Question about Saws
I'm looking for a bush with a washer combined that works inside the gearbox of the "Black & Decker" circular saw model: BD 531/H1A, this is the bush that supports the main drive gear.
SOURCE: I have tried numerous times to undo a nut on my
Am I correct that this is a hand-held saw? Want to make sure of the terminology.
If so, the bolt holding the blade has right hand threads -- meaning it loosens by turning counter-clockwise.
Is there a blade lock? Are you using it?
Posted on Apr 30, 2009
  • 17 Answers
SOURCE: I have a 2hp black and decker circular saw. Went
If the motor is 3 phase (which it may be if it is 2 HP) , it will run backwards if 2 of the wires are traded position. You may have changed the wires in the plug if you replaced a plug.
Posted on Jun 12, 2009
rowdy45176
  • 2176 Answers
SOURCE: I can't tighten the blade on the saw.
are both flanges in place and on correctly?? That would be the first thing that I would look for.
Posted on Dec 30, 2009
  • 5603 Answers
SOURCE: My black and decker, circular saw, blade moves
Some things like this we have to improvise. Possibly a filler washer can be used. It is not clear if the shaft end play is what you have, or the blade clamping washers allow the movement. If it is the blade clamping, possibly there is a burr on the washer that prevents the proper mating of the clamping washers.
If it is shaft end play, then try to use a fiber type washer to fill the gap.
Posted on Feb 10, 2010
al_kupchella
  • 843 Answers
SOURCE: How can I change the circular saw in my Back &
Unplug it and loosen the bolt in the middle of the blade. It's a standard thread, so turn it lefty-loosey. But you need to hold the blade from turning. That's easy by putting a screwdriver in front of a blade tooth, under the sole plate. Let the sole plate prevent the screwdriver from rising up with the blade as you turn the bolt. If your current blade has small teeth (like a plywood blade) then you can raise the sole plate as for a maximum depth of cut, then push the saw against the front edge of a workbench (or block of wood somehow held still) as if you were going to cut it. Before you remove the bolt, take note of the exact orientation of the washer (or washers)so you can replace them the same way.
Posted on Jun 18, 2010
Testimonial: "Thank you very much; more or less what husband had tried to do, but none the less he's going to try again, according to your instructions. Will let you know the result later. J"
My black a nd decker circular saw just stopped functioning midway inuse
It is hard to say at this distance what is wrong. If it is oldish, the motor brushes may be worn down. It could be that a wire has come loose from a terminal in it, or a contact has broken in the on/off switch assembly. All those things have happened to me at one time or another.
Jan 18, 2015 | BLACK and DECKER POWER TOOLS Black And...
Need parts for Black and Decker circular saw model 7390
Go to
http://www.ereplacementparts.com/black-and-decker-7390-type-circular-saw-parts-c-4167_4252_12157.html
Jan 24, 2013 | BLACK and DECKER POWER TOOLS Black And...
I need a switch for my black & decker 7 1/4 worm drive saw model 7395 type 1
That tool was discontinued in 1980 and parts are obsolete. You may be able to use a Skil 77 worm drive switch as many of the circular saw switches were configured the same. The switches are usually marked with a 1 and 2 on the back so make sure the wires are put on correctly as some will have the 1 on one side (top and bottom terminals) while others are on the top or bottom (next to each other).
Aug 05, 2012 | Black & Decker 7 - 1/4" Heavy Duty...
Looking for replacement blades for Black & Decker Zip Saw
Its on ebay http://www.ebay.com/itm/NEW-BLACK-DECKER-ZIP-SAW-11-PIECE-CUTTING-SET-74-691-/260888941452
only 15.00
Apr 02, 2012 | Saws
How can I change the circular saw in my Back & Decker Circular Saw, model: P3703 (1100 watts)
Jun 18, 2010 | Black & Decker Saws
My black and decker, circular saw, blade moves side to side about an eigth of an inch. The bushing on the shaft appears short allowing some movement. Does any one know a fix for this?
Feb 10, 2010 | Black & Decker CS1012 7-1/4" 12 Amp...
How do I adjust the clutch on a 2 1/2 hp black and decker circular saw?
there is no clutch adjustment on a circular saw of this type. what is the model number and I will try and give you some hints, if you tell me what the problem is.
Dec 21, 2009 | Black & Decker Saws
Bought my black and decker circular saw in july 2009 stopped working and still has warranty Ace hardware where I puchased the saw will not exchange saw says I need to send it to the company but, I didn't...
you would need to send it to a Dewalt service center or any authorized Dewalt service center for warranty repair, The exchange period is usually 30 days. If you need to give me your city, state and zip and I will try and find one close to you.
Oct 28, 2009 | Black & Decker CS1012 7-1/4" 12 Amp...
Saws Logo
27 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Saw Expert? Answer questions, earn points and help others
