Question about Mtd Garden
MY briggs engine will start when choke is on but shuts down when you take the choke off
Put in new spark plug it will start when the choke is engaged but shuts off when you dis-engage choke
    Top Expert:
  • Mtd Master
  • 51,484 Answers
Needs the carburetor cleaned possibly
Posted on Feb 01, 2016
extroitive
  • 35 Answers
SOURCE: briggs & stratton 3 hp engine will not start
likely needs a carb kit
Posted on Apr 19, 2009
  • 246 Answers
SOURCE: mower will only run if choke is on
Hello cmsbss:
>>From your Description it Sounds like the Carburetor requires Soaking and Cleaning.
>>The Following is a Basic File I Made for Cleaning Carburetors. Any Input is Appreciated. Even though the Carburetor Looks Clean, the Internal Passages May be Restricted with Varnish that Gas Causes to Build Up over Time.
>>Spray Cleaners Remove this Varnish in Layers, so Soaking is the Only Sure Way to Remove ALL this Varnish.
>>I Suggest you Make Sure the Gas is Free Flowing to the Carburetor Inlet Port (if the Model does Not have a Fuel Pump). If the Gas is Free Flowing to the Inlet Port, then
>>**Remove, Disassemble and Soak the Carburetor Overnight in Carburetor Cleaner (I Use Gunk).
>>The Primer Bulb is Held in Place with a Locking Collar at the Base of the Primer Bulb. Use a Small Flat Screw Driver and Carefully Pry the Lock Ring Up in Small Amounts All Around the Lock Ring until the Lock Ring and Primer Bulb can be Removed from the Carburetor Body. Usually a New Primer Bulb is Required when you have to Soak the Carburetor. The Rubber is Usually Rotted to Much for the Primer to be Reused.
>>Your Primer Bulb May Differ Slightly, but Removal is Usually Almost the Same Except for the Primer Bulbs that are Bolted to the Carburetor. These are Simply Unbolted and Changed with the new Primer Bulb.
>>I have Found that Most People can Use a Breakdown/IPL and Disassemble the Carburetor Enough for Proper Cleaning.
>>You Only have to Remove the Bowl (if Applicable), Float Pin (if Applicable), Float (if Applicable), Needle Valve and Needle Valve Seat if Applicable. This is a Flat O-Ring Located in the Inlet Port the Float Needle Rests in. Use a Strong Wire with a Slight Bend to Remove the Old Seat. Sometimes a Small Pocket Screw Driver can be Use Also.
>>The New Seat will have a Slightly Beveled Side and a Flat Side. The Flat Side goes Towards the Carburetor Body when Inserted into the Inlet Port. Spray the Seat with Spray Lubricant to make Installation Easier. The End of a Drill Bit that is Slightly Small than the Seat can be Use as an Insertion Tool.
>>Wear Gloves or Use a Rag when Handling the Sharpened End of the Drill Bit. Remove Any Adjustment Screws that Go Into the Carburetor Body. The Welch Plugs Do Not have to be Removed.
>>If you are Able to Remove and Disassemble the Carburetor and Keep the Gaskets Intact, then Usually these Gaskets can be Reused. Even the O-Ring Around the Bowl can be Reused if it is Not Broken. The Only Parts you May Need to Replace is the Float Needle Valve (and Seat if Applicable).
>>The Float Needle Usually is Not Replaced Unless it is Not Operating Properly (the gas flow not shutting off and the carburetor is Flooding). Do Not Remove the Main Nozzle. This is a Pressed Fit and Removal is Not Required for Cleaning. Soaking and Blowing the Carburetor Out After Soaking will Clean the Nozzle.
>>Once Disassembled, then Soak the Carburetor Body and Parts in a 1 Gallon Can of Gunk Carburetor Cleaner Overnight. The Can has a Parts Tray Inside it for the Small Parts.
>>Once the Carburetor and Parts are in the Cleaner, you can Replace the Lid for Safety and to Prevent Accidental Spillage. Then Blow Out the Passages with Compressed Air.
>>***(Do Not Use High Pressure Air for the Zama Carburetors, they have Check Valves for the Primer and these are Usually Blown Out of the Carburetor if Not Careful. Allow the Zama Carburetor to Set on a Drip Pan and Dry)***.
>>****All the Carburetor Adjustments are the Same for Lawn Mower and Trimmers. There are Several Location for the Air Mixture Screws. The Idle Air Mixture Screws are Usually Located at the Top of the Carburetor Bowl and the Top of the Carburetor Body.****
>>If the Main Air and Idle Air Mixture Screws are Side by Side on the Side of the Carburetor, then the Idle Air is Nearest the Engine. The Main Jet Air Mixture Screw is Located in the Bottom of the Carburetor Bowl or Beside the Idle Air Screw on the Side of the Carburetor Body.
>>Some of the Older Model Carburetors have the Main Jet Mixture Screw Straight in from the Top of the Carburetor Body (this is Rare anymore). If you have Cleaned the Carburetor (Disassembled and Soaked Overnight in Carburetor Cleaner (I Use Gunk). Then Blow Out the Passages with Compressed Air and Install a New Kit if Required. Now Setting the Air Mixture Screws:
>>****Turn the Idle Air and Main Air Mixture Screws In Until SNUG **Do Not Jam** Then Reverse Both Screws 1 1/2 Turns. Holding the Throttle Full Open, Start the Engine. Turn the Main Air Mixture Screw Clockwise Until Proper Revs are Obtained. Occasionally you May have to Turn this Counter Clockwise to Achieve the Proper Revs. Now Allow the Engine to Idle. Set the Engine Idle Screw (Not Idle Air) so the Engine will Stay Running if Required. Now Set the Idle Air Mixture Screw so there is No Hesitation when Throttling from Idle to Full Throttle. Reset the Engine Idle if Required.****
>>If This Carburetor has a Single Air Adjustment (Except Tank Mounted 9200 and 100900 Engine Model Carburetors), Use the Section Above that Pertains to Full Throttle RPM Air Mixture Screw and then Adjust the Screw if Required to Eliminate Any Hesitation when Throttling from Idle to Full Throttle.
>>For the 9200 Model Tank Mounted Carburetor Adjust the Air Mixture Screw Full In, then Reverse 1 1/2 Turns. Set the Throttle Lever to Full Throttle and Start the Engine.
>>Now Carefully Use 1 Finger and Open the Throttle Plate and Over Rev the Engine Slightly. If the Engine Over Revs and Does Not Struggle to Over Rev, then the Carburetor is Set. If the Engine Struggles to Over Rev, then Turn the Adjustment Screw In 1/4 Turn and Repeat the Over Rev Test.
>>If you Adjust to 1/2 Turns In and the Engine Still Struggles to Over Rev, then Return the Adjustment Screw to 1 1/2 Turns Out from Snug and Turn the Screw Out 1/4 Turn. Do the Over Rev Test. Continue this Process Until you have the Engine Over Revving without Struggle.
>>By Adjusting the Carburetor on this Style Carburetor Until the Engine Over Revs without Struggle, you have Adjusted the Air Mixture to the Best Possible Setting.
>>This file was Intended to Give you the Basic Carburetor Cleaning Instructions and May Not Reflect Your Carburetor Components.
>>If you have Questions, Please Ask. The links above Provide Good Directions on Cleaning the Carburetor. Make sure you use an Compressed Air to Blow through all the Carburetor Passages to make sure they are Clear.
>>1- http://www.repairfaq.org/samnew/lmfaq/lmclctc.htm
>>2- http://www.cpdonline.com/692509.pdf .
>>If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance. Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Happy.
>>Thanks.
Respectfully
John
Posted on Apr 21, 2009
jmkaep
SOURCE: engine won't start
Download the manual here:
http://www.briggsandstratton.com/maint_repair/manual_and_more/docsearch.aspx?enginelookfor=135292-0180-01
Follow instructions.
Posted on Apr 25, 2009
  • 45 Answers
SOURCE: Ryobi Model 65020 gas tiller dies when engaging the throttle
sounds like you need to adjust the carburator
Posted on Apr 29, 2009
  • 133 Answers
SOURCE: rotavator engine (briggs stratton 5hp) cuts out under load
Try a new governor spring.
Posted on Aug 09, 2009
My briggs and stratton engine throttle cable and throttle body wont engage,always wide open
Are you sure it's not a new style Briggs that uses the 'throttle cable' just as a shut off? Many new mowers on;y start and run at High Speed
Jul 05, 2013 | Briggs & Stratton Garden
I have gas in my oil and gas is pouring out the spark plug hole wats the cause of this?? sears crafsman lt 1000 briggs and straton intek,18 hp needle valve in carb seems ok,fuel solenoid working wat...
Gas in the spark plug chamber should mean it is flooded.trying to start it for too much time with the choke on will do this.when starting cold,engage choke.turn engine over till it tries to start.if you can't disengage the choke before it stalls,do not re-engage the choke.just keep turning the engine over,or pull starting,whichever you have,until the unit starts.it will.for now,if the sp.plg.hole has fuel in it,blast compressed air to clear it somewhat,re-install sp.plug,never overtightening,just snug,and try starting without the choke.hope this is useful.bart.i am a certified small engine mech.and remember when finished,let unit idle for 2 min. Or so and cool before shutting off.change oil religously every 50hrs.for units over 10hp.,every 25 hours for engines below that.they will last a long time.clean air filter after every two or three uses.never empty fuel when storing,use STA-BIL.
Sep 23, 2011 | Garden
Riding mower briggs and stratton engine will start and only run with the choke on and shuts off when i release the brake
hello jw. chances are that you have junk in your carburator. since it will run on choke do the following:
1. new fuel filter.
2. new air filter.
3. new spark plug.
4. get a can of starter fluid and a helper. remove the air filter and spray some starter fluid into the air cleaner area as it is running. do this for a minute and then see if it will run with the choke off. if not, repeat. J.
May 15, 2011 | Garden
John deere 135s won't start briggs and stratton 22 hp engine it is getting spark and fuel and I just put new plugs in because the looked fouled.
There are four reasons for fouled spark plugs, 1, You have a resticted air flow ( dirty air filter, or partially engaged choke), so the mixture is rich all the time fouling tghe plugs. 2, You have a poor quality fuel ( old, stale ), and it wont combust/burn hot enough, then fouling the plugs. 3, You might have a piston ring failure causing engine oil to be left on the cylinder wall instead of being wiped back down, and then burning as part of the combustion process. Thus burning and causingg a rich condition again, and fouling the plugs. Then finally number 4, low engine compression. This is again caused by worn cylinder walls and worn piston rings, causing compressed air/fuel mixture to leak past the rings into the crankcase, and when the fuel/air mixture is compressed then ignited, some of the air needed to ignite the fuel has escaped, and thus a rich condition again, fouling the plugs.
Determining which of the Four are causing you fouling is your next step.
Hope this helps
Nov 12, 2010 | John Deere 420,1020,2010,2020,2510,2520...
Briggs and stratton runs good for 5 minutes then starts to smoke
My first thought is that the throttle lever is being pushed so far forward ( max RPM's ) that you are running the engine 1/2 or better choked
Look at the choke butterfly with the throttle in your normal run position it should be completely open
This may require and adjustment in the control rods or might be as simple as not pushing the throttle wide open
Apr 06, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Replaced stop switch and it still won't shut off!
While attending college, I worked at a tool rental center and learned many tips and tricks from the mechanics. The problem that we heard the most from customers was that the machine would not start. Your your machine at least starts and runs fine, however will not shut down with the factory kill switch. Many times when replacing the mag. (spark coil) the kill wire would rub against the flywheel and break or over time the conductor wire will break inside the insulation. If you kill switch only has one wire, then all the kill switch does is short the mag to ground. Simple test is to remove spark plug, re-connect wire to plug, touch plug to engine and pull rope to observe spark, then short the tab on the magnito to ground, should be no spark. If you still have spark, coil is defective however good enough to run engine. Kill with choke or pull wire. If no spark with test, make new wire from tab of coil to kill switch or any switch that will short tab to ground. Good Luck
Jan 03, 2009 | Briggs Garden
Will not start, briggs & stratton 3.75
put a small amount of gas in carb from top and try it. if still not starting make shure choke is in closed position . check the safty switch handle . you do have spark/ and gas
Oct 19, 2008 | Garden
Garden Logo
144 people viewed this question
Top Mtd Garden Experts
Jim Parker
Jim Parker
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
