One of the switches (which are on each valve shaft) is stuck or shorted out. Pull a wire off each one at a time to determine which one is bad. Careful! 120 volts to each wire. Also, this can happen after you spill water into the valve area, if that sounds right, let it dry out.
Posted on Jan 30, 2010
intower18
  • 957 Answers
SOURCE: My GE Profile Stovetop keeps
The burners on an LP (liquid propane) gas range should produce blue flames with yellowish tips during normal operation. If there is more yellow than blue in the burner flame, or if the burner makes hissing and sputtering noises, the air-to-gas mixture may need adjustment. The range burners are each equipped with an air shutter that can be adjusted to improve the fuel efficiency of the appliance. Adjusting the air shutter with a screwdriver takes only a few minutes.
1. Turn off all burners and wait for the range to cool.
2. Lift off the grate from each burner and set aside. 3. Pull up on the range cooktop and raise toward the back of the appliance. Many ranges have a steel support rod to hold the cooktop in the upright position. Lift the rod and insert the tip in the hole on the underside of the cooktop. 4. Turn the setscrew in the air shutter next to the burner counterclockwise to loosen the shutter. The air shutter is built into a metal tub that feeds LP gas to the burner. 5. Push in and turn the control knob to light the burner you are adjusting. If the flames are excessively yellow, slide the shutter wider until only the tip of the flame is yellow and tighten the setscrew. Narrow the shutter to stop hissing sounds and sputtering flames, then tighten the setscrew. 6. Lower the cooktop and replace the burner grates on the range.
You might want to visit the link HERE it is helpful, and as well for your future reference.
Click HERE as well.
I hope the links and steps are helpful and will work for you.
Posted on Aug 03, 2011
Hot surface light stays on on GE Profile Cooktop model JP989 and On does not light for left burners. This is only happening on left burners. Left front burner goes to high with any setting on the switch...
You could have a shorted burner, if it is not then you may have gotten a bad part.
always unplug electricity before attempting to repair on any electrical appliance
Aug 17, 2017 | GE 30 in. Profile JP989 Electric Cooktop
GE profile JP939 flashing F152, how do I fix?
F152 means the right front burner has failed, the sensor in it is bad, the burner will need to be replaced. If you go to the following web page, and pick out your exact model number, you will see diagrams and parts lists that will help you get this fixed. You can order the element from that website, if you choose: http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=JP969 Good luck, and hope this helps.
Nov 28, 2010 | GE 36 in. Profile JP969 Electric Cooktop
How to replace a cooktop drip pan
It's really simple. Remove the burner grates, removed the old drip pans, then drop in the new drip pans. You can order a new drip pan from partselect.com if you don't have one yet. Let me know how this works out and if you need any further help.
Benjamin
Nov 04, 2010 | GE Profile JGP636 Gas Cooktop
My GE gas cooktop keeps making a clicking noise and one of the four burners doesn't ignite unless I light it with a match. What should I do?
the burners use a sw on the gas shaft of each burner to make the igniton work. i belive one of the sw are shorted or housing broken . replace it . / tip when I replace one i do them all .. saves time later . falure caused by spills ect and normal ware .. mm
Jul 16, 2010 | GE Profile JGP636 Gas Cooktop
Jan 29, 2010 | GE 30 in. JGP328 Gas Cooktop
G.E Profile gas cook top #JGP640 ignitor.
It is sparking because the module does not sense the heat which would normally cause the sparking to stop.
It can be caused by a poor ground, make sure the ignitor at that burner is clean and free from any obstructions. If it is then it could either be a defective ignitor or spark module.
Mar 12, 2009 | GE Cooktops
Electric Glass GE Profile Cooktop Burner popping
yes the knob is attached to a switch and the switch to the burner by way of wires..you can get into the cook top.but with your description of whats going on i would have the switch with me and then may only have too take apart once.there is a chance your burner is bad,but as you describe the way the switch is acting is seems pretty sure just the switch.you can order switch on line you need your model and ser#
Jan 30, 2009 | GE Profile JGP636 Gas Cooktop
Gas leak in my GE profile JGP336
Contact your local gas company and turn off the gas to the unit.
May 01, 2017 | GE 30 in.Profile JGP940 Gas Cooktop
I own a GE Profile gas cooktop model number JGP940SEK1SS. The igniter continues to make a sparking sound when it is plugged in . We have to unplug the the stove to make it stop.
It could be one of the burner switches shot it out or spark module malfunctions.
Burner switches ***. part# WB18T10366
Spark module part# WB13T10046
Nov 30, 2008 | Cooktops
GE Profile 36" Electric Induction Cooktop - Black Logo
60 people viewed this question
Top GE Cooktops Experts
Dan Webster
Dan Webster
Jim London
Jim London
Are you a GE Cooktop Expert? Answer questions, earn points and help others
