Question about Audi Vehicle Parts & Accessories
Where is cam sensor on chryseler300 m 99 model
Turn over wont start
    Master:
  • 710 Answers
In the head near the cam shaft.
Posted on Sep 01, 2014
How to diagnose timing belt verses cam sensor wont start and sounds funny when turning over
If it sounds like it has no compression I would vote for the timing belt. Code 16 is for the cam and crank sensors being out of sync, and code 340 is no signal from the cam sensor. Which would happen if the cam is not turning.
Feb 10, 2014 | Cars & Trucks
Car cranks wont start
run fault codes to find the faulty sensor that is not allowing the injectors to work. It may be a cam position sensor . Check that the cam shaft is turning ( broken timing belt.)
Jan 20, 2014 | Cars & Trucks
My 1999 2.4 dodge stratus wont run unless i unplug cam sensor its a new sensor and a new crank sensor
I'm having excatly same problem, found this sequence to ge the car running again..turn off ign, unplug cam position sensor, crank for 2 seconds, connect cam shaft sensor, crank again and it starts like that...
Apr 01, 2011 | 1999 Dodge Stratus
No start on 2003 s-10
did it work before cam sensor if yes put old one and tyr agian to start
Jan 25, 2010 | 2003 Chevrolet S-10
Wont start
I'm assuming the engine is cranking over while turning the key and wont start. from this assumsion it possible the cam sensor on the timing chain is broken. or no fuel pressure. to test for fuel pressure, turn the igntion key on, locate the fuel line & port on the fuel line, remove the cap & depress the small screader valve by using a small pocket screwdriver, fuel should shoot out with a lot of pressure. no fuel shooting out most likey the fuel pump is bad. if this has good pressure the cam sensor is most likey the cause. to replace the sensor, you need to replace the timing chain.
Nov 03, 2009 | 1992 Buick Park Avenue
Car wont start
being 94' im sure it has high miles, cam and crank sensor common to fail over time do to wear and heat exposure. check the basic, make sure you getting fuel and sparks. fuel pump only work as long the engine is turning over due to the crank sensor sense the flywheel turning. crank sensor may be faulty. no sparks, check coil make sure is good and putting out 12v, auto zone can test it for free. good coil, than check cam sensor, cam sensor senses the cam turning and tell the ecu to tell the coil to disperse the sparks to the plugs. cam and crank sensors, there no way of testing it but replacing the unit unless you have the special equipment to test it; both is fairly cheap to replace, check ebay.
Oct 24, 2009 | 1994 Mazda MX-6
I have 97 chrysler lhs 3.5l that just died on me and wont start its getting fuel ive replaced the ignition coil and the cam and crank sensors but still wont start and am getting an cam sensor not giving...
I would check the timing belt probably broke. Best way pull the cam sensor out take a flashlight shine it down in the hole and have someone turn it over. u should see it turning if you don't the timing belt is broke. good luck
Oct 10, 2009 | 1997 Chrysler LHS
2001 concorde dont start
Check the cranshaft position sensor located under the timing cover. Also check the camshaft sensor located near the camshaft.
Feb 06, 2009 | 2001 Chrysler Concorde
Vehicle Parts & Accessories Logo
Top Audi Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
ray gallant
Tom
Are you an Audi Vehicle Part and Accessory Expert? Answer questions, earn points and help others
