Question about Samsung Prostar DCS-24B-STD Corded Phone
How can I reprogram the phone so I can check voicemail?
I can no longer check voicemail on the phone
How can I get my nokia 206 asha on sainsburys mobile to ring for longer before going to voicemail?
call like you are checking your voicemail, there are sometimes options with your carrier to adjust as you check voicemail.
Jul 31, 2014 | Nokia Asha 206 Dual Sim GSM Unloced With...
I have ZTE MUVEAfter programming my voicemail and follow the instruction, every time i try to access to my voicemail it brought me to the direcction to reprograming voicemail again.
I am guessing you do have a voice mail subscription and if I am right, the issue could be with 'zte'. Not the best phone out there.
Apr 08, 2014 | ZTE Score
Nortel t7100 voicemail
have your in-office phone tech fix it or reprogram it for you..
Jan 07, 2014 | Lands Phones
When i select my programmed check voicemail button i get an error of "not in service". how do i fix this and re-establish it as the check voicemail shortcut?
Try Feature *3 - press the button you had programmed of check voice mail - the press Feature 981. This should reprogram your button.
Aug 20, 2013 | NorStar T7316E Corded Phone
When we press feature 981 the message reads inactive feature. what can we do to fix this issue
That means that the voicemail system is no longer recognized by the phone system. Check the lights on the voicemail to see if its still receiving power.If so try unplugging and plugging the voicemail to reboot it. The voicemail can take up to 6 minutes to totally reboot.
Sep 13, 2010 | NorStar Startalk Flash 2 Phone
Avaya Partner System. 18D Phone. Suddenly, I get a beep when an incoming call hits the system. No idea why it started. How do I get rid of it?
Is the time and date correct on your phones?
Usually this means that the system has lost programming, and when a call rings in, the voicemail picks up. The system will need to be reprogrammed from scratch. The voicemail boxes and messages will still be there, but the phon system doesnt know where the voicemail is until its programmed.
Dec 15, 2009 | Avaya Corded Phone avaparp18d
How can I reprogram my voicemail speed dial in spot 1? Right now it's set to go to ''youmail's'' voicemail and I want it to got to ATT voicemail. I have a Samsung BlackJack 2
the way it is it cannot be reprogrammed because its in the hardware of the phone and cannont be changed sorry hope this was helpful:)
Sep 13, 2009 | Samsung BlackJack II Smartphone
Phone won't go to voicemail before 10 rings
You have to reprogram this locals cfw no.# of ring .
Go into progaming set type in local step to cfw and # of rings
Mar 12, 2009 | NorStar M7310 Corded Phone
Voice message, reprogramming extensions
How did you program the voicemail so a caller can not leave a voicemail to a particular extension? Line ownership? SO a call goes directly to a milbox?
How can you reprogram the voice message????? Which one, for a particular user or the main Auto attendant greeting????
You have to know the admin login to change a mailbox password.
For that, you need to know which voicemail system this is.
When you log in to check your mail, the lady says, "welcome to Partner......"
Please fill in the blanks.
Nov 18, 2008 | Avaya Lucent Partner 616 Phone
Resetting the voicemail
Can you please clarify so I can better answer your question?
Sep 23, 2008 | Toshiba DKT-2020 Corded Phone
Samsung Prostar DCS-24B-STD Corded Phone Logo
26 people viewed this question
Top Samsung Lands Phones Experts
Jose Ma DM.
Jose Ma DM.
imfedup19
Level 1 Expert
Are you a Samsung Lands Phone Expert? Answer questions, earn points and help others
