Question about Hoover Washing Machines
Hoover washing machine VHD 8122 - Hoover Washing Machines
  • 249 Answers
SOURCE: My friend has a washing
Yes he could find it on the net
Posted on Dec 06, 2008
  • 155 Answers
SOURCE: My hoover washer dryer VHD is showing a fault E11
It means there is a problem with the dryer board on it.You can try removing
the lid and just check the dryer control board on it.Make sure the
connections are ok and that none of the wires are broken.Then if the wires are ok the dryer control board will need to be replaced.
Posted on Apr 10, 2010
blueextc3221
  • 15935 Answers
SOURCE: replace paddle/agitator on Hoover VHD 812 Washing machine
The following advice is for replacing the "Agitator Dogs" on Kenmore and Whirlpool TOP LOADER style washing machines. This simple repair can save you a fortune in repair costs as the replacement parts are very inexpensive at a cost of less than $10. The replacement kit part number is 80040. You can order on line at various appliance parts websites, or use this part number and go to your nearest appliance parts retailer.
What are "Agitator Dogs"? These are small plastic pieces (usually 4) that are located under the agitator center cap that grip the agitator and turn it during the wash cycle. They can (and do) wear out dependent upon the use of the washer. If you are in the habit of doing large load sizes frequently, or wash large items such blankets or afghans, this can wear the teeth off and reduce the life of the agitator dogs.
SYMPTOMS REQURING REPLACEMENT: The agitator fails to turn during the wash cycle, or will not turn with a heavy load. The timer will run normally through all cycles, and you will be able to hear the gearcase (transmission) engage and run. The washer will also drain normally. The only indication that something is wrong will be the agitator slipping or not turning at all. The result will be clothes that do not wash properly and will sit on the bottom of the wash tub.
To replace the Agitator Dogs, follow these steps:
1.Remove the agitator center cap by either pulling straight up or gently placing a flat blade screwdriver into a slot located in the cap.
2.If the agitator is equipped with an inner cap with a handle, remove this as well by pulling straight up.
3.Remove the center bolt of the agitator. You will have either a 7/16" hex bolt or a recessed square plastic nut. If you have the square recessed type, use a 3/8" to ½" ratchet adapter to remove.
4.Remove the agitator by grasping the bottom flange and carefully pulling straight up. Try to keep all the parts assembled while doing this, so do not pull too hard. This will make this repair much easier.
5.Place your hand over the top of the agitator and separate the upper portion of the agitator from the lower portion and turn the top half over in your hand. The agitator dog assembly will come out in your hand.
6.With the agitator dog assembly in your hand, lay the rest of the agitator aside. Pay careful attention to how the dogs are installed. Remove the worn dogs and reinstall new ones. It's that simple.
7.With all the dogs replaced and the assembly still in your hand, place the upper part of the agitator over the top of it, upside down, ensuring the inner assembly tabs align correctly.
8.Now keep your hand over the agitator top to hold all the pieces together and turn the entire assembly over (upright position).
9.Carefully align and reinsert the upper portion of the agitator to the lower portion. Again, making sure the two pieces align correctly.
10.Place the entire agitator assembly back on the gearcase shaft and reinstall center nut. NOTE: DO NOT over tighten the nut, or the agitator will not spin correctly. Just make the nut snug. Reinstall center cap and inner cap (if equipped).
These instructions should give you the basics on how to perform this repair. Since there are various agitator types in use by Whirlpool and Kenmore, assembly can vary.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 14, 2010
vinceisaac
  • 2432 Answers
SOURCE: Hi I have a hoover vhd 9143 zd washing machine which went 'pop' today. Now it doesn't work and the red digital display does not work properly? Any suggestions?
unplug the unit then remove the cover and look for the circuit board which get wet.or a wiring that get loose connection.
Posted on Oct 16, 2012
raza504
  • 3 Answers
SOURCE: hoover 800 f1 Will not wash
join And Earn http://www.neobux.com/?r=ahmedraza504
Posted on Mar 21, 2013
Hoover VHD sensor Dry shows Eo8 vibrate badly and stops any suggestions please regards Peter
http://www.ukwhitegoods.co.uk/help/fix-it-yourself/specific-faults/3070-hoover-vision-hd-washing-machine-fault-codes.pdf
Mar 09, 2015 | Hoover Washing Machines
I have a Hoover Vision HD 9 kg washing machine, type VHD 916Z. I does not spin when there are clothes in the machine, it just starts the spin then "gives up" after 0.5 to 1 second. When there are no...
Double check the waste pump on the inbound side, which could be the cause of a wrong feedback to the pressure sensor switch. The filter can be clean, but the collector from the basket to the pump can be obstructed.
Jan 26, 2015 | Hoover Washing Machines
Hoover vision hd
the bearing are gone
Jan 18, 2014 | Washing Machines
My Hoover VHD 1400 aaa has the front concrete weight off
This weight helps to balance the machine. needs to be put back on or replaced. Machine will not operate properly without it.
Mar 28, 2011 | Hoover Washing Machines
VHD 814 Hoover Vision HD wash stops and timer saver light flashes. Does not wash properly and have to select spin manually. Any answers?
this happens with mine too....
Any solution would be very welcome. The machine seems to have a mind of it's own.
Dec 21, 2010 | Hoover H160E Front Load Washer
Hoover visionHD vhd 842-80 will not complete its cycle (does not spin) lights flashing are 1200 &time saver button
Mine done the exact same thing and it was the bushes that went not the pump, so you can change them your self if you can
Nov 07, 2010 | Hoover Washing Machines
Hoover VHD Washing machine
Surely it is the wall socket.
Mar 19, 2008 | Washing Machines
Washing Machines Logo
21 people viewed this question
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
