Question about Denon AVR 1312
Why when the unit is turned on it flashes from green to red and does not turn on and needs several tries?
2 Suggested Answers
Professor_V
  • 92 Answers
SOURCE: Cannot turn the receiver on - when I push the
YOU MAY HAVE A PROBLEM IN THE OUTPUT SECTION OF THE AMPLIFIER AND THUS ACTIVATING THE PROTECTION CIRCUITRY. MAKE SURE IT IS NOT BEING CAUSED BY BAD SPEAKERS. REMOVE THE SPEAKERS, THEN POWER THE RECEIVER UP WITH THIS NO SPEAKER LOAD CONDITION. IF IT STILL GOES INTO PROTECTION, THEN THE RECEIVER WILL NEED TO BE SERVICED. THIS IS ALL YOU CAN DO AT THIS POINT, AS YOU HAVE MADE SURE THAT THE INSTALLATION IS NOT CAUSING THE PROBLEM, AND THE SERVICE OF THE AMPLIFIER OR POWER SUPPLY SECTION IS VERY INVOLVED AND TECHNICAL IN NATURE. IF YOU SEND IT IN FOR REPAIR, I SUGGEST SENDING IT TO THE SONY REPAIR CENTER, AS THEY HAVE A FLAT-RATE REPAIR FOR THESE RECEIVERS AND YOU WONT BE CAUGHT OFF-GUARD WITH A HIGH PRICED REPAIR. YOU CAN CONTACT THEM AT SONY STLYE=800-571-7669 OR TRY 800-222-7669. THEY WILL TELL YOU WHICH OF THE FOUR REPAIR FACILITIES TO SEND IT TO AND ALSO PROVIDE YOU WITH THE RMA AND FLAT-RATE REPAIR COST. LET ME KNOW IF YOU NEED FURTHER ASSISTANCE.....V
Posted on Jan 08, 2010
Fujitsu airon ASTA24LCC 2 flashes green and red then 5 red flashes any idea what it means
Had similar problem (ie. 2 green & red flashed followed by 5 red flashes - Fan blowing but not cooling ... I also noted that the outside unit fan wasn't going). Tried restarting several time after waiting only a minute or two after turning the mains power off but with no change. So turned the unit off at the mains power and then fired it up about 2hrs later and it was all working fine.
Jan 24, 2013 | Fujitsu 24C1 Air Conditioner
I have a pioneer pdp-r05XE, on the plasma, the light flashes green and red alternately whilst on the receiver it flashes green 6 times. I can't get the tv to turn on...
Unplug if you have not done so BOTH units from power for several minutes (any cable or satellite box also connected.
wait several minutes and restore power to all units which may allow them to reboot.
Cannot hurt and may help.
Dec 06, 2012 | Televison & Video
Sylvania LD320SSX 32-Inch 720p LCD HDTV/DVD Combo fails to turn on(power light flashes green, turns solid green 10-15 minutes then red). Leading up to this condition it would take several attempts to turn...
You checked for bad capacitors, but did you check for bad soldier joints?
I would start there. Also, be prepared to replace the Power Supply Board.
Aug 30, 2011 | Sylvania LD320SSX LCD TV
When you turn of the TV the POWER indicator flashes green for several minutes. The TV never comes on. After the several minutes of the POWER indicator flashing green, it stops, I hear a click and the...
A continuous flashing red light with the word LAMP on it would definitely mean you're going to need to spend a few bucks on a new lamp....or for a few more, upgrade to a TV from this century that doesn't require lamp changes :)
May 11, 2011 | Panasonic PT-52LCX66 Projection Television
Green "ice size" light is
try to reset your unit to unplug the unit then after a several minutes plug it on then observe the unit.
Mar 06, 2011 | Refrigerators
I have a Braemar LCB450-G evaporative cooler. There are two Diagnostic LED,s on the electrinics module,one red & one green. When the power is turned on at the module the red LED remains on & the...
There are several possibilities, the drain valve is opening and closing, this causes water to fill the base, the float valve will not achieve the desired level so the fan will not start. This could be the drain valve actuator is U/S or the PC board. Have you tried to turn the main power off at the switch board for 1/2 hour?
Most occasions the service person will swap out all the units as they purchase it as a package. It is not cheap to replace these units.
Nov 22, 2010 | Heating & Cooling
Any time i turn on my ps3 it will turn off
HI If the light turns yellow then red, this is a overheating issue. let it stand for an hour unplugged to cool.
Now, if the green light doesn't turn yellow before red, this will confirm that the HD(Hard disk), is experiencing some difficulties with the booting process. This will occur if the internal connections are damaged, due to a solder break. In this case, you will need to send the unit to Sony for a repair. Try removing the HD from the unit. after the unit HD is removed for a minute and re-installed, try to power up and initiate a boot. if the unit continues to not boot and flashes the red light after the HD is pulled, this will confirm that the HD is the culprit.
Contact Sony for a repair ticket if the problems persist.
Oct 03, 2009 | Sony Playstation 3 (PS3) Console
Saeco Italia SUP021 YR green lights and red water light flashing
You can't manually reset. The machine will have to do it. I had the same problem, two green flashing lights with one red (water) all 3 would just keep flashing and not turn solid. No coffee can be made or hot water. I could not pump prime. The problem was the steam wand was blocked with old milk residue. It needs unblocking or you will never pump prime. I could not unscrew the steam wand...so I let it sink in a glass full of hot water for a few minutes and then turned the water knob counter clockwise to push out the softened residue. After that, everything was good. When water started flowing out of the steam wand, the red light turned off and the green lights turned solid. The obvious answer to why you can't pump prime is there is a blockage somewhere and best to start with the steam wand. --Mabada
Sep 14, 2009 | Starbucks Saeco Italia Digital Barista...
Blinking power light.
i hve the same problem. I turned on my Sharp Aquos lc-32d62u HDTV last night for the first time, but it is black and a blinking green light.
did you find a solution?
Mar 06, 2008 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
Mitsubishi HC1500 DLP Projector
This sounds like an overheat issue and requires return under warrantee.
Oct 06, 2007 | Mitsubishi ColorView XL30U Multimedia...
Denon AVR 1312 Logo
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
