Question about Cisco Flip Video MinoHD M3160 4 GB Camcorder
When I plugged into my computer USB port not turning on only a light comes on as if charging but then nothing?
How do I re charge battery with electrical plug
To charge the battery using your computer:
Connect iPod shuffle to a high-power USB port on your computer using the included iPod shuffle Dock. The computer must be turned on and not in sleep mode (some models of Macintosh can charge iPod shuffle while in sleep mode). When the battery is charging, the status light on iPod shuffle is orange. When the battery is fully charged, the status light turns green.
If you don't see the status light, iPod shuffle might not be connected to a high-power USB port. Try another USB port on your computer.
To charge the battery using an iPod USB Power Adapter If you do not have then you have to buy the same from Apple Store) 1 Connect the AC plug adapter to the power adapter (they might already be connected). 2 Plug the USB connector of the iPod shuffle Dock into the power adapter. 3 Plug the power adapter into a working electrical outlet. 4 Put iPod shuffle in the dock. You can disconnect and use iPod shuffle before it is fully charged.
Apr 05, 2011 | Apple iPod shuffle MP3 Player
When you plug the reader in to recharge is a red light supposed to come on until charged? How do you know when it is fully charged?
Yes, the red light should be turned ON after connecting the Reader to te Computer. That means the Reader is taking charge. After getting it fully charged, the red light will be turned ON. If those things will not happen to your reader, perform the below mentioned stepos::
1. Connect the Reader to a different USB port of the Computer. 2. Connect the Reader directly to the USB port of the Computer; dont use any USB hub or adaptor to connect the Readr to the Comp. 3. Disconnect the Reader and then press the RESET button. 4. Try connecting the Reader to a different Computer to check whether the USB port of the Computer is working properly. 5. If the issue still persists, service may be required. Follow the below link to initiate the repair: http://eservice.sony.com/
Feb 02, 2010 | Sony E-reader Portable E-book MP3 Player
Ipod won't turn on
It may be that the battery has drained to such a low level that it is only barely charged. What I would do is leave it for a couple of hours charging using the apple usb cable supplied (if you have still got it) and also if you are using a usb hub plug it directly in the computer usb port. Hope this helps, if not send me a comment.
Nov 05, 2009 | Apple iPod MA446LL/A MP3 Player
BLACKBERRY BOLD HAS NO POWER,WILL NOT TURN ON. THE ONLY SIGN OF POWER IS THE RED INDICATOR LIGHT TOP RIGHT....ON SOLID. CARRRIED OUT REBOOT TAKING OUT SIM AND BATTERY. ANY ADVICE WOULD BE APRECIATED.
I have the same problem with my Blackberry 8120, died this morning, will not switch on, no red light, no charging light, completely dead... my computer does not recognise the blackberry at all so cant install any new software.. plus I need to recover all the information that is on the handheld... please help if you can....
Oct 15, 2009 | RIM BlackBerry Bold 9000 Smartphone
I just received my Garmin for XMAS and it was working fine but now it just seemed to not charge. Then the little pic on the front shows the GPS connected to a computer desktop. HELP! Amber Fader
Does it turn on at all? Try to charge it on car adaper then, when it will turn on, try this.
The picture is displayed while it is charging through USB cable and you can't normally use GPS.
Turn the GPS on without the USB plugged in, then press the Battery symbol for about 10 seconds, until the test screen appears. Then plug in the USB.
Screen will tell you percentage of charge, and if it is charging.
***Make sure you press EXIT before unplugging the USB cable. Press EXIT, turn GPS off, then remove the cable is safest way
On the bottom you should see "USB type" if nothing is there, it may be the USB port on your computer. Try it again with a different port
Jun 12, 2009 | Garmin nuvi 255W GPS Receiver
Charging camera
Are you using the front usb ports on your computer? My computer's front usb ports were not able to charge my camera, but the rear usb ports were able to (the charging light should stay on if it's charging correctly). I'm not an expert on this stuff, so maybe there's a power output difference between your frontal and rear usb ports.
Also, on the CD there was a camera connection driver. You might try installing that and see if that makes a difference?
Sep 28, 2008 | Kodak Easyshare M753 Digital Camera
No charge...
Hello mandag78,
The error message you are talking about occurs when a device tries to draw more power from the USB port then the port can provide,
Make sure you are connecting the MP3 player directly to a USB port on the computer or a USB hub that has an independent power source (one that you plug into an electrical outlet). If you are plugging your MP3 player into a USB keyboard or a non-powered hub the port may not have enough ower to charge it.
I am assuming tha tthe Zen was working before? And that you are sing the exact same USB port and cord that you were using to charge the item previously? If so, then what you are experiencing might be a sign that the unit has failed and is in need of repair.
Best Regards,
Ken
"Go Ahead. Use Us."
Jun 24, 2008 | Creative Labs ZEN Vision:M Digital Media...
2 problems with my coby mp3 player
I have the same problem just bought the thing yesterday and it won't charge I downloaded music yesterday and charged it, now it isn't recognized by the computer.
Went thru the whole troubleshooting chart and nothing happened, I did email techsupport but haven't heard anything. I guess I'll take the thing back and get it replaced.
Jan 03, 2008 | Coby MP-C582 MP3 Player
Ilo mp3 player won't turn on
Ok, SOME MP3/4 Players indeed charge from the USB port, albeit slowly... usually tho there comes a charger that plugs into the "Mains" and then plugs into the USB socket on the Player.. Sometimes if the Battery goes really "Flat" the USB port is unable to supplu enough "Current" sucessfully charge it up. (Hence the need for wall charger) IF it was entirely Via USB it would take many hours, I would at least think overnite. Hope that hepls.
Jul 30, 2007 | iLO (2 GB) MP3 Player
Cisco Flip Video MinoHD M3160 4 GB Camcorder Logo
135 people viewed this question
Top Cisco Video Cameras Experts
Are you a Cisco Video Camera Expert? Answer questions, earn points and help others
