Question about Briggs & Stratton Prosumer 20324 Gas Pressure Washer
Pump oil is milky white in color - Briggs & Stratton Prosumer 20324 Gas Pressure Washer
  • 32 Answers
Sounds like water has gotten mixed in your oil.
Posted on Nov 26, 2014
If oil in pressure washer is milky colored will it hurt pump to run till oil change
Milky appearance in oil is due to water mixing with the lubricant. An internal seal has failed. Have your pressure washer checked by a small-engine mechanic immediately.
Apr 13, 2018 | Garden
2003 Ford Explorer sport is losing all the water from radiator
3 ways of loosing the coolant/water search for leak -hole in radiator,hoses at connections or damaged,water pump,heater core and hoses //blown head gasket coolant being burnt will show white smoke out tail pipe ,oil will show milky cocoa color ---//transmission oil cooler lines have internal damage in radiator and transmission has fluid draining
Aug 25, 2016 | 2003 Ford Explorer
My Alero is overheating, and pushing the coolant out the surg tank, my brother said water pump, changed. then said thermostat, changed. then said radiator clogged, flushed. still doing the same thing?
Do fans come on , if not it is the $8 dollar temp sensor or the fan fuse or the fan motor.
If you have heat from the heater and if radiator gets hot then it is neither the raditor or the water pump nor the thermostat as neither heater or radiator would get hot
because no water would be moving in the system.
So
May 11, 2015 | Cars & Trucks
What would cause oil to turn milky white?
That is the typical color when water is mixing with the oil.
Probably a leaking seal or gasket.
The washer will need servicing.
May 05, 2014 | Simpson MegaShot 3100 PSI Gas Powered...
Water get into oil
Water in oil makes the oil go grey / milky or white . Check the cooling system by a pressure test and if it is holding then it will not be water in the oil.. If you are referring to transmission oil then the tan colour indicates burnt oil, and must be replaced. Water in that oil will also be a white cherry/ milky colour.
Mar 18, 2014 | 1993 Buick LeSabre
Replaced the ECU but still smoke coming from exhaust
What color smoke? black = fuel blue = oil white = water. oil is not always milky with head problem if thats what you are getting at. Does it start rough (misfireing) then clear up?
Jun 15, 2012 | 1990 Lexus LS 400
Engine runs smooth and the head gasket has been replaced,I already know I need a new radiator..There is a small amount of white smoke at start up,and my oil is milky looking>
milky sump oil is coolant in the sump
could be head gasket
could be the aluminium housing behind the water pump has corroded and leaking water into the sump
that will account for you thinking that you need anew radiator
May 08, 2017 | 1999 Chevrolet Suburban
Engine overheat changed water pump thermastat radeatorfan temp sensor bottom radeator hose what else could it be
blown head gasket,check oil for water in oil,gray milky look,check antifreeze in radiator for color,check exhaust for white smoke or water-coolant if its going out exhaust gasket blown inbetween cylinders,see if pushing antifreeze out of radiator etc.check radiator for leaks pressure test it,cap on radiator bad?
Jul 21, 2011 | Chevrolet Cavalier Cars & Trucks
Oil milky white in pump
it may have a slow water leak inside the pump.
change oil and monitor the new oil.
if it goes milky the next time you use it then it has a bad leak and the seals will need to be
replaced,otherwise the bearings will rust & seize
Dec 18, 2010 | Honda Pressure Washer PSI 3000
Over heating new radiator and thermastat
what about the water pump also if you dont have all of the air out of the cooling system it will cause it to not flow properly and might cause it to over heat,also check the oil to see if coolant is getting in there,the oil will be milky white or have a slightly sweet smell to it and could look slightly greenish in color
Jan 02, 2010 | 1999 Nissan Altima
Briggs & Stratton Prosumer 20324 Gas Pressure Washer Logo
256 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
