Question about Xerox Office Equipment & Supplies
Replace fuser xerox 7220 - Xerox Office Equipment & Supplies
2 Suggested Answers
  • 2072 Answers
SOURCE: Fuser Assembly for Xerox Copier 5309 PN 126K3410
Right here
https://www.partsdrop.com/store/
Use that link, ask for Britt, he will fix you up. Tell him Rick said Hi. Haven't talked with them for a while..
Posted on Jun 13, 2008
How to clear error 10-333 on xerox 7132 all in one
That error signifies a fuser problem where the thermistor does not detect the fuser coming to temperature. Need to replace fuser unit, part number 008R13022, see link.
http://www.iteminconline.com/008r13022_008r13022-xerox-workcentre-7132-fuser-110-volt.htm?source=froogle&gclid=Cj0KEQjw8u23BRCg6YnzmJmPqYgBEiQALf_XzZg4C5Qd7jYhL14rJSJWIPdkZdVrtP4kPg2RlOQFweIaAnzV8P8HAQ
Apr 26, 2015 | Xerox Office Equipment & Supplies
7120 copier. Why is there a recurrent 'replace fuser' message?
The fuser's page count has been depleted. At 100K prints the machine declares the Replace Fuser message because it is almost worn out.
May 11, 2012 | Xerox Office Equipment & Supplies
Xerox 3050 fuser replacement
Assuming you are talking about the Xerox 3030/3050 wide format printer, you don't replace the fuser, only the individual components eg. fuser roll
Error U4-1000 (Xerox CopyCentre C116 copier)
U4-1000 Indicates Fuser on time failure
Follow these steps:
1. Check for paper on the fuser.
Y remove paper N proceed to step 2
2. Check the installation of the fuser assembly, make sure it is securely installed.
Y reinstall fuser N proceed to step 3
3. Remove the fuser. Check the conductivity of the contact points of the thermostat, are the contact points connected
N replace the fuser
Apr 12, 2011 | Xerox CopyCentre C118 Copier
Xerox work centre 4150 screen states faulty fuser module. Can't seem to find part...Help
That is in fact a bad fuser which must be replaced (part# 126N00321 for 110v). Replacing it is simple, open the right door and remove the 4 screws that hold in the fuser. Make sure the machine has been off for awhile because the fuser my be hot. Here is a video that shows you how. Hope it helps, and thanks for using fixya
Dec 20, 2010 | Xerox WorkCenter 4150 Black and White...
Xerox 5225 fault code 010-320???
If you have a Xerox WC5225 with Error Code 010-320, then you have a fuser problem. The fuser is the heated item which bonds the image, just before it exits the unit. The machine monitors the temperature sensors and heating elements on this part.
The fuser is sold as PN 126K24980. It is easy to replace yourself.
Nov 23, 2010 | Xerox DocuColor 3535 Copier
Brother MFC-7220, paper coming out like a Fan. All creased or not coming out at all and jamming at the back. Any ideas....
your fuser has gon bad or something is blocking the paper path. Open the back and look close for any objects. If nothing there you need a new fuser. Steven 805-520-3003
Jul 08, 2010 | Brother MFC-7220 All-In-One Laser Printer
Xerox 6250 will not warm up. it says
Yes it can be the used fuser. Kind of odd for it to be anything else but the fuser.
Jan 25, 2010 | Xerox Phaser 6250 Laser Printer
How can I reset the Xerox Phaser 3100MFP fuser?
A hardware module is used to reset Xerox Phaser 3100 which work as permanent solution. After that you can refill unlimited number of times without any problem. www.nakshatraworld.com, 09713862555
Dec 15, 2009 | Xerox Phaser 3100MFP/S Laser Printer
49 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
