Question about Emerson Fans Emerson MW8115SS Microwave Oven
How do i get the back off my emerson microwave
How do i get the back off i think it may need a fuse
    Sergeant:
  • 258 Answers
Screws are probably on the bottom of the microwave - then the whole side and top come off - then you have access to the back - i doubt it has an internal fuse though! I presume you have checked the plug fuse.
Be very careful - microwaves generate a massive electrical output and will fry you in a second!
Posted on May 13, 2014
The light bulb in my emerson 8997B stopped working. It had come backThe light bulb in my emerson 8997B stopped working.
Buy a different brand of Microwave. This is ridiculous! We are now buying a new microwave - a different brand, one that has a light bulb that is easy to change
Dec 16, 2012 | Emerson Black Microwave Oven
Emerson mw9113ss wont turn on
If the is no power to the microware and the display does not showing any signs of power then you internal fuse has been damaged. First I would suggest you move the mocroware to a different outlet to eliminate the outlet as the problem. Once you have eliminate the outlet, then disconnect the power and then remove the covers and find and replace the fuse. Let me know the results
Nov 27, 2011 | Emerson Microwave Ovens
I think the fuse is blown on my emerson microwave mw8781sb i test the power coming from the plug and there is power but none after that
You have blown the microwave internal fuse. If you are handy enough you can take the cover off and follow the power cord in the system. The fuse will be between the transformer and the power cord
YOU MUST DISCONNECT POWER CORD AS PART OF ELECTRICAL SAFETY WHILE WORKINGON ON THE SYSTEM!!
Sep 27, 2011 | Emerson MW8102SS 1100 Watts Microwave Oven
When I press the start the button the turn table inside microwave is not turning and there is not heat on the food. But the light is on and the clock is working. What do you think is the problem? and what...
The turn table motor of your microwave is defective already and also the magnetron - the source of generated heat of the microwave is also defective. But before assuming that magnetron is dead, check the high voltage fuse it may be blown and replace the fuse (if it is blown) it with similar rating. I hope I help you with your microwave problem.
Mar 21, 2011 | Emerson MW8107WA Microwave Oven
Emerson Microwave Model MW8119SB found blown fuse. Replaced fuse power came back punched in 10 sec started microwave and fuse blew again.
Chances are that either the diode or capacitor are shorted. Be very careful, the capacitor can store a charge and should be discharged first for safety. Hope that helps...
Geno
Dec 06, 2009 | Emerson Microwave Ovens
I think the fuse blew on my emerson microwave. Can I check myself by removing the rear panel?
Unplug the power. Remove the screws, on the back that secure the outer case and slide it off to the rear. Check near the control panel for a clear glass fuse. If it is bad, make sure to replace it with one that has the same ratings.
Jul 11, 2009 | Emerson MW8985W Microwave Oven
Fuse is blown where is fuse
I think this has the fuse in the back,if not look on the side where the door handle is.
Mar 17, 2009 | Emerson MW8168B Microwave Oven
Replace Emerson Microwave Ove Fuse
Most of the manufactory has put them in the back where the power cord comes in.
Mar 13, 2009 | Emerson MW8168B Microwave Oven
Emerson MW8119SB microwave wont stop running with door closed
It should have a one-year warranty on parts and labor.
I'd call Emerson at 1-800-695-0098 to find your nearest authorized service center to have it fixed free.
It's probably a bad door switch or door switch mount.
We're happy to help and we appreciate your thoughtful rating of our answer.
Jun 22, 2008 | Emerson MW8778 Microwave Oven
Emerson Model MW8627W does not heat after changing fuse!
check the magnitron and capacitors one of this is bad
Sep 18, 2007 | Emerson MW8627W Microwave Oven
Emerson Fans Emerson MW8115SS Microwave Oven Logo
99 people viewed this question
Top Emerson Fans Microwave Ovens Experts
William Miller
William Miller
Owen Barnes
 Gary Gemmell
Gary Gemmell
Are you an Emerson Fans Microwave Oven Expert? Answer questions, earn points and help others
