Question about Bosch Classixx WFC 2465 Front Load Washer
How can I remove in order to flush the waste pipe from a Bosch Classixx 1400 express
  • 228 Answers
SOURCE: when I select a cycle the -0- is displayed and the lock symbol.
YOU PROBABLY HAVE THE CHILD LOCK ACTIVATED GENERALLY HOLDING THE LOCK BUTTON IF THERE IS ONE OR THE START BUTTON FOR 5 SECS OR MORE WILL TURN IT OFF ALLOWING NORMAL USE
Posted on Sep 19, 2009
57 varieties
  • 1653 Answers
SOURCE: my bosch classixx 1400 express is not draining off
The error indicates that the machine has taken too long to drain the water. Do the following.
  1. Switch off the machine and disconnect the mains power.
  2. Remove the access panel on the lower right front of the machine.
  3. Remove the filter and make sure that the filter is not blocked and is clean and clear of all debris. Clean as required.
4. Proceed by checking the drain hose for proper connection and kinks and make sure that it is not blocked.
5. Also check that the main waste drain pipe, if you use one, is not blocked and clean if required.
6. Reconnect the power and switch the machine on.
If the problem persists then do the following.
7. Switch off the machine and disconnect the mains power.
8. Check the electrical connections at the pump and make sure it is operational.
9. Remove the connecting hoses, and expect water to drain out and make sure the pipes are not blocked with debris or any object blockage.
10. Makes sure the pump appears clear and that the impeller looks in good condition.
11. Reconnect the hoses and then reconnect power and switch the machine on.
12. If problem has not been corrected, then remove the pump and check that the drive coupling to the motor is OK and that the motor turns OK. If all is well then replace the pump.
Posted on Oct 23, 2009
  • 1382 Answers
SOURCE: door wont open on bosch classixx 6 1400 express washing machine
The "F16" on a Bosch indicates the door is open / unlocked. If it's happening during a wash it would suggest either a faulty door lock, faulty wiring or worse, a faulty main control board. The wash program should halt when this comes up but you should be able to restart it when the door is closed. As the cost of a new door interlock isn't overly expensive. The best way to fix this problem is to purchase a new lock and fit it.
Thank you !
Posted on May 19, 2010
  • 662 Answers
SOURCE: bosch classixx 1400 express key symbol
Power on, press the start button for 5 or 6 seconds, the sign will go off. Try the door gently.
Pl rate me 'very helpful' for the free help, thanks
Posted on Jun 14, 2010
  • 662 Answers
SOURCE: key symbol showing
I have bosch classixx 6 washing machine with F22 code flashing ?
How to reset Bosch Classixx 1400 Express
hi,couldn't find too much detail about the fault , may be faulty brushes an commutato......the abovel ink gives details and how to reset after f22 message
good luck
r
Jul 09, 2015 | Bosch Washing Machines
My bosch classixx 1400 express washing machine drain pump sometimes does'ent work
bosch classixx 1400 express washing machine drain pump This video will show you how to change the pump washing machine
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
Mar 13, 2013 | Bosch Washing Machines
Bosch classixx 1400 express manual
Go to:
https://portal.bsh-partner.com/portal%28bD1kZSZjPTAwOQ==%29/PORTALFRAME.HTM
This has all Bosch manuals.Bosch appliances have a unique E-NR (E Number) which will normally be found inside the door of the appliance. You will need this in order to download the correcy manual. Mine is WAE28162GB/03 for example.
Dec 15, 2010 | Washing Machines
I have a Bosch Classixx 6 1400 express washing machine which works fine but only splns very slowly,What can be the problem ?
Probably needs new brushes fitting in the motor, you will have to remove the motor to do this.
Dec 02, 2010 | Bosch Washing Machines
Got the Bosch Classixx 6 Express 1400 washing machine cant
Power on, press the start button for 5 or 6 seconds, the sign will go off. Try the door gently. Means the machine is locked, for children. I think if you do it again it locks.
Feb 22, 2010 | Bosch Classixx WFO 2466 Front Load Washer
Key symbol showing
Jan 06, 2010 | Bosch Classixx WFL 2066 Front Load Washer
My bosch classixx 1400 express is not draining off and has a lot of grey stuff on the clothes is this dirt
Oct 21, 2009 | Bosch Washing Machines
I can't undo the filter cap
i had same problem so removed the inlet pipe on the pump at the back of the filter and removed debri from back of filter [screws coins and a darning needle] because of this the design of the lid would not allow it to open.........
Mar 18, 2009 | Bosch Classixx WFL 2066 Front Load Washer
Bosch Classixx WFC 2465 Front Load Washer Logo
32 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
