Question about Plumbing
I have a Tuscany 900 90503 faucet that leaks water from the spigot. How do I fix it?
  • 374 Answers
SOURCE: How do I, myself, fix a faucet leak?
Faucets in general operate either with a one handle valve stem or valve stems that uses small pieces of rubber to precent the water flow. In a single handle model this is usually caused by mineral deposits building up and the valve not being able to fully restrict the flow of water. The fix here is usually a new stem. On models that use a two handle system and do have replaceable valve stems one must get a repacement seat from a hadware store and reinstall the stem. In extreme cases the valve body may need to be ground internally and will require a professional. If you do not a have replaceable stems than the only alternative is a new faucet. I hope this assists you and thanks for using Fix Ya.
Posted on Nov 09, 2008
  • 297 Answers
SOURCE: I have purchased a Tuscany Brass kitchen faucet
if i remember correct this connection is plastic to plastic,if this connection is broken you must replace the hose and the head.i hope this helps.good luck with you project.
Posted on Jul 31, 2009
  • 39 Answers
SOURCE: kitchen faucet leaking pull down sprayer spout type
try tightening the nut that attaches the flex line to the pull out spout
Posted on Aug 04, 2009
SOURCE: Tuscany kitchen faucet blows
They do come with a lifetime warranty, so if you have the model number, you can call their Customer Service line at 800-545-5230 for replacement parts.
Posted on Mar 10, 2010
  • 349 Answers
SOURCE: Water leaking from the faucet onto the countertop.
http://docs.homeclick.com/PE-Links/Rohl/Rohl-A3608-specs.pdf
Check out this web site and it looks like it should be a o ring at the base, anyway I hope this will be helpful.
It has a breakdown of faucet internal parts.
Posted on Jun 05, 2010
Tip
Ball-Type Single Lever Faucets
BALL-TYPE SINGLE-LEVER FAUCETS
  • The single-handle faucet with a ball inside to control both hot and cold water may either leak at the spigot or at the handle. A handle leak is usually caused by improper adjusting-ring tension. Simply adjust the tension to stop the leak. Leaks at the handle can also result from a worn cam gasket. Dripping from the spigot is usually caused by worn spring-loaded, soft rubber seat assemblies.
  • Parts for ball-type faucets are available in kits. Get the spring/seats kit for spigot leaks, or the complete kit for handle leaks. It may be advisable to use the complete kit to replace all working parts of the faucet at the same time. In any case, you'll need a kit containing the spanner/hex wrench for removing the handle (hex end) and turning the adjusting ring (spanner end).
  • Without turning the water off, loosen the handle set screw. Slide the handle from its stem.
  • For a handle leak, try using the spanner wrench to tighten the adjusting collar. Tighten it by turning the wrench and collar clockwise until the faucet doesn't leak when it is turned on and off. If the adjustment is too loose, the faucet will leak. If you turn it too tight, the handle will be hard to move. When the adjusting ring cannot be turned with the wrench, it is corroded. At this point, you will need to remove the cap to free the adjusting ring. (See next step.) You must turn the water off before removing the cap! Apply penetrating oil to the threads, remove the ring and clean all parts before reassembling.
  • Install the seats. For faucet leaks at the spigot, you must install new rubber seats and springs. You must turn off the water to make this repair. Unscrew the chrome cap by turning it counterclockwise. If it won't turn easily, wrap electrical tape around the cap and turn it with pliers. The adjusting ring, which is threaded into the cap's center, will come off with it. For a seats/springs replacement, pull the ball up and out by its stem. The gasketed cam will come with it. Now you can locate the two rubber seats and springs inside the faucet body. Remove them with pliers or yours fingers and install the new ones. The springs go into the holes first, and the cupped sides of the seats fit over the springs.
  • Service the ball. If the ball is dirty or coated with scale, clean it or replace it with a new one. Both plastic and brass balls are available, but use a plastic one if your home has hard water.
  • Reassembly. Put the ball and cam back into the faucet with the slot in the side if the ball fitting over the pin in the faucet body. Then make sure the tab on the cam slips down into the notch in the body. Not aligning the tab and notch is the number one cause for a faucet leaking after it is repaired. Finally, screw on the cap and adjust the ring as described in Step 2. If a properly adjusted ball-type faucet leaks at the cap, the cam and gasket must be replaced.
  • Swing spouts. If a single-lever ball faucet leaks at the base, you should replace the O-rings. Remove the spout-retaining parts, as well as the spout. Wrap the spout-retaining nut with electrical tape to protect it, and remove the nut with a wrench or pliers by turning counterclockwise. Remove the spout by pulling it up and side-to-side. One or more O-rings should now be exposed. Take the O-rings to your hardware or home center store to get matching O-rings for replacement. Clean any scale that appears on the spout base, faucet body, and the inside of the swinging spout. Install the new O-rings and reverse the steps above to reassemble the faucet.
on Jan 16, 2010 | Plumbing
Delta 400-DST Single Handle Kitchen Faucet Spigot Drips
I've installed quite a few of these from the big box stores that leak. There are 2 rubber pieces inside the valve body that act as seats. The seats are what turn the water on and off as you move the handle. These rubbers need to be replaced. You can buy a delta repair kit, which will contain these parts. Where the faucet is new, it might be easier to bring it back
Mar 02, 2014 | Delta Faucet Plumbing
Outdoor Spigot Leak
You may exchange the washer in the spigot or just change the spigot which is simple.
May 17, 2013 | Plumbing
Delta faucet continues to leak I have replaced the upper seals around the ball but I don't know how to get to the lower seals in the neck of the faucet
2 little seals with springs use a small screwdriver or needlenose pliers to remove the seats and springs they come out easy just pull them out
Oct 27, 2009 | Delta 2402 Classic Single Handle Kitchen...
How do you fix a leaking outdoor wall spigot? Even though the handle is turned tightly off there remains a drip. Spigot seems to be all one piece and attached into stucco wall. Is there a way to repair...
Sometimes, depending on the type of the spigot, you can unscrew the valve from inside the spigot. There would be a hex nut immediately under the part where the handle on the valve stem comes out. BE CAREFUL: Outside spigots rarely have independent shut-offs (ie, in order to work on it, you will have to shut off the main water supply). Once you start down this path, you need to be fairly certain there is a replacement available for your type of spigot. If you remove the valve, there is no assurance that you will be able to get the original back in without making the leak worse. Please have an emergency back-up plan in place.
Sep 16, 2009 | Plumbing
I have purchased a Tuscany Brass kitchen faucet with pull-out spout in the past 3 years. The problem is that the faucet leaks out through the loop handle and the spray head mounting collar what can be done...
Jul 27, 2009 | Plumbing
Leaking at base of spigot
duh....replace the o ring or the packing.
Mar 08, 2009 | American Standard 4275.550.002 ColonySoft...
Plumbing Logo
82 people viewed this question
Top Plumbing Experts
Donni Steen
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
