Question about NEC Ux5000 24-button Telephone Set ip3na-24txh
When trying to retrieve voicemail, i'm not prompted for a code and it just rings
Voicemail number changed on samsung galaxy and can not check voicemail now
Voice mails are set up from the phone company. Your phone has no control over the voice mailing service other than assigning a speed dial to it. You should call your phone company on their customer service number and they will tell your the number to call for setting up your voice mail box.
Mar 11, 2014 | Cell Phones
Forgot unlock code voicemail kyocera jax
Go to this link...
http://www.virginmobileusa.com/resources/phones/prepaid/manual/kyocera-aw-jax.pdf
DOWNLOAD THE MANUAL FOR FUTURE REFERENCE!! LOL
Scroll down to page #39 to where it says Use Voicemail and follow the instructions!! As per the service tech I spoke to on the phone to find this link, following these instructions will automatically erase your old voicemail unlock code as well as any as yet unheard messages.
Just in case anyone still has difficulty in finding the instructions.....
Set Up your VoicemailBefore your phone can receive voicemail messages, you must set up a 4-10 digit passcode and record a personal voicemail greeting.When you have set up your voicemail, all unanswered calls to your phone are automatically transferred to voicemail, even if your phone is in use or turned off.1. Press and hold the 1 key.2. Follow the system prompts to create a password and record a greeting.
Check your Voicemail
When you receive a voicemail message, a
notification with a voicemail message icon
appears at the top of your screen.
• At the voicemail notification, select Call to call
your voicemail number and follow the system
prompts to retrieve the message.
Select Ignore to clear the notification without
checking messages. The notification icon
remains on top of the screen until you listen to
the message
• When only the voicemail message icon
appears on top of the screen, select
Voicemailand follow the system prompts
Best of luck!!
Susan
Jan 27, 2012 | Kyocera Jax Cell Phone
I am having trouble retrieving voicemail remotely...I was able to do it before and now can't get a code that works.
well..........can you set another code that will allow you to retrieve voicemail?
I think you can replace with another code by the menu....see if this can work?
Regards, Meder's tv service and please rate..thak you for using FIxYa
Dec 22, 2011 | Panasonic KX-TG1033S Cordless Phone
How do I retrieve my voicemail from a land line
Access your voicemail from your mobile cell phone and record a personalised voicemail greeting.
Now call your number from a landline, and when you hear your voicemail greeting prompt you to leave a message, press the required key sequence to access your voicemail from the landline.
The required sequence is dependent on which network/service provider you are using.
If you let me know which network, i can give you more detailed information.
Jan 06, 2010 | Motorola Cell Phones
I tried to re-record a voicemail message from my office phone, but the voicemail box is on a different phone. I entered the system by placing the voicemail box ext that I wanted to update. I followed the...
it must have been the main general mailbox you accessed, when in the voicemail the greeting number it will ask which prompts you to press * or # to re - record current msg. try intercom 777 and if no answer still reboot the system . power switch on upper right of the cabinet.
Oct 01, 2009 | Lucent PARTNER18 Corded Phone
I need to change the number of rings before phone goes to voicemail
First, call your voice mail. After the messages you will be given a menu to follow. On the Sony Ericsson W350 I went to Personal Options (4) then to Administrative Options (2) and finally Prompt Level (3). After reaching Prompt Level you have the option to shorten or extend the number of rings. At this point I chose to shorten the prompt and then I exitted the system.
Apr 12, 2009 | Lands Phones
Can't retrieve voicemail from a remote location
When you hear the auto attendant answer your call into the office, dial ** and then follow the prompts.
Feb 15, 2009 | NorStar T7316E Corded Phone
How can you retrieve voicemails if you are not in the office
Press *7 when voice mail answers and follow prompts.
Dec 14, 2008 | Lucent PARTNER18 Corded Phone
Voicemail Reset Toshiba DKT2020
you need to log in to your voice mail. when you hear your voice press * , enter your user id, enter your security code then follow the prompt.
Apr 04, 2008 | Toshiba DKT-2020 Corded Phone
Changing the number of rings to answer on our Model 28112 GE Cordless phone
the voicemail ring count has to be setup on your phone line thru your voicemail menu,and has nothing to do with the answering machine. if you don't want the answering machine to pickup, just shut it off. follow the prompt's for your voicemail settings, there you'll be able to set the amount of rings you want.
hope this helps.
wg
Feb 14, 2008 | Uniden Cordless Phone
NEC Ux5000 24-button Telephone Set ip3na-24txh Logo
16 people viewed this question
Top NEC Radio Communications Experts
Mister Danger
David Payne
David Payne
Are you a NEC Radio Communication Expert? Answer questions, earn points and help others
