Question about NComputing Computers & Internet
Vspace x-series how to start station - NComputing Computers & Internet
Ncomputing x550
i also have the same problem, it looks like it hapens when you re-iinstall
Nov 13, 2013 | NComputing X550 PCI CARD W/ VSPACE F/LG...
Drivers windows xp
pls give me drivers for ncomputing pci card x550 for windowsxp
Sep 12, 2013 | NComputing X550 PCI CARD W/ VSPACE F/LG...
Ncomputing with 5 stations freezes after 30 mins in use
Make sure the software is registered after the vSpace installation. Also, make sure this is part of a fresh install, not an image where vSpace might have been pre-installed.
Nov 23, 2012 | NComputing X550 PCI CARD W/ VSPACE F/LG...
Ncomputing (x550) client cannot print
The solution itself won't allow or prevent printing, it is purely a Windows issue. You can try to logon to the host system and do a test print. If that works, then logging on to one of the NComputing stations with the same account should allow you to print successfully as well.
Apr 27, 2012 | NComputing X550 PCI CARD W/ VSPACE F/LG...
Cannot connect server ...... client PC diplay this message
Can you PING the L230 device from the server? In other words, are you confident there is a clear IP path from server to device? Also, if you're running on XP, turn off the XP firewall as a test. If that works and you still want to run with the firewall on, then you'll need to specify specific ports to be opened up on your firewall or your domain's firewall policy. Those ports, as listed from NComputing's website are:
Port Exceptions
  • For L-series device connection
    • TCP: 27605, 27615, 3581, 3597, 3645, 3646
    • UDP: 1027, 1283, 3581
  • For vSpace registration
    • TCP Port 3630
    • Point to:
      • register.ncomputing.com
      • or 85.214.107.229
  • For vSpace Update
    • TCP Ports 20 & 21
    • Point to:
      • 70.182.176.102
      • or 81.169.173.128
      • or 81.169.173.128
Jun 12, 2011 | NComputing L230 Network Terminal
First l230 connect to vspace ok,then i installed safe360 , then l230 report "terminal server - yet not ready. please, retry ..."
What is Safe360, an AntiVirus or Firewall software? If so, the program may have inadvertently blocked port access to the kernel which vSpace needs access to for user sessions. Below are the port exceptions for firewall configurations and file exceptions for Antivirus configurations. Current as of this post.
  • Port Exceptions
      • TCP Port 3630
      • Point to:
        • or 85.214.107.229
    • For vSpace Update
      • TCP Ports 20 & 21
      • Point to:
        • 70.182.176.102
        • or 81.169.173.128
        • or 81.169.173.128
  • File Access Exceptions
    • For vSpace functionality
      • C:\Windows\system32\KMServc.exe
      • C:\Program Files\Common Files\NComputer\Bootsrv.exe
    • For vSpace tray icon
      • C:\Program Files\NComputing vSpace\KmMsg.exe
    • For vSpace Registration
      • C:\Program Files\NComputing vSpace\KmRegWiz.exe
    • For vSpace Update
      • C:\Program Files\NComputing vSpace\KmUpdate.exe
May 01, 2011 | NComputing L230 Network Terminal
NComputing vSpace not installed my pc Error
Options:
(A)
An authorization error usually occurs when more than one system in a LAN has the same software serial numbers assigned to the system. In this case, the first PC to be turned on does not suffer an authorization error, but any subsequent PC's which contain the same serial number will experience the issue.
To remove these duplicate serial numbers, first unregister them, then delete them from the host PC they are installed on:
  1. Access the NConsole application by either:
    • Click "Start" > "All Programs" > "NCX-2000-XP" > click on the entry labeled "NCX - 2000 - XP"
    • Double-click the NComputing console application icon in the system tray
  2. In the left-hand pane, navigate to "Local Settings" > "Information and Settings" > "Serial Numbers"
  3. To unregister a serial number, right-click on the number and select "Unregister now"
  4. To remove serials, right-click on the number and select "Delete"
Also, an update that does not install correctly may rarely cause corruption of the data file in which serial number information is contained, causing this error. If there are no other X-series hosts on the network with duplicate serials, then a complete uninstall and reinstall of the X-series software may fix this issue. When uninstalling, choose to unregister all serials and remove all serial registration data.
To download the latest version of our software, please search the knowledge base using "software download" as the search text, for links to the latest software.
(B)
When more than one X300 station is used under the same login (same Username on two or more stations), Active Desktop error messages may occur. Also stations would be sharing same user settings and other files, which could cause unpredictable errors.
Different stations should always be used with different usernames logged in. To add more User accounts (usernames), go to Windows Control Panel, select Users and then go to Create New User option.
Mar 10, 2011 | NComputing X300 3 User Expansion Kit...
550 NCOMPUTING PROBLEM
when i insert ncomputing cd in my computers drive and want to install ncomputing softwere the massege appearce that "NComputing vSpace not installed
Error report:
This software is hardware protected. Your hardware is not supported. Please contact NComputing Inc. or its partners to purchase supported hardware. plz solve my problem as soon as thank u
Jul 16, 2010 | NComputing X550 PCI CARD W/ VSPACE F/LG...
Computers & Internet Logo
35 people viewed this question
Top NComputing Computers & Internet Experts
Tom Chichester
Dan Shibata
Dan Shibata
Are you a NComputing Computer and Internet Expert? Answer questions, earn points and help others
