Question about IFB Washing Machines
How to replace ifb front load washing machine drum ?
Washing machine inside drum is not rotating.
SOURCE: thumping and banging
washing machine making noise, remove water but doesn't spin
Posted on Jan 27, 2008
  • 156 Answers
make sure all shipping pins are out the tub should move all around from side to side if it level still bangs its eather the balance ring top basket are there 3 slides on a plate above the motor just put some silacone oil on tham move around
Posted on Feb 25, 2008
  • 210 Answers
SOURCE: LG WM-1280 DD front loading washing machine
When the unit is off, open the door and spin the drum, does the noise occur? If the answer is no then there is nothing wrong with the bearings. Chances are the hall sensor on the motor is on the way out. Call for service and ask them to replace it. Make sure you are using a "HE" branded detergent,,,, less is best.
Sgt 48
Posted on May 31, 2008
  • 1462 Answers
SOURCE: Creda Excel 1200 W120VW Front loading washing machine
check motor brushes for a start
Posted on Jul 04, 2008
  • 177 Answers
SOURCE: Water leak under the rotating drum
Have you removed the front panel?
If not remove front panel two screws 5/16 on bottom
Start the washer in a cycle. look with a flash lite and look for leak.
It maybe the rubber boot.
Please let me know if you have any other questions.
I will also need model number, because a AWS52NW is a top loader model number not a front loader.
T
Posted on Jul 29, 2008
I have IFB washing machine it shows E7 error
1:IFB Washing Machine Not Turning ON OR Turns ON But Does not Starts. 2:IFB Washing Machine Door Does Not Opening. DE Error 3: Water is not coming inside the IFB Washing Machine Inlet problem 4:Water is Leaking from the washing machine, drum or hose pipe damaged 5:Wash is not happening / Spin not Happening in the IFB Washing Machine 6:Drum NOt rotating or Drum Making Huge Sound while spin cycle, 7:Water not Draining From the washing Machine 8:Burning smell, Tripping Problem, etc https://electronicshelponline.blogspot.com/
Read more: http://ifbservices-com.webnode.in/error-code-fault-codes/
Aug 05, 2016 | IFB Washing Machines
In IFB front washingmechain AC h1 error is coming what to do
AC h1 is actually AC hi error which means input voltage is too high. Wait for sometime for voltage to stabilize Washing machine will automatically start. If not call electrician to check electrical fault for high voltage
Jul 03, 2014 | Kenmore Elite 45986 Front Load Washer
IFB washing machine front load Showing ' Lo' what
Error code LO normally means the filter is blocked. this would be the best place to start. refer to your owners manual for instructions on cleaning this.
Aug 10, 2013 | IFB Washing Machines
Burning smell along with fumes came out after a ghastly spin of the drier. after that it can't be switched on. Mine is a front loading washing machine (IFB executive plus).
Don't try to turn on again. Call a service agent for that brand of machine and leave it to them. Obviously a major problem and could cause major damage to your home if you force it on again
Jan 14, 2013 | IFB Washing Machines
Ac voltage become hihg or low when start ifb washing machine
We got a IFB front loading washing machine last week only after 3 time wash 4 th day it is showing AC-LOW message . the service people came and went but nothing is done what is the next solution?
Same point top loading Godrej 6.5 kgs working fine but water consumption is more in that compared to front loading machine so pls sugeest good solution at the earliest.
Sep 30, 2012 | IFB Washing Machines
Jamed in front loaded IFB washing machine tell the solution
Plz forward contact no. contact name, address. So we can contact with you. also you can visit our website www.ifbappliances.com for more details.
Regards,
IFB customer care
Jun 07, 2012 | IFB Washing Machines
There is a cockrach in the idicator of my IFB front load washing machine. How do i remove it?
this is always a problem with all electronic lcd when around little cockroaches an expert would take the panel off and clean as well as spray the unit from the inside but short of that he will event die and hopfully fall away from the lcd
Apr 20, 2010 | Indesit W 123 Front Load Washer
How do i fit the drive belt on a hotpoint wma74 washing machine
Hook the belt over the motor shaft and feed it onto the drum pulley as far as it will go,hold it in place on the pulley with the aid of cable tie clips, then rotate the inner drum anti clock wise by holding the inside of the inner drum. This will draw the belt onto the pulley and the cable ties will snap as the drum rotates.
Mar 04, 2010 | Hotpoint WMA74 Front Load Washer
Kenmore 3.1 capacity front load washer
CHECK REAR BEARING(rear of drum)OR THE ROLLERS THE DRUM ROTATE ON LOWER PART OF WAShER
Jan 19, 2008 | Kenmore 43142 Front Load Washer
Washing Machines Logo
14 people viewed this question
Top IFB Washing Machines Experts
Raj Patel
ray gallant
Are you an IFB Washing Machine Expert? Answer questions, earn points and help others
