Sanwa yx360trf schematic diagram free
How to repair resistance setting?
  • 641 Answers
Posted on May 13, 2014
2 Suggested Answers
SOURCE: do you have schematic diagram
schema yx360trf
Posted on Sep 04, 2011
Elliptical resistance
please follow this steps and fix it. Merry Christmas
·2
Be aware that the resistance is often the part that requires repair. Resistance is managed magnetically, so often if the machine is working, but the resistance isn't setting correctly or at all, check the bolts that secure the magnets. If they are loose, the resistance will slip. If the bolts are fine, check the magnets themselves by using a refrigerator magnet and see if it is attracted or repelled by the your fridge magnet. If not, the magnets have de-magnetized and need to be replaced.
Dec 17, 2013 | Exercise & Fitness
God bless you
May 22, 2013 | Xterra Fitness Xterra FS220e Elliptical...
Resistance too high
Feb 18, 2013 | Life Fitness X3 Elliptical with TRACK...
To much resistance
please see the comments and proceeds for fix it. God bless you
Dec 18, 2012 | Schwinn 140 Upright Bike
My Proform 100 ZLX Exercycle is stuck in low/zero pedal resistance, and doesn't respond to console settings. Can this be economically fixed?
follow the steps, and fix it. God bless you
Dec 05, 2012 | Exercise & Fitness
My schwinn 460 elliptical resistance cannot be changed
see the following details. God bless you
Dec 04, 2012 | Schwinn 460 Variable Stride Elliptical...
Cruise control not working
This is probably all the diagnostics you need.
SET SWITCH
Check Continuity Between the O/V Terminal (F) and BE/BK Terminal (B) of Connector [17B]. Resistance Must Be InfinityOhms. Pressing SET/RESUME Switch to SET Should Produce a Reading of Less Than 0.5 Ohms. Are These Your Observations?
YES: STOP - Go to Test 7.4 (Part 2 of 2)
NO: FLHRC-I
Remove the Headlamp Assembly. Disconnect 6-Place Connector [22] and 4-Place Connector [159]. Measure Resistance Between O/W Wire on Connector [22B] and BE/BK Wire on Connector [159B]. Resistance Must Be Infinity Ohms. Pressing SET/RESUME Switch to SET Should Produce
YES: Locate and Repair Open on BE/BK Wire in Main Harness.
NO: Right Handlebar Switch Wiring Pinched or Damaged?
YES: Repair Wiring.
NO: Replace Cruise SET/RESUME Switch.
May 31, 2012 | 2003 Harley Davidson FLHRCI Road King...
2003 Durango, Truck 5.9, Car is intermittently having trouble shifting from 1 - 2nd - reves to ~3 RPM, then lunges into the next gear. I've been doing my homework on the net, but can only find info on...
Possible Cause
The following items may be area of concern:
?¬Other transmission-related DTCs are set.
?¬Solenoid pack connector 5-volt supply circuit open.
?¬Sensor signal circuit has short to ground, short to voltage or open.
?¬Governor pressure sensor defective.
?¬Transmission fluid burnt or oil pan contains excessive debris.
?¬Governor pressure out of range.
?¬Transmission leaking internally.
?¬Defective PCM.
?¬Defective valve body.
Diagnostic Procedure
1.Using scan tool, read DTCs. If good trip counter for DTC P1756 is not displayed or displayed count is not zero, go to step 25. If good trip counter is displayed and displayed count is zero, go to next step.
2.Repair any other transmission-related DTCs before proceeding. If no other transmission-related DTCs exist, go to next step.
3.Check transmission fluid for proper level and for any debris. Fill or repair transmission as necessary. If fluid level and condition are okay, go to next step.
4.Start engine. Allow engine to reach normal operating temperature. Set parking brake, depress brake pedal and place gearshift lever in "D" position. Using scan tool, observe governor pressure sensor pressure. If pressure is greater than 3 psi (.2 kg/cm 2 ), go to next step. If pressure is 3 psi (.2 kg/cm 2 ) or less, go to step 20.
5.Turn ignition off. Install a pressure gauge at transmission governor pressure test port. Start engine. With gearshift lever in "D" position, observe gauge pressure. If pressure is 5 psi (.3 kg/cm 2 ) or more, go to step 23. If pressure is less than 5 psi (.3 kg/cm 2 ), go to next step.
6.Turn ignition off. Disconnect transmission solenoid assembly connector. Turn ignition on. Measure voltage between ground and 5-volt supply circuit at transmission solenoid harness connector terminal No. 2. If voltage is 4.5-5.5 volts, go to next step. If voltage is not 4.5-5.5 volts, go to step 19.
7.Turn ignition off. Disconnect PCM harness connector C2 (White). Measure resistance of governor pressure sensor signal circuit between transmission solenoid harness connector terminal No. 4 and PCM harness connector C2 (White) terminal No. 29. If resistance is less than 5 ohms, go to next step. If resistance is 5 ohms or more, repair governor pressure sensor signal circuit for open.
8.Disconnect PCM harness connector C1 (Black). Measure resistance of sensor ground circuit between transmission solenoid harness connector terminal No. 3 and PCM harness connector C1 (Black) terminal No. 4. If resistance is less than 5 ohms, go to next step. If resistance is 5 ohms or more, repair sensor ground circuit for open.
9.Measure resistance of governor pressure sensor signal circuit between ground and transmission solenoid harness connector terminal No. 4. If resistance is less than 5 ohms, repair signal circuit for short to ground. If resistance is 5 ohms or more, go to next step.
10.Measure resistance between sensor signal circuit and sensor ground circuit at transmission solenoid harness connector terminals No. 3 and 4. If resistance is less than 5 ohms, repair governor pressure sensor circuit for short to sensor ground circuit. If resistance is 5 ohms or more, go to next step.
11.Turn ignition on. Measure voltage of governor pressure sensor signal circuit between ground and transmission solenoid assembly connector terminal No. 4. If voltage is one volt or less, go to next step. If voltage is more than one volt, repair sensor signal circuit for short to voltage.
12.Turn ignition off. Ensure transmission solenoid harness connector is disconnected. Remove transmission oil pan. Disconnect governor pressure/temperature sensor harness connector. Inspect connector and terminals for damage. Repair as necessary. Measure resistance of governor pressure sensor 5-volt supply circuit between governor pressure/temperature sensor harness connector terminal "A" and transmission solenoid harness connector terminal No. 2. If resistance is less than 5 ohms, go to next step. If resistance is 5 ohms or more, replace transmission solenoid assembly (internal transmission harness).
13.Measure resistance of sensor ground circuit between governor pressure/temperature sensor harness connector terminal "D" and transmission solenoid harness connector terminal No. 3. If resistance is less than 5 ohms, go to next step. If resistance is 5 ohms or more, replace transmission solenoid assembly (internal transmission harness).
14.Measure resistance of governor pressure sensor signal circuit between governor pressure/temperature sensor harness connector terminal "B" and transmission solenoid harness connector terminal No. 4. If resistance is less than 5 ohms, go to next step. If resistance is 5 ohms or more, replace transmission solenoid assembly (internal transmission harness).
15.Measure resistance of governor pressure sensor signal circuit between ground and governor pressure/temperature sensor harness connector terminal "B". If resistance is less than 5 ohms, replace transmission solenoid assembly (internal transmission harness). If resistance is 5 ohms or more, go to next step.
16.Measure resistance between governor pressure sensor signal circuit and sensor ground circuit at governor pressure/temperature sensor harness connector terminals "B" and "D". If resistance is less than 5 ohms, replace transmission solenoid assembly (internal transmission harness). If resistance is 5 ohms or more, go to next step.
17.Reconnect transmission solenoid assembly harness connector. Turn ignition on. Measure voltage of governor pressure sensor signal circuit between ground and governor pressure/temperature sensor harness connector terminal "B". If voltage is more than one volt, replace transmission solenoid assembly (internal transmission harness). If voltage is one volt or less, go to next step.
18.Turn ignition off. Using DVOM, backprobe governor pressure sensor signal circuit at PCM harness connector C2 (White) terminal No. 29. Start and idle engine. Place gearshift lever in "N" position. Using scan tool, observe governor pressure sensor voltage. Compare scan tool value with DVOM voltage. If voltages match, replace governor pressure/temperature sensor. If voltages do not match, replace PCM.
19.Turn ignition off. Ensure transmission solenoid harness connector is disconnected. Disconnect PCM harness connector C2 (White). Measure resistance of 5-volt supply circuit between transmission solenoid harness connector terminal No. 2 and PCM harness connector C2 (White) terminal No. 31. If resistance is less than 5 ohms, replace PCM. If resistance is 5 ohms or more, repair 5-volt supply circuit for open.
NOTE: Removing transmission control relay in the following step may set other DTCs. Disregard these DTCs.
Nov 28, 2010 | 2003 Dodge Durango
IT IS NOT WORKING
Run this diagnostic
Test Procedures
1. Check if DTC P0110 is set in addition to DTC P0105 or P0106. If DTC P0110 is set, go to next
step. If DTC P0110 is not set, go to step 3 .
2. Turn ignition off. Disconnect MAP sensor 4-pin connector. Measure resistance between ground
and MAP sensor connector terminal No. 4 (Green wire). If resistance is one ohm or less, replace
MAP sensor. If resistance is more than one ohm, repair open in Green wire between MAP sensor
and ECM connector terminal No. 48. After repairs, clear DTC and verify MAP sensor operation.
3. Turn ignition off. Disconnect MAP sensor 4-pin connector. Measure resistance between MAP
sensor connector terminals No. 1 and 4 (component side). Resistance should be about 30,000
ohms. If resistance is as specified, go to next step. If resistance is not as specified, replace MAP
sensor. After repairs, clear DTC and verify MAP sensor operation.
4. Turn ignition on. Measure voltage between ground and MAP sensor connector terminal No. 2
(Red wire). Voltage should be about 5 volts. If voltage is as specified, go to next step. If voltage is
not as specified, repair open in Red wire between ECM connector terminal no. 44 and MAP
sensor connector terminal No. 2. After repairs, clear DTC and verify MAP sensor operation.
5. Turn ignition off. Disconnect ECM 63-pin connector. Check for continuity between ground and
MAP sensor connector terminal No. 1 (Green wire). If continuity does not exist, go to next step. If
continuity exists, repair short to ground in Green wire between MAP sensor and ECM. After
6. Reconnect MAP sensor connector and ECM connector. Turn ignition on. Backprobe MAP sensor
connector and measure voltage between ground and MAP sensor connector terminal No. 1 (Green
wire). Voltage should be 0.2-4.5 volts. If voltage is as specified, go to next step. If voltage is not
as specified, replace MAP sensor. After repairs, clear DTC and verify MAP sensor operation.
7. Check ECM connector for loose or damaged terminals. If problem exists, repair ECM connector.
If problem does not exist, replace MAP. Clear DTC and verify system operation. If problem still
exists, replace ECM. After repairs, clear DTC and verify system operation.
Good luck and hope this helps. If the car does not start diconnect the MAP sensor to get you to the parts store if you need it to get you there.
May 25, 2009 | 2001 Hyundai Elantra
- will not idle at proper setting, stalls when put into gear
Check for vacuum leaks and test the idle air conrtol valve.
0900c1528006c55b-lxsvs4ftyjtcqsaualeaxmu4-4-0.gif TESTING
See Figure 2
  1. Disengage the IAC electrical connector.
  2. Using an ohmmeter, measure the resistance between IAC terminals A and B. Next measure the resistance between terminals C and D.
  3. Verify that the resistance between both sets of IAC terminals is 20-80 ohms. If the resistance is not as specified, the IAC may be faulty.
  4. Measure the resistance between IAC terminals B and C. Next measure the resistance between terminals A and D.
  5. Verify that the resistance between both sets of IAC terminals is infinite. If the resistance is not infinite, the IAC may be faulty.
  6. Also, with a small mirror, inspect IAC air inlet passage and pintle for debris. Clean as necessary, as this can cause IAC malfunction.
Do It Yourself Diagnosis and Repair
Sep 02, 2017 | 1987 GMC VanDura
Televison & Video Logo
282 people viewed this question
Top Televison & Video Experts
Electro Med Services...
