Question about Rain Bird Xerigation XCZ-075
I have a isa 304 worked last year but not now has it been replaced by something else
My Rainbird ISA 304 will not turn off, even when completely disconnected
Solenoid is not completely shutting down for that zone.
Aug 28, 2017 | Garden
What is code 301 302 303 304 305 306 on this honda
these codes refer to engine miss fires. and the cylinders that are miss firing, hence the last #in the code. could be spark, fuel, or something in the system that allows the cylinder to fire.
Mar 14, 2015 | Honda Cars & Trucks
My computer beyond ISA server and also have note book, when cable wire not attach with router then my wire note book connect easily, when i put my cable connection in router, wireless indication light stop...
First of all, routers come with static ips... (the default is usually 192.168.1.1). So I am going to assume you mean your internet ip is a dynamic ip. Now Im not an ISA expert, so I may be wrong... but ISA should work with a dynamic external IP. And lastly if you cant get it to work, a quick call to your ISP will get you a static IP.
or
Try to configure the IP address of the external NIC in the same network as your router with the default gateway pointing to your router´s IP address.
In the internal NIC, configure the IP address of the internal network in the same subnet as your internal clients, set no default gateway and set an internal DNS.
In the internal network definition, you should put only the networks behind ISA trust interface.
Create access rules according to your needs.
If you need more help come back.Post / thumbs / testimonial are welcome!
Nov 21, 2010 | D-Link DIR-300 Wireless Router
MY PROBLEM AUDİO DRİVER... HOW CAN I DOWNLOAD AUDİO DRİVER? MY NOOTBOOK TOSHİBA A305-S6858 XP
You could try to reinstall its sound driver. Feel free to download it from this location.
Hope it works for you.
Cheers! Carlos
May 22, 2010 | Toshiba Satellite PSAG0U-02D00M Notebook
2002 Passat 1.8T with 150,550 timing belt, water pump and tramsmission have been replaced. Codes: PO011 PO300-304 PO328 PO171 Is it time to say goodbye?
po328 is your knock sensor the po300-304 is your cranksensor change that and most problems will go away remember to disconnect the battery
the knocksensor can still play a roll if the car doesn't want to start each one of thors sensors are at autozone 40.00 bucks to 60:00 covers it
Mar 01, 2010 | 2001 Volkswagen Passat
Nad 304 amplifier no output, relais not willing to
The 2 BIAS resistors of 47kohm, R333 R334, replaced with new 1W resistors. 1 resistor was totally open and 1 resistor was 55k.
It were 1/2W resistors, replaced them with 1W resistors. Very low cost repair for a High End amplifier. Should live for another 10 years.
Regards
Marc
Jan 07, 2010 | NAD Audio Players & Recorders
MOB ITOX G4620-N won't reconize ISA Cards
WOW must be a fairly old system if it still has ISA slots.
Are you running XP or something else?
I assume you have the manufactures drivers that match the operating system you are using?
Have the isa cards worked in this system before?
My memory of isa cards is they are really useless at managing interrupts and I/O addresses. Go into device manager and see if there are any conflicts.
Try installing one card at a time. once it is recognised you can try the second one.
Also go into the bios settings page and turn off devices you are not using like serial ports and parrallel ports. if you have a sound card remove it or disable it if is onboard.
If you know what Interupt the cards is tyring to uses you should be able to reserve it in the bios so that plug and play devices won't touch it.
With a some trial and error and a combination of all these settings you should be able to figure it out.
Apr 01, 2009 | Computers & Internet
MY XFX8500GT CARD WON'T FIT INTO ANY OF THE CPI SLOTS IN MY COMPAC PC,CAN I USE THE BLACK ISA SLOT?
That card is a PCI EXPRESS. Not the same as a PCI. Definetely wont work in your ISA either. PCI Express came out a few years ago and is a faster interface than PCI. Hope you can get your money back or exchange it for a PCI. Please remember to rate me if this fixedYa. Thanks.
Feb 22, 2009 | XFX NVIDIA GeForce 8500 Graphic Card
Replaced radiator in 99 cabrio
It could be either:
1) Thermo fan switch
2) Radiator fan
Dec 12, 2008 | 2000 Volkswagen Cabrio
Mitsubishi WS-55859
Check any/all fuse devices in power supply.Let me know.....T.
By the way,the tv serial # is 107543. I assume the model # is
as stated==WS-55859.
Oct 21, 2007 | Mitsubishi WS-55859 55" Rear Projection...
Rain Bird Xerigation XCZ-075 Logo
Top Rain Bird Hardware & Accessories Experts
Gene Haynes
Hippy_dd
Are you a Rain Bird Hardware and Accessory Expert? Answer questions, earn points and help others
