Question about Indesit 18 in. D41 Slim-Line Free-standing Dishwasher
My D41 dishwasher fills empties but wont wash whats wrong ?
4 Suggested Answers
SOURCE: Dishwasher
hello mate, i bought a brand new indesit d40. plumbed it in and the 1st light kept flashing, phoned the technical centre and they said its the anti flood mechanism kicking in and preventing it from working. although water was going in it was not going into the dishwasher but filling the base and the safety feature just shut it off. said to get back in touch with comet who i bought it off for a new one because its a manufacturing problem. put the new one in and theres no problem. wouldn't have a clue how to fix it myself though.
Posted on May 13, 2007
localwonder
  • 6784 Answers
SOURCE: D41 slimline dishwasher not filling
Make sure you get water to the dishwasher. Check to see if the water shut-off valve (located under the sink) is open. If you get water to the dishwasher, but there is still no water inside during the fill cycle, the problem might be with a faulty water valve (located at the bottom of the dishwasher, behind the kick panel, on either side), in which case replace the water valve.
Posted on Jun 13, 2009
SOURCE: my indesit idl530 dishwasher after the first wash
******** web site no answers
Posted on Jun 09, 2010
Water empties immediately DW711
It will be a fault with the water level sensing circuit, try adjusting the inlet tap pressure as it is a time fill and if the pressure is too high or low it will pump out. Also a flood switch fault could cause the same issue.
Mar 12, 2012 | Jenn-Air 24 in. DW711 Built-in Dishwasher
How to fix my Indiset d41 dishwasher ? The power button trips out the electrics ! Stopped mid programme , wont drain , still water left in it after it flooded the kitchen . Cant try any other programme as...
You have a component down to earth. The problem isn't the start button. Most likely to be the element, but ciuld be wash or drain pump. Check the element with a resistance meter first, when you find the componant at fault, replace it
Feb 04, 2018 | Indesit 18 in. D41 Slim-Line Free-standing...
The first 2 lights are flashing intermittently and the machine wont run a wash cycle
Make certain that there is water supplied to the dishwasher. Otherwise, contact an appliance service company.
Feb 22, 2010 | Indesit 18 in. D41 Slim-Line Free-standing...
Ist GREEN LIGHT FLASHES BUT WONT FILL WITH WATER
I also had this problem, it was the automatic anti-flood device, the upper spray arm water pie was leaking into base off unit which operated the anti-flood device.
Hope this is of some use to you and others
ipip32
Jul 20, 2009 | Indesit 18 in. D41 Slim-Line Free-standing...
Jun 13, 2009 | Indesit 18 in. D41 Slim-Line Free-standing...
My dishwasher seems to start ok then the first light starts flashing and it do'es nothing just stays there any ideads what my problem is
Can you tell if it's filling with water. The first thing it does is fill with water (usually on a timed cycle) before the pump starts. If there's no water in the tub, it obviously won't wash dishes, since a dishwasher is nothing more than an enclosed pressure washer. If it does not fill with water, you may have a bad fill valve or the timer that turns the fill valve on may be defective. You DO have the water turned on, RIGHT?
Jun 11, 2009 | Indesit 18 in. D41 Slim-Line Free-standing...
Dishwasher salt
Cooking salt contains ingredients that could damage your dishwasher. It could increase water hardness and they are likely to clog when wet. Suck out as much water as you can from the salt cup,enter there dishwasher salt and run your washer few empty cycles on the lowest temperature. Good luck
Aug 18, 2007 | Indesit 18 in. D41 Slim-Line Free-standing...
Will not start cycles
is it doing the initial pump out then filling with water and stopping b4 the wash cycle? if so it may be that the wash motor has failed(you may hear a buzzing) or the pcb is faulty. if the water does not fill into the base there may be a valve fault of a supply fault. any engineer worth his salt should be able to diagnose this fault on first visit and return with a part so dont expect multi visits.
Jul 18, 2007 | Indesit 18 in. D41 Slim-Line Free-standing...
Dishwasher
Apr 06, 2007 | Indesit 18 in. D41 Slim-Line Free-standing...
Indesit 18 in. D41 Slim-Line Free-standing Dishwasher Logo
Top Indesit Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Eric Taylor
Are you an Indesit Dishwasher Expert? Answer questions, earn points and help others
