Question about 3M SCP716W Projector
White dots on my 3M SCP716W - 3M SCP716W Projector
Diagonal lines at 45 degree angle from left top to right bottom of screen
db:: 4.31::Diagonal lines on tm2 screen? fz - Hivmr
www.hivmr.com/db/fzap9jk8dp87mcjk3cc9jsp7fzxk7pz1
There are faint 45 degree diagonal lines covering my brand new tm2 LCD ... with some static looking diagonal lines going from bottom left to top right. .... DB:3.01:Dv6113 Us - Computer Freezes Showing Diagonal Lines On Screen aj ... Also there arediagonal lines that run across the screen at about a 30 degree angle.
3M Privacy Filter for Laptop diagonal-14.1" viewing screen ...
www.amazon.com/3M...diagonal-14.../B00006B8A9
Amazon.com, Inc.
Rating: 3.8 - ‎1,617 reviews
Amazon.com: 3M Privacy Filter for Laptop diagonal-14.1" viewing screen ... Premium 14.0 Inch Privacy Screen for Widescreen Laptop or Computer Monitor .... 3M™ Privacy Filters create a 30-degree cone of vision so on-screen data is .... You'll also notice a large "3M PF14.1W" printed in the top right hand corner of the filter.
FZ190: Faint Diagonal lines on screen? ' NotebookReview
forum.notebookreview.com > ... > VAIO / Sony
Jan 27, 2016 | Computers & Internet
Black dots projected on my 3m scp716 projector
Actually, this is a known issue with this specific model as 3M has acknowledged. We bought 4 of these and 3 have had to be replaced in 3 years because of this exact issue. It requires the mainboard to be replaced and it is almost as expensive to do this as to buy a new unit. 3M has been know help to us on this even through we bought the entire setup (Projector, Arm, Smartboard) and spent over $15000.
Oct 17, 2012 | 3M 78-927719-5 - SCP716 DLP PROJ 2400LUMEN
White dot on my samsung DLP 42" screen
white dot is from a failure in the dlp chip. it controls 1000s of tiny mirrors which help make up your pix, when the mirrors get stuck a white dot appears. over time more will pop up. Probably in the $300-$500 range to have someone repair.
Jul 04, 2010 | Samsung Televison & Video
White dots all of screen
sound like you have a bad dlp chip. this happens to a lot of samsung dlp tvs. some of the mirrors are stuck. they can appear as black dots or white dots and it usually gets worse over time.
Feb 06, 2010 | Televison & Video
I have got two white dots that have appered on the screen
is your problem like this?
if it small like this DMD BOARD
if its smaller try to clean the back of your tv..
Dec 26, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
Liesegang DV 610 / 3M MP 8610
http://www.eserviceinfo.com/downloadsm/29752/3M/Liesegang_MP8610/DV610.html
Mar 07, 2008 | 3M MP 8610 Multimedia Projector
3M Multimedia Projector
Hi Sue, On your first concern, a possible reason for the 'Sync is out of range' is because your laptop's resolution is just too high for the projector to handle. You may have to manually lower down your screen resolution (right click on a clear area of your desktop, click on properties, settings tab, move bar of screen resolution towards the left). Try different settings that will give you best performance without the projector rejecting the input signal. Am not sure about your second concern though, offhand your description sounds like video noise. You may have to check that your connectors are firmly plugged in. A longshot is to remove any possible source of interference like wireless phones including your mobile, WiFi AP and the likes. Perhaps you give the first suggestion a try and see if the purple dots disappear when you have the projector running ok. Further you may have to reset your projector if it's got one. Normally it's a small button clearly marked RESET somewhere at the rear of the unit. Hope this works out for you. Pls comment/post back should you need further information. Good luck and kind regards.
Aug 04, 2007 | 3M MP 8640 Multimedia Projector
3M SCP716W Projector Logo
Top 3M Office Equipment & Supplies Experts
jasbo
jasbo
Are you a 3M Office Equipment and Supply Expert? Answer questions, earn points and help others
