Question about Miele Coffee System
How do I access the bean hopper on my miele coffee machine
The machine tries to grind but the beans are not being fed into the grinder. The machine grids for a while and then stops and a message then comes up "add coffee beans" even though there are coffee beans available.
SOURCE: Miele CVA615 remove coffee bean dispenser?
their is a plastic screw below the bean dispenser .once unscrewed you will remove the dispenser
Posted on Aug 16, 2008
Master_Tech
  • 770 Answers
SOURCE: No coffee coming out
sounds like you have a bean jam post your model i will send you the guide on how to fix this it is too long to type here
Posted on Aug 20, 2008
SOURCE: No 'real' coffee taste or crema - despite following instructions
Set the machine for the finest coffee and the least water.
You should get a decent espresso.
For a regular cuppa, keep the settings the same and make either a medium coffee combined with a small coffee (jolt) or
make two small coffees.
I have this machine and the crema is nice at this setting.
Posted on Oct 03, 2010
  • 51 Answers
SOURCE: the coffee is filled and yet when it begins to
Are the beans very oily? Oily beans can sometimes cause things like this. My suggestion is you take out the bean hopper and clean the beans under that because on my Miele CVA4066 there are usually more than a few beans and chipped off pieces of beans under the hopper which cause some trouble.
Posted on Jun 29, 2011
  • 51 Answers
SOURCE: I owe the miele CVA4075
Make sure the hopper is working correctly to see if there are any blockages, then check under the hopper to the opening where the beans go to the grinder. My guess is that there are a few beans and chipped portions of beans which are clogged under there.
Bean hopper is full, machine starts to grind the coffee but right before it starts to pull the shot, it stops & says "add beans to hopper".
the add beans to hopper signal most likely is triggered by the machine not sensing enough load put on the grinder (hence it thinks its out of beans) , this most likely is set by the grind (fine/course ) id say the grind is set to an improper size and the automatic sensor is picking up on that
another thing is the coffee / if its way too moist and not dry enough then its also going to trip the sensor as well
Feb 26, 2016 | Coffee Makers & Espresso Machines
My Rancilio Rocky Burr coffee grinder w/doser is not grinding the beans they simply remain in the hopper
It is most likely that something is blocking the pathway to the grinder. As the Rocky is a direct drive grinder there is no gear that could be broken.
Try to remove the beans from the hopper and inspect the pathway, move the beans that might be under the 'disk'. If that is not working you might have to open the grinder;
  • remove all coffee beans
  • unscrew the three screws in the bottom of the hopper
  • remove the hopper
Now you can see the grinder wheel and tell if it is turning normally.
This might be a good opportunity to give the grinder a thorough cleaning.
Do not soak it in water, just a stiff small brush (e.g. a toothbrush) is the best tool. And perhaps accompanied by a vacuum cleaner :)
If you have been using very 'oily' beans for a long time they might have clogged the grinding wheels.
Good luck,
Villi
Mar 02, 2015 | Rancilio Coffee Makers & Espresso Machines
The grinder runs but does not grind beans
Sounds like a blockage in the bean hopper. With the power off, take away the bean hopper and reach in the hole where the beans go and poke around to see if you can clear it.
Mar 03, 2012 | Miele CVA615 Espresso Machine
I owe the miele CVA4075 BUT my whole bean grinder is not grinding the bean and only water gets dispensed, anyone have a solution?
Jun 28, 2011 | Miele Coffee Makers & Espresso Machines
Ground coffee will not dispense
The beans are hanging up in the hopper and not falling down into the grinder...... wiggle it, give the beans a push, or go to a bean that is not so sticky....
May 29, 2010 | Gaggia Titanium Espresso Machine
Coffee beans don't grind even though there are beans in the hopper. Message: empty coffee beans. Grinder turns, but doesn't sound like the beans are going through.
Sounds like you have a blockage in you grind passage. Try removing the brew group. Then inside on the roof of the machine where the brew unit was setting there is a drop chute where the coffee is dropped into the brew unit. From the left side of the drop chute pull down and back, and it will drop coffee. This will clear an opening that relieves pressure on the passage. There is a passage inside the drop chute area that goes to the grinder. Vacuum it out. It will be on the right side of the drop chute.
Once that is cleared go to the bean hopper. There is a lever on the right side of the bean hopper. Push the lever back to the largest number. You can push the lever to a larger number any time but it has to be grinding to pull to a smaller number. Now replace everything and make your coffee. Once you have made your coffee you can pull back to a number that was higher than the one you had it on, but only when the grinder is running.
Nov 11, 2009 | Saeco Royal Professional Espresso Machine
Machine has major problem with grinding beans.
Try removing all beans from bean holder - then use a vacumn machine to remove the bits down amongst the grinder "teeth'. You may have had a small stone in your coffee and if so it may have jammed the grinder.
Once it looks clean, try making a cup of coffee without the beans in the hopper - you should be able to see and hear the grinder revolving and also hear the brew unit moving between the grinder outlet and the water inlet. If it all seems ok now, then add a small amount of beans back into the beans hopper and try making a coffee. If it still will not work, get it serviced. There's not much the average person can do inside these units other than to do more serious damage or kill themselves with an electric shock.
Nov 05, 2009 | Saeco Magic De Luxe Espresso Machine
All of sudden my grinder plugs up. coffee settles in around the base of the burr and does not seem to fall into the grind bucket, so the machine still runs but grinding basically stops as no more more...
This fixes almost all the "beans will not feed or beans will not grind" problems caused by coffee bean dust packed in the burrs. Oily beans cause this problem more fequently.
a. Pour all the beans out the top.
b. Open the settings up all the way and see what else can be poured out. Use your shop vacuum to **** grounds out the spout and backward out the bean bin.
c. Pour in some instant rice and start grinding. Reduce the grind to a small setting like six and then open the settings all the way again. (The grinder will not start at a low setting with the rice in it. If you let it stop, open the settings to about 16 before trying to restart.)
d. Pour out the rice and vacuum out the ground rice.
e. Adjust the grinder to your favorite setting and try a coffee grind. Grind until most of the rice dust is expelled (any remaining trace of rice dust will not affect the flavor of the coffee).
Nov 03, 2009 | Solis Maestro Electric Burr Grinder
Bean hopper is full, grinder is grinding...but NO COFFEE!
Sometimes the chamber between the grinder and brewer will clog up. Try: Open the grind all the way up to the highest number. Push the grind button and while grinding move the dose knob (the one with the + - sign toward minus. If it does not kick in and dose try it again. If it does take off then leave it on the high number for 3 coffees. Then while the grinder is turning move the two knobs back to whre they were. If this does not work you can reomve the brew unit and right above where it sits in the machine there is a trap door that you can open. Open it and shove someting like a straw up toward the grinder and you should get a bunch of grounds droppiing down. Then try the above procedure a couple more times. If this does not work you may need to google "Saeco repair" and send it to an authorized repair center.
Aug 15, 2007 | Saeco Vienna Digital Coffee Maker,...
Miele Coffee System Logo
Top Miele Coffee Makers & Espresso Machines Experts
Jerry Greenberg
Jerry Greenberg
Colin Stickland
Colin Stickland
steve morris
steve morris
Are you a Miele Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
