Question about Garden
Loose steering LA 145 - Garden
Why does the wire on my mower blade clutch burn off on a la 145 jd?
Something is loose causing a bad ground situation. Which will cause the wire to be burned. Locate the loose part and tighten it.
Jul 27, 2016 | John Deere Garden
Need a schematic for mower deck belt configuration for LA 145
Here is a link with diagram and routing configuration, I hope this helps.
https://jdparts.deere.com/partsmkt/document/english/featbene/fb_MaintSheet_LA145_48_deckLawnTractor.pdf
Sep 30, 2013 | John Deere Garden
Steering john deere la 145
This is a messy thing to trouble shoot. You should take the return hose from the input of the pump off. You can do this at the pump or at the wheels. Then you need to run it and catch all the PS fluid that comes out. Turn the wheels to the left and the right to get all the fluid out. Replace the fluid. You can flush it out with diesel if you want. IF that does not help then you have to take the power assist off the unit and have it disassembled to see if it is a seal or something sticking in the unit.
Jul 21, 2013 | Garden
LA 145 won't crank...replaced battery & fuse
Check your battery connections. Pull spark plug. A lot time the cyl. will with fuel.
Mar 03, 2012 | John Deere Garden
Al momento de ir avanzando en el tablero de mi carro prende la leyenda de power steering y el volante pierde su manejabilidad se pone tenso
chequeate la bomba aver si tienes aceite en ella ,opor si tienes un liqueo en la mangas o en la bomba
Apr 05, 2011 | 2006 Chevrolet HHR
How to remove steering colum on 1977 buick la sabre
at the back of the steering wheel there are scews.then remove the center pad of the steering wheel.you wil also need to loosing the center nut that secures the steering wheel.
Sep 20, 2010 | 1983 Buick LeSabre
Me falta el regulador de corriente de esta impresora se me perdio
Por favor llama a HP Colombia, al siguiente numero telefonico:
01-8000-51-HP INVENT (01-8000-51-474-68368)
De Lunes a Domingo de 8:00am a 10:00pm
Ellos pueden venderte el regulador y te lo envian por correo
Gracias
TechSaver
Feb 06, 2010 | HP PhotoSmart 145 InkJet Printer
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
john h
