Question about Kenwood Microwave Ovens
My Kenwood Microwave K23CM13 , the turntable runs slowly and eventually cuts out ,turning the whole unit off
  • 17 Answers
SOURCE: Microwave turns on, but no heat or turntable movement
The problem is that the magnatron is not getting power. Chance is that if could be a bolwn fuse inside the unit. If the fuse don't fix it then that leaves the charging diode, capacitor or the magnatron, or high voltage xformer of which without technical epertize I would not recomend attempting to replace. good luck
Posted on May 14, 2008
ginko
  • 19396 Answers
SOURCE: GE Spacemaker XL1800 Microwave
You need to take apart the oven and fix the turntable gear, then reassemble it, it is not a difficult job. Always work with power unplugged.
Posted on Aug 04, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: G.E. Spacemaker microwave turntable won't turn
The turntable system consists of the motor, the coupler, the turntable support with rollers, and the tray.
You can see and hear a video of how a turntable motor should sound when you rotate it by hand.
If yours is not set to be off via the control panel, and it won't rotate or it sounds like it's grinding, etc., you may have a bad motor or plastic coupler.
To replace either, you need to unplug power, then remove the bottom cover of the oven.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Posted on Dec 16, 2008
pgh_pa_guy
  • 2992 Answers
SOURCE: I HAVE A KENWOOD MICROWAVE GT/AL17,THE TURNTABLE
Two possibilities: either the turntable coupling is broken or the turntable motor has quit. The plastic coupling can wear or crack so it no longer fits properly on the turntable motor shaft. Then even though the motor still turns, the turntable doesn't. Or the motor itself may have stopped working. If the plastic coupling still looks normal and you can't rotate it easily by hand while it's in place, it's probably the motor.
I'm here in the US so I can't suggest where to find parts, but you should be able to locate a supplier who might have replacements available. Of course the oven will still work without the turntable running. You'll have to open the oven occasionally and turn the food yourself to insure even cooking.
Posted on Jun 03, 2009
  • 353 Answers
SOURCE: Kenwood microwave not heating
cheaper to buy a new one
Posted on Jun 30, 2009
Turntable not working
please follow this step and fix it. God bless you
f the carousel inside your microwave won't turn when you run it, the small motor that operates it may be broken.
Nov 22, 2013 | Kenwood KENCJ99SSA Microwave Oven
GE spacemaker XL1400
what problem do you have mention ? attached is there a list please indicate. God bless you
    No Lights or Power, Unit seems Dead The voltage to the unit is good.Lights come on, but can not program unit, Touchpad dead
    Microwave Runs, but no Heat Turntable rotates, acts like it is heating but doesn't. This is the big one, many possibilities.
    Microwave Runs, Heats, but turntable does not move
    Microwave is arcing
    Microwave Vent Hood is not working Over The Range(OTR) Models.
    Microwave Stove Light not Working OTR models, light bulbs good.
    Microwave overheats and keeps turning off
Oct 01, 2012 | Microwave Ovens
The paint (or whatever it is covering the bottom)
Check the 3 wheels on the circular plastic part that's fitted below the turntable.
It sounds like they may need some filing down. Run your fingers around the wheels to see if there are any sharp bits of plastic that could be cutting into the paintwork on the base.
Clean out the base of your oven and apply a thin film of vaseline to each of the 3 wheels. This will help rotation in future.
Remember to keep cleaning out any excess food particles that may lodge below the turntable, as these will eventually slow down or stop the rotation, which in turn means that your food is not heated evenly throughout!!!
Nov 18, 2009 | GE JE2160 Microwave Oven
I HAVE A KENWOOD MICROWAVE GT/AL17,THE TURNTABLE HAS STOPED TURNING, ANY ADVICE MANY THANKS. TONY Nr IRRLAND
Jun 03, 2009 | Whirlpool MH7140XF Microwave Oven
I'm trying to fix my turntable
Most units have a acess panel on the bottom of unit.If not it would be a cut out around where the motor is.I would say try that if to much work let me know
May 08, 2009 | Sharp R-320HQ Microwave Oven
Turntable doesn't turn
remove bottom panel,< screws along front and tips down > the turntable motor is in the middle. Unplug motor and use multi-meter< insert probes into plug end > run short cycle with something inside of unit," glass of water ", if you have voltage here then the motor is bad and needs replaced. If not then mother board most likely problem.
Apr 26, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Maytag Microwave 1150 Help
Check first the motor coupling under the turntable, if that is not the problem , then test and eventually replace the turntable motor.
Click here and select model to get parts and diagrams.
Apr 05, 2009 | Maytag MMV4205 Microwave Oven
No longer turns
on the bottom of most units you can get to the turntable motor with some side cutters,cut the joins. pull the little flap off and there is your motor run a current through it to see if it turns(how much will say on the motor) if not turning there is your problem
Oct 06, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Maytag MMV5165BA Over The Range Microwave
We had this problem. It was installed improperly - to recirculate instead of to vent.
Sep 07, 2007 | Westinghouse WST3504 Microwave Oven
Microwave Ovens Logo
50 people viewed this question
Top Kenwood Microwave Ovens Experts
acmservice
Andrew Taylor
Andrew Taylor
Are you a Kenwood Microwave Oven Expert? Answer questions, earn points and help others
