Question about Jura Capresso Impressa F9 Espresso Machine
Why water will not dispense from water sprout?
Our F9 stopped dispensing water from the water sprout and dispenses instead into the used coffee grain holder.
SOURCE: no coffee will dispenses
Hi, We had a similar problem and it turns out the beans we were using were too oily and clogging up the works. We solved it by using a slightly more coarse grind (and brewing a stronger cup), and by buying only the best beans (oily beans don't make coffee stronger, just means they aren't good beans and by roasting longer can make the coffee taste stronger). Try Barefoot Coffee Roasters (I don't work for them, just love their coffee). We also use the cleaning tablet more often than prompted, and clean the inside of the flap when we dump the grinds. Good luck. Great coffee, but finicky machine!
Posted on Aug 14, 2008
  • 3 Answers
How fine have you got you grind setting, if it is a new machine it needs to be on course Grind, fine grinds clog the filter.  You need to reach into where the tray goes with a cloth and wipe clean the filter bin which is right behind a flap
Posted on Dec 09, 2008
SOURCE: one dispense spigot barely trickles
You need to take a paper clip and clean the little holes where the water comes out on the left side (It's like a screen). Also you should pull the silver thing that adjusts to allow taller cups underneath up and down several times. You should do the latter every week. It helps get rid of some of the coffee grounds that block the aforementioned little holes.
Posted on Mar 12, 2009
z34aga
  • 137 Answers
SOURCE: Water in the drip tray of coffee machine
take out the mecanism and clean it how is instructed in manual, than get it back carefuly. Pay attention on position of mecanizm.
Posted on Mar 28, 2009
  • 60 Answers
SOURCE: I have a new Z5 (less than 300 cups) that began
If the grounds are really wet and not looks like a round firm cake, you need to use coarser grist on the grinder. The water in the drip tray is coming from the brew unit. The o-rings are not holding the pressure inside because the sieve is clogged. It could also be that the o-ring are dirty, then the brew unit needs to be disassembled and cleaned.
A good way to controll if the grist is too fine, is to watch if the coffee is just dripping from the outlet. Then try adjusting the grinder until the coffee flows evenly. You can also hear if the pump works harder during brewing.
Posted on Jun 02, 2009
Water dispensing from stem wand instead or brew nozzles
Overfill problem, could be leaky inlet valve or manual fill lever stuck partly on. Franko (ems.coffee768@gmail.com )
Jan 03, 2014 | Saeco Talea Touch Plus Espresso Machine
Why does ground flow from the top of brewer instead of coming through the dispenser?
Buy a new K-cup holder from amazon.com. Its the black cone shaped holder.
Jan 11, 2013 | Keurig B70 Coffee Maker
Benvenuto B20 not dispensing water
I had similar problem - water came out into the tray underneath instead of the cup. I found the problem to be the drain valve after taking the whole machine apart.1_20_2013_9_13_36_pm.jpg
this part was cracked in my case which meant that the water did not come out the nozzles..
To get at this part you would need to take the back top and both side panels
here is the exploded view of this part
Dec 18, 2012 | Bosch Benvenuto B20 Espresso & Coffee...
I have a Saeco Royal Coffee Bar that will intermittently fail to dispense espresso. It will grind the coffee but instead of dispensing the coffee, it dumps the (dry) coffee into the dreg drawer and resets...
Hi
Its not the water. More than likley its the lever on the right side of the machine at the top middle of the door. Its pushed all the way to the back or positive. Move it 1 mark towards the front of the machine and try again. If you put too much coffee in the brew unit, it can't compress it and kicks it out. It could also be your grind is too coarse. It should look like auto drip coffee.
Apr 02, 2011 | Saeco Royal Cappuccino Espresso Machine
New Bunn NHBX takes about an hour to make 10 cups of coffee. Water is dispensed drop by drop instead of a stream. 4 dispensing holes are clean
It sounds like you might have a problem with the water tubing. If you will call Customer Service at 800-352-2866 we will be happy to assist you with this issue.
Sep 21, 2010 | Bunn NHBX-B Contemporary 10-Cup Home...
Gaggia syncrony logic not dispensing water. Just drops pods and red light comes on. have cleaned brew unit shower screen and dispenser tube. still have the problem
Lubricate the brew unit with a food safe grease this should help.
The brew unit becomes stiff and fail to load up fully this stops the water being dispensed
Jan 18, 2010 | Gaggia Syncrony Logic 74884 Espresso...
No coffee dispensed and no water comes out when Rinse selected
1st use cleaning tablets used for brew unit. and go on cleaning procedur.
2-the sound you hear i think is only motor of
grinding
thank you
Mar 24, 2009 | Miele CVA615 Espresso Machine
Cocoa latte hot drink maker
replacement parts for valve, lid, and bowl can be found here
http://www.focuselectrics.com/catalog.cfm?dest=itempg&itemid=3169&secid=53&linkon=subsection&linkid=118
part no. description Price
U27-2 Lid, White. CA series
$3.50
U18-182 Blending Jar with Built-In Stir Paddle
$12.00
U17-104 Dispensing Valve, Beige. Interchangeable with all Cocoa Latte Models
$5.00
Jan 23, 2009 | Back to Basics CM300 Coffee Maker
Machine stopped working
This machine is piece of s... I replaced two of them so far and experienced same problem.:
Machine works fine couple days
...than it start dispensing less water into the cup.
...than it stop dispensing water into cup completely and instead all water goes into the tray.
..The pump also starts occasionaly to make interrupted repetative sound.
Did anybody get it fixed?
Jan 05, 2008 | Krups XP2070 10 cup Coffee Maker/15 bar...
Cuisinart BGB-300
I just got mine to work. It seems that so much water condensation gets into the grinder that there was rust stopping the grinder from moving. Just remove all the parts, especially the blade and basket holder assembly. Take a pair of pliers and twist the grinder stem manually to loosen the rust. Turn it a good number of times and then test it out. I didn't want to use WD-40 on something my wife uses everyday. Good luck.
Aug 10, 2007 | Cuisinart DGB-300 Coffee Maker
Jura Capresso Impressa F9 Espresso Machine Logo
62 people viewed this question
Top Jura Capresso Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Ken Macumber
Ken Macumber
Level 1 Expert
Are you a Jura Capresso Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
