Question about Uniden BCD396XT Handheld Scanner
How do you fix a loose charging port?
Scanner won't charge when I plug it in. The charging port is loose.
2 Suggested Answers
BillB-SA
  • 2761 Answers
SOURCE: where can I purchase an
Sorry to be the bearer of bad news, but your scanner dates back to about 1994, and parts for it are no longer stocked. You can contact Uniden via the link below and see if they can cross reference your part (it may be used on a newer scanner), but the chances of finding a replacement are not great. You might also try eBay and other web sites where you might locate a used scanner either as a replacement or for parts.
http://www.mycusthelp.net/uniden/_cs/QuestionAsk.aspx
Posted on Mar 02, 2011
How to tell if the charge port is loose or broken
About 56,70,000 results (1.03 seconds)
Search Results
SOLVED: How can I fix the charging port on my Android tablet? - iFixit
https://www.ifixit.com/Answers/.../How+can+I+fix+the+charging+port+on+my+Andr...
Jul 5, 2012 - asheley, since I do not know what make/model your tablet is, it will be ... 10485 Questions View all ... the charging port but it seems to be loose and refuses to charge. ...Answered! ... My cousin has the same problem his charging port is broken. ..... Replacement ports,if it is a standard connector, are usually .
Mar 21, 2017 | The Computers & Internet
Tip
How do you fix your phone if it wont charge? ...
All you need to do is shut down your device, remove the battery if possible and use something small, such as a toothpick, to 'lever up' the little tab inside the USB port on your smartphone or tablet. Do so very carefully and gently, then reinsert your battery and plug it in again.
or this.
  1. Turn the phone off.
  2. Remove the battery.
  3. Wait 10 seconds.
  4. Plug in the charger.
  5. Insert the battery.
  6. Turn on the phone.
How to fix phone that won charge properly AndroidPIT
SOLVED Why won my Samsung Galaxy II charge Samsung Galaxy II
How to fix phone that wont charge
How to fix Samsung Galaxy S6 that not charging Troubleshooting Guide
Why is my Samsung charger not working Google Search
on Dec 12, 2017 | Samsung Cell Phones
Tip
Ipod not charging when i connect it to the usb port. or iphone.
If an alert says that your accessory isn't supported or certified. These alerts can appear for a few reasons: Your iOS device might have a dirty or damaged charging port, your charging accessory is defective, damaged, or non Apple-certified, or your USB charger isn't designed to charge devices
If your iPhone iPad or iPod touch won charge
How to Fix an iPad iPhone or iPod Touch That Won Charge Anymore
Help My iPad Won Charge
Help My iPod Battery Won Charge
ipod do not charging when connect it to the usb port Google Search
on Dec 06, 2017 | Computers & Internet
I CANNOT CHARGE THE TABLET THRU EITHER PORT- THE REGULAR CHARGING PORT OR THE USB PORT THAT I FOUND ALSO CHARGES IT. WHAT COULD BE WRONG AND WHAT ARE POSSIBLE SOLUTIONS?
could be software issue reset it would fix it:?
damage to ports both broken sounds unlikely
try usb plug into a different computer
the cables inside the tablet are loose or not connected
check for damage to ports and loose connections inside device
Jun 29, 2015 | Proscan PLT7223G 7" 4 GB Wi-Fi Black...
My iphone won't charge up at all i put it on
hi there.
Follow these steps:
  1. Remove any debris from the charging port on the bottom of your device.
  2. Restart your iOS device.
  3. Try a different USB cable or charger.
  4. Make sure that you have the latest version of iOS.
  5. Contact Apple Support to set up service.
If your iPhone, iPad, or iPod touch won't charge - Apple Support
Why my iPhone is not charging?
2: Change the Wall Outlet or USB Port Plugged Into. The next most common reason aniPhone won't charge is because of where it's actually plugged into. Sometimes the wall outlet itself isn't working or the light switch is turned off, so if you're using a wall charger then change the outlet.20 Feb 2016
iPhone Won't Charge? Here's Why iPhone Isn't Charging & How to Fix It
How do you clean the charging port on iPhone?
To be safe, back up your iPhone or iPad to your computer or the cloud. Power it off, and with a normal toothpick, gently remove the lint. You will be amazed how much can get stuck in the port. Connect the charger and see if it works.16 Dec 2014
Use a toothpick to clean out your iPhone - CNET
https://www.cnet.com/how-to/use-a-toothpick-to-clean-out-your-iphone/
How do I charge my phone if my charger port is broken?All you need to do is shut down your device, remove the battery if possible and use something small, such as a toothpick, to 'lever up' the little tab inside the USB port on your smartphone or tablet. Do so very carefully and gently, then reinsert your battery and plug it in again.16 Jul 2016How to fix a phone that won't charge properly - AndroidPIThttps://www.androidpit.com/how-to-fix-a-phone-that-won-t-chargeSearch for: How do I charge my phone if my charger port is broken?
or try this link.
iphone won charge up Google Search
Nov 19, 2017 | Cell Phones
Where can i get my galaxy s charging port fixed and how would the port become loose?
If it's loose it is probably broken away from the internal circuit board. A common problem. People accidentally knock the plug sideways and they only have fragile connections.
Get a technician to resolver if possible or take to Samsung repair centre.
May 02, 2014 | Accessory Export Samsung Galaxy S i9000...
Fix loose charging port
You will need to take the laptop to a qualified service shop to have it repaired. Usually, the charging port is held onto the mainboard by small solder connections. If the charging port is loose, then these solders have likely been broken. You can try to fix it yourself, but you wil have to disassemble the laptop and re-solder the charging port back in place. If you are not comfortable doing this yourself, then you should take it to a service shop for repair.
Hope this helps!
Joe
Dec 24, 2013 | Computers & Internet
Htc droid incredible 2 won't charge
FOr changing the charging port you have to take it to an authorized service center. it could be a software issue also.
Dec 08, 2017 | HTC Droid Incredible 2
7" touch andoid tablet won't charge
It may be the charger has a loose wire. In that case a new charger would fix the problem. Mine has a problem with the charging port itself. I am fortunatly that my tablet is under warrenty they are going to replace the tablet for me.
Dec 27, 2012 | Nextbook Premium 7 Capacitive Touch...
V-touch won't turn on
Check and see if you have a loose charge port on the V-Touch, or it could be a short in the cord. Try and plug it into a computer and see if it will come on. If not try using different USB ports on the computer (some work better than others.) if that does not work I would try a wall socket. You can get a USB to wall socket plug from almost any I-pod or I-phone. Droid and Android also it. If you still have no luck you could send it back to Visual Land for them to fix. If your warranty is still valid, they will fix it for free. Hope this helped.
Apr 27, 2012 | Visual Land V-Touch Digital Media Player
Uniden BCD396XT Handheld Scanner Logo
44 people viewed this question
Top Uniden Radio Communications Experts
Jason
John
John
Greg Cann
Greg Cann
Are you an Uniden Radio Communication Expert? Answer questions, earn points and help others
