Question about Motorola Mobility SLVR L7 Cellular Phone
Need help how i adjust my time
Take the battery out and leave it out for maybe 4-5 minutes then put it back in and turn it on and it should be fixed
Posted on Nov 04, 2007
How do i do a timing adjustment
well what kind of timing adjustment you need sir, it will be helpful if you be more clear as to what you want to knw,am wondering why you want to do that, but if you want to do a distributor adjustment you should have yourself a timing light,then you mark the damper pulley with a white paint so you can make sure you have it on point
Jun 25, 2014 | 1992 Nissan Pathfinder
How do I adjust timing on a poulan pro snowblower
Factory Set, you can not truly adjust the Timing, most people find that the Carburator or Spark plug will fix 99% of everyone's problem
May 13, 2014 | Poulan Garden
Singer7462 timing adjustment
try these sites
Mar 04, 2012 | Singer 7462 Mechanical Sewing Machine
Cant adjust timing.
Why do you have to adjust the timing? And if you have to what kind of car or truck is it and the year perhaps engine size get alil specific for us!
Dec 21, 2011 | Cars & Trucks
Having problem setting distributor on timing
Hello Jc..the timing on the vortec engine is computer controlled. This is called static timing, & is done when the gears are installed. A timing light will not help on this. You can adjust the camshaft sensor, but a scanner needs to be connected to monitor the adjustments. I hope this helps.
Sep 23, 2011 | 1999 Chevrolet Silverado 1500
He time on my motorola shows 16:10. How do I correct The Time please?
Most Motorola phones have a feature of "auto-adjustment" for correcting time. If this feature is enabled then your phone will not show the option to set the time manually. In order to correct the time manually you need to disable the "auto adjustment" feature. After disabling this manual adjustment settings will automatically come.
Hope this will help....cheers:)
Oct 01, 2010 | Motorola Cell Phones
Carburator adjustments
Unfortunately, the two screws are not the problem. In fact, they very rarely require adjustment. Only when the engine is old and worn.
The problem is the timing, that is in need of adjustment.
You need to try and find the old screw settings, (if you can).
To adjust the timing, you can either adjust the gap, between the magneto, and the contact, or, the gap on the plug.
Good luck with that,
btw, don't forget to rate:)
Jul 28, 2009 | Garden
Rear brakes need ajustment on Buick Lesabre
I don't know if this works on a Buick but I have had two cars that the auto adjusters worked when you used the parking brake, I rarely use the parking brake so I got in the habit of working the parking brake 20 times or so at oil change time.
Apr 15, 2009 | 1998 Buick LeSabre
Adjusting date and time
According to Canon, the backup memory lithium battery (interal) recharges off the main AA batts that you put in... the manual says it takes about 4 hours to charge this battery.
When not in use, leave the AA batts in the camera .. see if this helps keep the date/time memory!
Jun 23, 2008 | Canon PowerShot A620 Digital Camera
Setting analog time
go to; and enter the module number code on the back of your watch - hopefully will tell you what you need to know. Hope this helps :)
Mar 13, 2007 | Casio AW80-1AV Wrist Watch
Motorola Mobility SLVR L7 Cellular Phone Logo
16 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
