Question about Miele CVA4070 Coffee Maker
How come my Miele built in coffee Maker always has fault 73?
3 Suggested Answers
SOURCE:
SOURCE: miele coffee maker cva 4070
OK. Here's the deal. I struggled with this CVA 4070 (F 73) problem also recently, and even posted a questions in the cyber world about it. I jiggled, re-cleaned the machine, re-read the Miele manual, and scoured the internet for schematic drawings of this brewing unit's insides. No luck. Finally after finding out I'd have to pay $199 just for a service clown to walk in my front door, I said NYET!!!  I must solve by myself. If I can take apart & fix my Dyson, etc, etc, I WILL DO THIS TOO!!  (MUST HAVE COFFEE>>>)
Pull out the brewer, turn it a quarter-turn to your right, and look at the spot where that small black plastic piece -- shaped like a block "M" or block "W" -- should be situated. Pull it out, if it isn't out already. Don't worry about yanking it out or harming these parts, said the Miele troubleshooter guy in New Jersey on the phone. They're "made from the same plastic used in football helmets."  Okey-dokey.
This approx. 1.5" wide, blocky plastic piece is part of the "slide" that takes the brewed coffee grounds into the waste container. When positioned correctly, it looks like a block "W,"  with the "wings" ointing up, and slides in just under a brown 1.5" flat piece. A small, down-facing tab on the brown piece clicks into the "W" piece and holds it in place. The "W" should feel fairly solid, although it is not rigidly in place, as the entire mechanism is a movable system to deposit the grounds in the waste receptacle.
Put everything back inside your CVA 4070 "love" machine, hit "on," and wait for it to go through its warm-up.  No F73 message?  Yeah!  Mission Accomplished. You, like I, have fixed your Miele, saved your family relationships, and saved yourself a bundle from unnecessary service calls.
Posted on Apr 09, 2009
  • 40 Answers
SOURCE: While cleaning Miele built in coffee maker, Fault
Insufficient water intake. Check that the water tank is installed correctly. Check hoses and connections. Check water tank valve.
Posted on Feb 28, 2011
Miele cva 4075 stuck brewing unit
http://mielerepaircenter.com/miele-coffee-maker-repair
Sep 07, 2014 | Miele CVA4070 Coffee Maker
Miele cva4070 coffee maker showing fault76
Fault 76 is caused by there being too much coffee to compress . Assuming there is not a fault with brew unit or brew unit drive, then try to use less coffee (see menu settings) or grind the coffee to a finer level (see manual). regards
Jun 16, 2014 | Miele CVA4070 Coffee Maker
Want to clean the grinder part of my built in miele coffee maker.
Very Carefully with the power plug pulled out of the wall.
If you do not have the manual, go on line and have customer service send you a detailed instruction manual or have a technician take you through the process.
Mar 25, 2014 | Miele CVA4070 Coffee Maker
While cleaning Miele built in coffee maker, Fault 17 appeared. What does this mean?
Feb 27, 2011 | Miele CVA2660 Stainless Steel Coffee Maker
F17 fault
Try posting your question in the oven section as opposed to the coffee maker section. You might get more responses
Feb 06, 2010 | Miele CVA4070 Coffee Maker
Getting Fault 73 for my CVA 4070 at start-up. Have removed the brew unit to ensure is clean and plastic piece -- shaped like a block "M" or block "W" - is in the "W" position. Have tried a manual on and...
I have had the same fault 73. Miele is coming out to replace the drive and the brew unit. SHould be a $700 repair. Thank God for warranties. I'll et you know the end result once repairs are complete.
Jan 09, 2010 | Miele CVA4070 Coffee Maker
Miele coffee maker cva 4070
Feb 27, 2008 | Miele CVA4070 Coffee Maker
Miele CVA4070 Coffee Maker Logo
168 people viewed this question
Top Miele Coffee Makers & Espresso Machines Experts
Pierre Laplante
Vincent G
Vincent G
Jerry Greenberg
Jerry Greenberg
Are you a Miele Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
