Question about Master Appliance HAS011K Replacement Heater Element For HG501
My hoover apollo delux dryer has a broken plastic plate that the door latch fits into. Do you think I can get a replacement part ?
  • 120 Answers
You would have to go to the Hoover web site and see if they still sell parts for your unit.
Posted on Oct 08, 2009
My Hoover apollo deluxe dryer trips the electricity switch to the house and goes off. Is it fixable or not worth it?
With a an electrical short that is strong enough to trip the safety on the house, it must be repaired or replaced to be safe. So it is a matter of your taste and the cost. I would bring it to a repair shop, ask for a quote and their opinion based on the condition of the vacuum.
Jun 09, 2017 | Hoover Dryers
Can you give a model number?
Jan 30, 2014 | Dryers
Hanging Hoover Apollo Deluxe dryer unit from the wall
you will need to get a wall mount bracket. I found a couple on ebay for about $30.
Sep 30, 2009 | Hoover Dryers
Hoover Apollo Delux not drying properly and takes ages. Outlet air is hot but my wife says it's not drying as well as it used to. The front filter is clean but is there an inlet filter that I'm overlooking...
T^o much lint in duct work, causing moisture and not allowing cloths to dry. Vacuum out duct work in dryer and from dryer to outside of home.
Jul 17, 2009 | Dryers
Door latch broken- disassemble door ??
yes if its plastic just pop it out to replace
Feb 09, 2009 | Bosch Axxis WTL 5410 Electric Dryer
Door won't fully latch, light stays on, dryer won't function
There is typically a small plastic piece that catches the door and keeps it latched. The door has the male side and the frame of the dryer has the female side.
Either the male part on the door has broken off (or bent) or the the female part on the frame has broken. Replace this part and you'll be back in business. It is typically called a door latch and it comes with both the male and female parts.
Here is a picture
of a typical one.
Sep 22, 2008 | Dryers
Hoover Apollo Delux dryer
i dont think so , even if you could get the parts it would be quite tricky to fix without the proper tools and if you bought the tools they would cost more than a replacement dryer
Sep 20, 2008 | Master Appliance HAS011K Replacement...
Zanussi ZDC67550 Dryer, door swing change?
Hi
just reversed the doors in 15-20 mins. It worked for me. You do need to be a competent DIYer to do this.
If in doubt, do now't. Get in an engineer
Disconnect from mains (obviously)
Remove top using 7mm nut driver/spanner
Remove 2 cross-head screws holding the door - Door will come away from dryer.
Remove 2 cross-head screws holding the white top and bottom blanking plates
pull out the switch blanking plate
Locate the PINK wires connecting the switch/latch mechanism inside the dryer at the top. This will be taped to a blue wire.
Unscrew the 2 smaller cross-head screws holding the latch/switch assembly whilst holding the pink wire to stop the mechanism dropping inside the dryer.
Pull up the latch mechanism and unravel the black tape holding it to the blue wire.
Drop the latch assembly down the lefthand side of the dryer and refit using the 2 small cross-head screws.
Retape to the blue wier and feed the PINK wires through the plastic retainers.
Fit the white blanking plates to the RIGHT handside of the door opening.
Swap the hinges and the switch latch on the door (don't lose the spring !!!, refitting the hinge blanking plates(ease these out with a small flathead screwdriver covered witha bit of insulating tape to avoid damage.)
Fit the door using the 2 cross-head screws you have left
Refit the top.
Connect to the mains and switch on to the sound of £80 you have just saved yourself !!
Electricity kills Be careful
Oct 03, 2007 | Whirlpool GEW9250P Electric Dryer
Master Appliance HAS011K Replacement Heater Element For HG501 Logo
176 people viewed this question
Top Master Appliance Tools & Hardware - Others Experts
Marvin
Marvin
john h
Are you a Master Appliance Tool and Hardware - Other Expert? Answer questions, earn points and help others
