Question about Bosch Microwave Ovens
Microwave error code E7 - Bosch Microwave Ovens
2 Suggested Answers
ercupa190
  • 12223 Answers
SOURCE: E7 fault on bosch oven/ microwave
this means a control board problem . However follow this steps: use the common sense and carefully. God bless you
Enter the Service Test Mode as follows:
1. Open door.
2. Press DELETE.
3. Press pads 1, 3, 5, 7.
4. Close door.
5. Press DELETE within 15 seconds (Pressing RESET at any time will cancel the Service Test)
Posted on Sep 17, 2012
Mod.KHMS155LSS-1 Getting F-6 Fault code ????
Search Results
    Combination Microwave Wall Oven - Error Code/Message ...
    www.kitchenaid.com/...microwave...error-code...f6-error-cod...
    KitchenAidQuestion: Combination Microwave Wall Oven - Error Code/Message - F6 Error Code -F6 E8. Answer. Product Symptom: Combination Microwave Wall Oven ...
    Over-the-Range Microwave - Error Code - Starts with F ...
    www.kitchenaid.com/...microwave-error-code...f...f6...code/P...
    KitchenAidKitchenAid's product help articles give answers to your frequently asked questions (FAQs). ... Microwave - Error Code - Starts with F - Starts with F6 - F6E0 Code.
    Kitchen Aid Oven Model # KEMS308SSS02 error msg - Lost ...
    www.shopyourway.com > Manage My Life > Questions
    I have a Kitchen Aid Model # KEMS308SSS02 and I getting the follow error message... is working and was always working but the top microwave/oven does not work. ...Kitchen Aid Oven Model # KEMS308SSS02 error msg - Lost Err/ F6 E0/ ... Most "F6/E0" fault codes is usually because of a loose wire connections, loss of ...
Feb 05, 2016 | KitchenAid Microwave Ovens
Tip
Troubleshooting KitchenAid oven, range and microwave error codes
Here list of Kitchen Aid range and oven codes.
4 Digit Failure Codes
F1 - E0 EEPROM communication error
F1 - E1 EEPROM checksum error
F1 - E2 UL A/D error
F1 - E4 Model ID error
F1 - E5 Calibration shifted
F1 - E6 Latch signal mismatch error
F1 - E9 Stack overflow
F1 - E3 Wiring harness cavity size does not match stored value
F2 - E0 Shorted touch pad
F2 - E1 Keypad cable connection error
F2 - E5 Cancel key drive line open
F2 - E6 Cancel key drive line open
F3 - E0 Oven temperature sensor (RTD) opened (upper oven on double oven models)
F3 - E1 Oven temperature sensor (RTD) shorted (upper oven on double oven models)
F3 - E2 Oven temperature is too high (Cook mode)
F3 - E3 Oven temperature is too high (Clean mode)
F3 - E4 Oven temperature sensor (RTD) opened (lower oven on double oven models)
F3 - E5 Oven temperature sensor (RTD) shorted (lower oven on double oven models)
F3 - E6 Drawer sensor open
F3 - E7 Warming drawer sensor shorted
F4 - E1 Meat probe malfunction - shorted
F5 - E0 Door Switch
F5 - E1 Self clean latch will not lock
F5 - E2 Latch during CLEAN error
F5 - E5 Self clean temperature not reached within 45 minutes.
F5 - E6 Door is open, but latch is locked
F5 - E7 Self clean latch will not unlock
F6 - E0 Return line not connected
F7 - E1 Common switch wire defective
Two digit codes:
F0 ERC Board failure
F1 ERC Board failure
F2 Oven temperature is too high
F3 Oven temperature sensor open
F4 Oven temperature sensor shorted
F5 ERC Board failure
F7 Function key stuck on ERC
F8 ERC Board failure
F9 Oven door lock failure
Microwave and Microwave combo error codes:
F1 - E3 or F1 - E4 Electronic control malfunction
F2 - E0 or F2 - E1 Keypad connection error
F2 - E3 Keypad held down too long, or keypad is shorted.
If you get an error code, try first resetting the code:
1. Disconnect power for about two minutes.
2. Connect back power.
3. If code re-appears, test and eventually replace faulty part.
Regards.
on Mar 27, 2010 | KitchenAid KHMS155LSS 1000 Watts Microwave...
Why does my microwave not work? It displays what I believe is an error code.
. The SE error code means the microwave has had a Key short error. The control panel or smart board will need to be replaced.
-korrinA S
Mar 03, 2015 | Kenmore Microwave Ovens
1. Open door.
2. Press DELETE.
4. Close door.
Sep 16, 2012 | Microwave Ovens
I have an prestige induction cook top model PIC 3.0 the problem is that it displays an E7 error whenever switched on after appx. 1 minute and the food is not boiled /cooked. please let me know what is the...
Dear Sir i have an prestige induction cook top model PIC 3.0 the problem is that it displays an E7 error whenever switched on after appx. 1 minute and the food is not boiled /cooked. please let me know what is the problem How Can Solved this Problem This prestige induction cook top model PIC 3.0 Only one week so please do need full
thx... Kundan singh Rana Baddi (H.P.) 09857455945 ranansd@gmail.com
Mar 23, 2011 | Microwave Ovens
Error code F2
The error code "F2" that appears on your KitchenAid microwave refers to a keyboard failure/short on the front button panel or loose keypad connector
Attempt the following to clear error:
Check keypad connector for firm connection.
Press "Cancel" after the error code is noted, if error code returns after 60 seconds, replace keypad ( also called touch pad or membrane switch ).
Best of Luck with the microwave.
Jan 26, 2011 | KitchenAid KHMS155LSS 1000 Watts Microwave...
Error code F5:E7 Can not get the oven door unlocked or reset this code. What do we do?
Beginner on forumn, don't have any manual in front of me on f5:e7. Sounds like a conventional oven problem, oven door locking. If in fact is some form of conventional heat oven (convection?), I had similar problem with a GE range, it flashed some kind of code seams like which I later interpreted by using owner's manual that explained codes. In my case it was in "cleaning mode" and you can't turn that off unless you unplug or turn breaker off, that puts it back to default mode with nothing running. I simply tried out the self cleaning feature, from there the oven went to full on heat and oven door locked unexpectedly. I learned stays locked till cycle finishes and oven cools, which is some time after the oven automatically switches off, said that it can be a couple of hours before you hear a...click, and now door opens (note to self, don't ever do that again).
Jan 13, 2011 | KitchenAid Microwave Ovens
When we start the microwave and push the start button instead of 30 seconds 15 minutes appear.No other button including start button works.It stops working only on opening the window of the microwave and...
That normally means the board needs to be replaced. Without wanting to explain all the details, im almost sure the keypad is still in good order.
Aug 08, 2010 | Microwave Ovens
Ge microwave jvm 1430 error code F3
F3 Key panel (touch pad) shorted This code will occur if a shorted key panel is detected continuously over 60 seconds. Replace key panel (also called touch pad).
Jul 17, 2009 | GE JVM1430 Microwave Oven
Microwave Ovens Logo
19 people viewed this question
Top Bosch Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Bosch Microwave Oven Expert? Answer questions, earn points and help others
