Gemini II motor for VEP-90M
Where can I get a Gemini 2 motor for an Empire Comfort Systems Heating unit model VEP-90M??
5 Suggested Answers
  • 269 Answers
SOURCE: when I try to play
dont answer this but was it received with a crackgen if so they have shut down that key code
Posted on Sep 08, 2010
walesarumi
  • 6993 Answers
SOURCE: Comfort Zone carrier Unit:
the answer is yes. It will work. They are almost the same thing with slight difference.
You can go ahead and replace the old interface with the new style thermostat.
I wish you good luck.
Posted on Sep 10, 2010
Mintex
  • 442 Answers
SOURCE: Empire Comfort Systems fireplace remote control not working since fell off table.
I assume you've tried removing and re-seating the batteries in the remote. If this doesn't reset the remote the fall most likely broke a component or solder point on the circuit board. If all else fails you can try opening the remote and making sure no wires are broken. Look closely around the battery contact points. Often when a remote is dropped the weight of the battery can cause damage to that area.
Posted on May 02, 2015
  • 739 Answers
SOURCE: I have two Vulcan Bonnaire Evap Cooling systems. Unit 1 was working fine, unit 2 had a blank screen on comfort control. Plumberfriendswapped something between units. Now unit one is blank.
forget plumber friend and get HVAC friend
Posted on May 04, 2015
How to set gas control knob on 18,000btu empire heater its out of whack
CORGI used to be the registered engineers for GAS appliances, but this has now been superceeded by 'GAS SAFE' contact any GAS SAFE engineer.
Oct 08, 2014 | Empire Comfort Systems SR-18LP 18,000 BTU...
CO2 and flame "dancing"
This normally is caused by low gas pressure, or some blockage in the burners. Do not run this heater until it is fixed.
Jan 10, 2014 | Empire Comfort Systems Empire RH50C Closed...
Can I buy a new remote control for a Empire Comfort Systems R-5797
Yes call Ray Murray and the can have one sent to you with in 2 days.
Apr 03, 2013 | Empire Comfort Systems Heating & Cooling
Empire DV35 is making soot
OS for computers. Try another post. gl.
Paul Rogers as in Bad Co?
Nov 28, 2012 | Empire Comfort Systems DV35IN33L Natual...
Our furnace is less than 1 year old - turned it on the other day the the blower does not work ????
Depending on which model optional blower you have, either one requires that the fan switch be turned ON for it to operate (manually or automatically). Also be sure that the blower cord is plugged into a functional* wall outlet. I have included a link to the Owner's Manual for your model Direct Vent Heater. In case you have misplaced yours. Starting on page 18, you will find the 2 optional blower models.Determine which one you have and follow their suggested recommendations, as one requires oiling several times during the heating season.
http://www.empirezoneheat.com/assets//EHS/manuals/12434--0410%20%28EN,FR,SP%29%20DV-%2825,35%29-2SG.pdf
* "Functional" meaning there is power to that outlet and a circuit breaker has not been tripped.
If you continue to have an unsolvable problem contact Empire Comfort Systems Technical Service Dept 800-851-3153. The blower has a I year warranty. If you have your dated Proof of Purchase, repairs or replacement may be covered.
Hope this helped you and thanks for choosing FixYa.
Sep 19, 2011 | Empire DV-35 Heater
Blower stopped working Empire Stove Model # RH655 Ser T40891422
Beth, first check the blower's cord to be sure that it's still plugged into the wall outlet. Also, check your home's circuit breaker panel for a tripped circuit breaker, that is feeding that outlet.
On the mechanical side there's 3 things that need to be done:
1. Check the Fan Control by shorting across the terminals.
2. Check for blower wheel binding, by removing the wheel and operating the motor.
3. Check for frozen bearing due to a lack of oil.
To further help you with a parts breakdown, I have included a link to the Owner's Manual for your Model. You can download & print it if you like.
http://www.empirezoneheat.com/assets//EHS/manuals/128
If you continue to have a problem with it , contact Empire Comfort Systems Technical Service @ 800-851-3153.
Sep 16, 2011 | Heating & Cooling
Empire FAW-60-2-spp fan short cycles about 4 seconds on/off
From what you have described, it sounds as if the Fan Control Switch, ECS Part # R-1941, which works in conjunction with the Limit Control Switch (ECS Part # 912073) is failing and needs to be replaced. You can order these parts directly from Empire Comfort Systems. If you decide to replace these parts yourself, it will give you an opportunity to thoroughly clean the interior of the Wall Furnace, if you haven't already. If you need further information, contact Empire Comfort Systems, Technical Service @ 800-851-3153 Monday - Friday.
Hope this helped you to troubleshoot the problem. Please don't forget to rate my response. Thanks!
Mar 27, 2011 | Empire Heating & Cooling
Heating & Cooling Logo
90 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
