Question about Liebert UPStation GXT 2U GXT2-1500RT120 UPS System
Output switch open - Liebert UPStation GXT 2U GXT2-1500RT120 UPS System
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 64 Answers
You give little information, can you tell us more?
The output switch can also act as a fuse.
Is your load too large?
Posted on Jan 26, 2015
06 Lincoln Navigator liftgate opens okay but need help to close why?
Power Liftgate
The power liftgate feature will allow the customer to automatically OPEN or CLOSE the liftgate by activating the interior open/close switch, the remote keyless entry transmitter or by manually initiating liftgate movement. The power liftgate uses a power cinch system to latch the liftgate.
The power liftgate system consists of the following:
  • Power liftgate control switch (located in the overhead console)
  • Power liftgate motors (located in the rear headliner area)
  • Optical sensor and power liftgate encoder wheel (located in the left power liftgate motor assembly)
  • Pinch strip switches (located on the body by the liftgate)
  • Home position switch (located on the cinch actuator)
  • Forkbolt switch (located on the cinching latch assembly)
  • Detent switch (located on the cinching latch assembly)
  • Liftgate close chime module (located in a unit external from the power liftgate module)
  • There are a lot of electrical switches an motors
  • Visual Inspection Chart Mechanical Electrical
    • Power cinching latch and linkage
    • Power liftgate pinch strip switches
    • Liftgate and liftgate hinges
    • Liftgate assist cylinders
    • Liftgate strikers
    • Exterior release handle and linkage
    • Liftgate weatherstrip
    • Liftgate alignment to body and striker
    • Central junction box (CJB) fuse:
      • 5 (7.5A)
      • 105 (30A)
    • Wiring harness
    • Connectors
    Are you willing to take the back hatch apart to test this ,to find a fix . But first have it check for DTC'S - diagnostic troulbe codes '
  • Power Liftgate Module Diagnostic Trouble Code (DTC) Index
    Power Liftgate Module Diagnostic Trouble Code (DTC) Index DTC Description Source Action B1342 ECU Is Defective Power Liftgate Module INSTALL a new power liftgate module. REFER to Power Liftgate Module in this section. B2477 Module Configuration Failure Power Liftgate Module REFER to Section 418-01 . B2522 Vbatt1 Circuit Failure Power Liftgate Module Go To Pinpoint Test B . B2552 Vbatt2 Circuit Open Power Liftgate Module Go To Pinpoint Test B . B2698 Vbatt2 Circuit Failure Power Liftgate Module Go To Pinpoint Test B . B2699 Left Pinch Strip Open or Short to Battery Power Liftgate Module Go To Pinpoint Test B . B2700 Right Pinch Strip Open or Short to Battery Power Liftgate Module Go To Pinpoint Test B . B2701 Left Pinch Strip Stuck Active Power Liftgate Module Go To Pinpoint Test B . B2702 Right Pinch Strip Stuck Active Power Liftgate Module Go To Pinpoint Test B . B2703 Open/Close Switch Stuck Active Power Liftgate Module Go To Pinpoint Test B . B2704 Optical Sensor Power Short to Ground Power Liftgate Module Go To Pinpoint Test B . B2705 Optical Sensor 1 Input Not Active During Powered Gate Movement Power Liftgate Module Go To Pinpoint Test B . B2706 Optical Sensor 2 Input Not Active During Powered Gate Movement Power Liftgate Module Go To Pinpoint Test B . B2709 Gate Open Output Short to Battery Power Liftgate Module Go To Pinpoint Test B . B2710 Gate Close Output Short to Battery Power Liftgate Module Go To Pinpoint Test B . B2711 Gate Open Output Short to Ground or Open Power Liftgate Module Go To Pinpoint Test B . B2712 Gate Close Output Short to Ground or Open Power Liftgate Module Go To Pinpoint Test B . B2713 Unlatch Output Short to Ground or Open Power Liftgate Module Go To Pinpoint Test B . B2714 Uncinch Output Short to Ground or Open Power Liftgate Module Go To Pinpoint Test B . B2715 Cinch Output Short to Ground or Open Power Liftgate Module Go To Pinpoint Test B . B2718 Gate Ajar Output Short to Battery Power Liftgate Module Go To Pinpoint Test B . B2721 Gate Ajar Output Short to Ground or Open Power Liftgate Module Go To Pinpoint Test B . B2722 Open/Close Switch Active During Self-Test Power Liftgate Module Go To Pinpoint Test B . B2723 Glass Position Switch Active During Self-Test Power Liftgate Module Go To Pinpoint Test B . B2724 Forkbolt Switch Invalid During Self-Test Power Liftgate Module Go To Pinpoint Test B . B2725 Detent Switch Invalid During Self-Test Power Liftgate Module Go To Pinpoint Test B . B2726 Home Switch Invalid During Self-Test Power Liftgate Module Go To Pinpoint Test B . B2819 Gate Motor Circuit Short to Battery Power Liftgate Module Go To Pinpoint Test B . B2820 Gate Motor Circuit Short to Ground or Open Power Liftgate Module Go To Pinpoint Test B . B2821 Cincher Motor/Unlatch Actuator Short to Ground or Open Power Liftgate Module Go To Pinpoint Test B . B2822 Cincher Motor/Unlatch Actuator Short to Battery Power Liftgate Module Go To Pinpoint Test B . B2825 Movement Ceased Due to Excess Speed Deviation Power Liftgate Module Go To Pinpoint Test B . B2903 Chime Output Circuit Short to Battery Power Liftgate Module/ Liftgate Chime Module Go To Pinpoint Test C . C1935 Chime Circuit Failure Power Liftgate Module/ Liftgate Chime Module Go To Pinpoint Test C . U1950 UBP Communication BUS Fault UBP Communi- cation REFER to Section 418-00 . U2338 Invalid ACM Message Data Power Liftgate Module REFER to Section 418-00 . U2242 Invalid 4WAS Message Data 4WAS Module REFER to Section 308-07A . U2403 Invalid CSM Message Data Vehicle Security Module REFER to Section 418-00 . U2406 Invalid IC Message Data Instrument Cluster Module REFER to Section 413-01 . U2469 Power Liftgate Disabled By Customer Interface Instrument Cluster Module Turn power liftgate on at message center. U2470 Unexpected Keyfob/Keypad Button Press Power Liftgate Module Go To Pinpoint Test A . U2471 Unexpected PRNDL State Power Liftgate Module REFER to Section 419-10 . U2472 Unexpected IGN State Power Liftgate Module REFER to Section 418-00 . U2473 Unexpected Vehicle Speed Instrument Cluster Module/ Powertrain Control Module REFER to Section 413-01 . U2528 PRNDL Data Mismatch Power Liftgate Module/ Instrument Cluster Module Go To Pinpoint Test D .
Feb 13, 2017 | 2006 Lincoln Navigator 4x4
Interior lights
This is both a courtesy and safety issue on many high end vehicles. The light from the interior lights can cast enough light to get to front door and possibly show dangers in your path. And after first getting into you car and starting it, you can check the back seat for any unwanted hitchhikers. As for the 10 minute timer, I don't know if this can be adjusted. A Chiltons/Haynes repair manual for you car may have that answer, or, the Buick dealership shop foreman. Best of luck.
May 31, 2015 | 1998 Buick Park Avenue
How do I reset lift gate on 2004 lincoln navigator. It doesn't open or close anymore with the remote
Maybe your key fob needs a new battery !
Power Liftgate Initialization
NOTE:If the power liftgate system is turned OFF in the message center, the system cannot be activated with any switches or with the liftgate handle. The system will need to be turned ON for any power operation to occur.
NOTE:The power liftgate may not operate under the following conditions:
  • a low voltage or dead battery.
  • a disconnected battery
  • a power liftgate that has been left open for more than six hours.
  • a power liftgate that has been manually closed and left ajar.
If any of these conditions has occurred, the power liftgate must be reset.
  1. Manually close and fully latch the power liftgate.
  1. NOTE:If the power liftgate does not open during this step, refer to the symptom chart to diagnose the power liftgate for no operation.
    Power open the power liftgate by using the keyfob or overhead console switch.
  1. Once the power liftgate is fully open, close the power liftgate by using the keyfob or overhead console switch.
    This system can also set DTC'S
  2. POWER LIFTGATE MODULE DIAGNOSTIC TROUBLE CODE (DTC) INDEX (BODY CLOSURES) 501-03 Body Closures 2004 Expedition/Navigator DIAGNOSIS AND TESTING Procedure revision date: 08/23/2004
    DTC Description Source Action B1342 ECU Is Defective Power Liftgate Module INSTALL a new power liftgate module. REFER to Power Liftgate Modulein this section. B2477 Module Configuration Failure Power Liftgate Module REFER to Section 418-01. B2522 Vbatt1 Circuit Failure Power Liftgate Module GO to Pinpoint Test B. B2552 Vbatt2 Circuit Open Power Liftgate Module GO to Pinpoint Test B. B2698 Vbatt2 Circuit Failure Power Liftgate Module GO to Pinpoint Test B. B2699 Left Pinch Strip Open Or Short To Battery Power Liftgate Module GO to Pinpoint Test B. B2700 Right Pinch Strip Open Or Short To Battery Power Liftgate Module GO to Pinpoint Test B. B2701 Left Pinch Strip Stuck Active Power Liftgate Module GO to Pinpoint Test B. B2702 Right Pinch Strip Stuck Active Power Liftgate Module GO to Pinpoint Test B. B2703 Open/Close Switch Stuck Active Power Liftgate Module GO to Pinpoint Test B. B2704 Optical Sensor Power Short To Ground Power Liftgate Module GO to Pinpoint Test B. B2705 Optical Sensor 1 Input Not Active During Powered Gate Movement Power Liftgate Module GO to Pinpoint Test B. B2706 Optical Sensor 2 Input Not Active During Powered Gate Movement Power Liftgate Module GO to Pinpoint Test B. B2709 Gate Open Output Short To Battery Power Liftgate Module GO to Pinpoint Test B. B2710 Gate Close Output Short To Battery Power Liftgate Module GO to Pinpoint Test B. B2711 Gate Open Output Short To Ground Or Open Power Liftgate Module GO to Pinpoint Test B. B2712 Gate Close Output Short To Ground Or Open Power Liftgate Module GO to Pinpoint Test B. B2713 Unlatch Output Short To Ground Or Open Power Liftgate Module GO to Pinpoint Test B. B2714 Uncinch Output Short To Ground Or Open Power Liftgate Module GO to Pinpoint Test B. B2715 Cinch Output Short To Ground Or Open Power Liftgate Module GO to Pinpoint Test B. B2718 Gate Ajar Output Short To Battery Power Liftgate Module GO to Pinpoint Test B. B2721 Gate Ajar Output Short To Ground Or Open Power Liftgate Module GO to Pinpoint Test B. B2722 Open/Close Switch Active During Self-Test Power Liftgate Module GO to Pinpoint Test B. B2723 Glass Position Switch Active During Self-Test Power Liftgate Module GO to Pinpoint Test B. B2724 Forkbolt Switch Invalid During Self-Test Power Liftgate Module GO to Pinpoint Test B. B2725 Detent Switch Invalid During Self-Test Power Liftgate Module GO to Pinpoint Test B. B2726 Home Switch Invalid During Self-Test Power Liftgate Module GO to Pinpoint Test B. B2819 Gate Motor Circuit Short To Battery Power Liftgate Module GO to Pinpoint Test B. B2820 Gate Motor Circuit Short To Ground Or Open Power Liftgate Module GO to Pinpoint Test B. B2821 Cincher Motor/Unlatch Actuator Short To Ground Or Open Power Liftgate Module GO to Pinpoint Test B. B2822 Cincher Motor/Unlatch Actuator Short To Battery Power Liftgate Module GO to Pinpoint Test B. B2825 Movement Ceased Due To Excess Speed Deviation Power Liftgate Module GO to Pinpoint Test B. B2903 Chime Output Circuit Short To Battery Power Liftgate Module/ Liftgate Chime Module GO to Pinpoint Test C. C1935 Chime Circuit Failure Power Liftgate Module/ Liftgate Chime Module GO to Pinpoint Test C. U1950 UBP Communication BUS Fault UBP Communi cation REFER to Section 418-00. U2338 Invalid ACM Message Data Power Liftgate Module
Feb 05, 2015 | Lincoln Cars & Trucks
Harley engine codes
P0107 Map Sensor Open/Low
P0108 Map Sensor High
P0117 ET Sensor Low
P0118 ET Sensor High
P0112I AT Voltage Low
P0113I AT Voltage Open/High
P0120 TPS1 Range Error
P0220 TPS2 Range Error
P0122 TPS1 Low
P0123 TPS2 High/Open
P0131 Front Oxygen Sensor Low
P0132 Front Oxygen Sensor High
P0151 Rear Oxygen Sensor Low
P0152 Rear Oxygen Sensor High
P0154 Rear Oxygen Sensor Inactive.
P0222 TPS2 Low
P0223 TPS2 High/Open
P0261 Front Injector Open/Low
P0263 Rear Injector Open/Low
P0262 Front Injector High
P0264 Rear Injector High
P0373 CKP Sensor Intermittent
P0374 CKP Sensor Synch Error
P0444 Purge Solenoid Open/Low
P0445 Purge Solenoid High
P0562 Battery Voltage Low
P0563 Battery Voltage High
P0501 VSS Sensor Low
P0502 VSS Sensor High/Open
P0572 Brake Switch Low
P0577 Cruise Control Input High
P0603 ECM EEPROM Memory Error
P0605 ECM FLASH Memory Error
P06415 V+Vref 1 Out Of Range
P06515 V+Vref 2 Out Of Range
P1001 System Relay Coil Open/Low
P1002 System Relay Coil High/Shorted
P1003 System relay contacts open
P1004 System Relay Contacts Closed
P1009 Incorrect Password
P1010 Missing Password
P1270 TGS Validation Error
P1351 Front Ignition Coil Driver Open/Low
P1352 Front Ignition Coil Driver High/Shorted
P1353 Front Cylinder No Combustion
P1354 Rear Ignition Coil Driver Open/Low
P1355 Rear Ignition Coil Driver High/Shorted
P1356 Rear Cylinder No Combustion
P1357 Front Cylinder Combustion Intermittent
P1358 Rear Cylinder Combustion Intermittent
P1475 Exhaust Actuation Position Error
P1477 Exhaust Actuator Open/Low
P1478 Exhaust Actuator Shorted/High
P1501 Jiffy Stand Sensor Low
P1502 Jiffy Stand Sensor High P1510 EFI Limited
Performance Mode
P1511 EFI Power Management Mode
P1512 EFI Forced Idle Mode
P1514 Air Flow Fault
P1600 EFI Module Processor Internal Error
P2100 EFI Motor Circuit Open
P2101 EFI Motor Circuit Range Performance (Actuation
Error)
P2102 EFI Motor Circuit Low
P2103 EFI Motor Circuit High
P2105 EFI Forced engine shutdown
P2107 EFI Module Processor Internal Fault
P2119 EFI Motor Throttle Body Range Performance
P2122 TGS1 Low/Open
P2123 TGS1 High
P2127 TGS2 Low/Open
P2128 TGS2 High
P2135 TPS Correlation Error
P2138 TGS Correlation Error (Twist grip sensor)
P2176 EFI Closed Position Not Learned
U Codes
U1016 Loss of ECM ****** Data
U1064 Loss of TSM/FSFM ****** Data to ECM
U1097 Loss of Speedometer ****** Data to ECM
U1255 ****** Data Error
U1300 ****** Data Low
U1301 ****** Data High
Harley Davidson 2008 DTC Code Reading (draft)
Harley Davidson DTC Codes - Unofficial Guide Page 3
B Codes
B0563 Battery Voltage High.
B1121(TSM) Left Turn Output Fault
B1121(HFSM) Left Turn Output Open
B1122(TSM) Right Turn Output Fault
B1122(HFSM) Right Turn Output Open
B1123(HFSM) Left Turn Output Short to Ground
B1124(HFSM) Right Turn Output Short to Ground
B1125(HFSM) Left Turn Output Short to Battery
B1126(HFSM) Right Turn Output Short to Battery
B1131(HFSM) Alarm Output Low
B1132(HFSM) Alarm Output High
B1134 Starter Output High
B1135 Accelerometer Failed
B1136(HFSM) Accelerometer Tip Test Error
B1141(TSM) Ignition Switch Low/Open
B1141(HFSM) Ignition Switch Low/Open
B1142 Smart Security System Internal Fault
B1143(HFSM) Security Antenna Short to Ground
B1144(HFSM) Security Antenna Short to Battery
B1145(HFSM) Security Antenna Open
B1151 Bank Angle Sensor(BAS) Short to Ground
B1152 Bank Angle Sensor(BAS) Short to Battery
B1153 Bank Angle Sensor(BAS) High
B1154 Clutch Switch Input Short to Ground
B1155 Neutral Switch Input Short to Battery
Apr 11, 2014 | 2007 Harley Davidson FLHRC Road King...
I have a peavey cs800 s that has no output on channel B. im hoping someone can tell me the first few things i can check. its not the input source or cables i do kniow that much. havent found any loose
Switch inputs, switch speakers, if not you need to open it up(unplugged from power) and do a visual inspection.. possible bad power/output transistor(s)
Apr 11, 2013 | Audio Players & Recorders
I haveSansui 1403ctv the tv set is dead.no output from smps.When I switch on the tv immediatly switching transister(c1802) will be short.
Check the freewheeling capacitor connected to the collector of this switching output transistor for open. Check the serial resistor too.
Dec 05, 2012 | Televison & Video
2008 Harley Davidson DTC codes
P0117 ET Sensor Low
P0122 TPS1 Low
P0222 TPS2 Low
Performance Mode
Error)
P2122 TGS1 Low/Open
P2123 TGS1 High
P2127 TGS2 Low/Open
P2128 TGS2 High
U Codes
U1016 Loss of ECM Serial Data
U1064 Loss of TSM/FSFM Serial Data to ECM
U1097 Loss of Speedometer Serial Data to ECM
U1255 Serial Data Error
U1300 Serial Data Low
U1301 Serial Data High
B Codes
Jan 07, 2012 | Harley Davidson FLHX Street Glide...
The ip4500 will not print - says the paper output tray is open!
Just fixed this problem on mine. Need to remove the covers, watch these 2 vids to see how..
http://www.youtube.com/profile?user=martop49#p/u/1/iQdHDR6po80
Then on the right side where the on switch is, near the hinge is a little switch with 2 yellow wires, it's probably broke. Pull the 2 wires out and solder or twist them together, then put everything back together. It will now assume the door is always open. Jobs a good'n :)
Mar 23, 2009 | Canon Pixma iP4500 InkJet Printer
1993 Cadillac Deville Phantom Codes
ECM Output Cycling
This mode can be initiated after "E.9.5" is displayed on the "Fuel Data Center". The display of the "E.9.5" can be reached by depressing the Hi button while Code ".7.0" is displayed. The ECM output cycling mode, Code "E.9.6." turns the ECM's outputs on and off. To enter the output cycling mode, proceed as follows;
The engine must be running.
Turn the cruise instrument panel switch to the on position so that the cruise control outputs will cycle.
Turn the engine off and within two seconds, turn the ignition on.
Enter the diagnostics and display Code "E.9.5".
Depress the accelerator pedal (throttle switch open) and release it (throttle switch closed). The ECM output cycling mode begins as the display switches from Code "E.9.5" to Code "E.9.6."
It is possible to leave the ECM output cycling mode at any time and return to ".7.0" by clearing the ECM and BCM codes. If the display does not advance to Code "E.9.6", refer to Code "E.7.2" of the switch test.
The output cycling mode will end automatically after two minutes of cycling and the display will switch from Code "E.9.6" to Code "E.9.5".
The outputs will cycle on and off every three seconds until the two minute automatic shut off occurs. The only exception to this three second cycle is the cruise control power valve which cycles continuously. If additional output cycling is desired, recycle the throttle switch.
Oct 13, 2008 | 1993 Cadillac DeVille
Printer Error
there is button or clip backside of the printer.......u just press it and open the tray..........it is also possible that u don't attch ur usb wire to the cpu u just check it .........may be it will be good........
Apr 19, 2008 | Canon PIXMA iP3000 InkJet Photo Printer
Liebert UPStation GXT 2U GXT2-1500RT120 UPS System Logo
305 people viewed this question
Top Liebert Computers & Internet Experts
Computer Links
Are you a Liebert Computer and Internet Expert? Answer questions, earn points and help others
