Question about Frigidaire Washing Machines
Service center in dubai
I need to know the cost of changing a part of the machine transmission tub seal and tub bolt
  • Frigidaire Master
  • 5,323 Answers
ROUGHLY AROUND 20-/30 BUCKS BUT HAVE SEEN SOME HIGHER
Posted on Mar 31, 2015
SOURCE: changing front loader seal
the way i done it was open the door take take the wire band of around rubber seal__as in picture one.__2 take top of machine of and take spring of as shone in picture 2 you shold be abble to take silver band of around rubber seal
Posted on May 07, 2007
  • 7 Answers
SOURCE: Maytag MAV7200 Washer......needs seal and bearing kit
I HAD TO REPLACE THE SPIN BEARING ON MY MAYTAG ATLANTIS WASHER MAV9750,
it was making a loud noise during sin cycle, like a bad bearing would
make, jet engine kind of noise, i did replace the bearing and made a web
site with pictures on how to do it, since it almost takes all the parts
out, it will show you how to get to most of the parts in the machine, and
i also included links for downloading the repair manual, and parts at
appliance parts pros web site
http://maytagwasherrepair.googlepages.com/index.html
Posted on Apr 11, 2008
  • 1122 Answers
SOURCE: outer tub seal
you must first remove the agitater,then remove the inner tube,you'll need a spaner wrench,you now can see the tub seal,how you need to remove the 3 bolts around the bottom of the outer tub,now you can remove the outer tub and replace the tub seal,or use some 3m gasket seal,up to you,you can get a new tub seal on line for $10,let me know how you do-mike
Posted on Nov 04, 2008
breddi2
  • 126 Answers
SOURCE: top loading washing machine leaking at center bottom
remove panel below door and run it. Then you can see if it is the front seal or back at pump. Two screws on bottom of panel to remove it
Posted on Apr 26, 2009
  • 121 Answers
SOURCE: GE WBXR2060V1WW leak_transmission shaft and tub
The tub seal is leaking, often this damages the transmission. A new tub seal comes with the transmission this page should help http://www.appliance-repair-it.com/GE-washer-disassembly.html
Posted on Sep 03, 2010
Leaking from underneath the machine
If the washer leaks all the time, check these: Hot and cold water fill hoses - Check the hot and cold water hoses from the household plumbing. If either hose is leaking, tighten it or replace it, as appropriate. Main tub seal - The main tub seal is located between the transmission and the outer tub. It's the primary water seal in the outer tub for the transmission-shaft entry point. If this seal leaks, you can see the leak by opening up the machine's main access panel while the machine is full of water with a small amount of detergent in it. The leak appears at the underside of the outer tub, at or near the center. This seal is difficult to replace. You probably should call a qualified appliance repair technician. Pump - If the pump leaks, you can probably spot the leak when the tub is full of water. The pump has two or more black rubber or plastic hoses attached to it and usually has a drive belt that spins the pump. If the pump is leaking, you need to replace it.
Dec 31, 2010 | Hotpoint VBSR3100D Top Load Washer
Hi, My Frigidaire Clothes Washer, Model FES445RF, which has developed a leak around the shaft seal where it enters the outer tub. Is it possible to repair and can I get to it by removing the outer tub from...
Hi, what you are experiencing is problem with the Main tub seal - The main tub seal is located between the transmission and the outer tub. It's the primary water seal in the outer tub for the transmission-shaft entry point. If this seal leaks, you can see the leak by opening up the machine's main access panel while the machine is full of water with a small amount of detergent in it. The leak appears at the underside of the outer tub, at or near the center. This seal is difficult to replace. You probably should call a qualified appliance repair technician.
You can get the parts by contacting appliance help on 1-800-470-7119
Oct 06, 2010 | Kitchen Ranges
Water leak around transmission
you will need a new tub seal kit part number 12002223. however these seals are very time consuming to change and most(90%) of the time will only temporaraly fix the problem. the seals are machine pressed in at the factory so changing the seal in the home doesn't hold up very long
May 07, 2010 | Maytag SAV571EEWW Washer
Maytag Dependable LAT8824AAE. Main tub seal leaks
The part number for the mounting stem and seal kit is 6-2095720 it cost about 85 bucks retail. You will also need to buy a special maytag spanner wrench to remove the inner tub. Its NOT an easy job the inner and outer tubs and hoses all need to be removed. The seal kit comes with no instructions. If you had a service company do the job it would be probably around 250 maybe more. We charge 104.95 labor for the job. Good luck _MJ_
Mar 04, 2010 | Maytag Washing Machines
Water leaking out of bottom of machine, nothing clogged and found a bolt head in tub
if you found the bold head in the tub chance are that the trunion bolt has broken off and cause the tub to become unsecure from the agistatir shaft and has torn the seal below the inner tub. remove the agitator and you will see the trunion and two bolts.the tub ring has to be removed and then the inner tub has to come out in order to replace tub seal.the tub seal part number is 5303279394 it cost around 45 dollars. the screws need for the locking plate are 131192800 and they caost about 4 dollars a piece.i hope this has helped you out.let me know how things go and if you need any more help let me know.
Jan 22, 2010 | Frigidaire FWSB5700DS Top Load Washer
Water leaking from under washer
Hi
You'll need to open the machine and check for the leaks in the hose connected to the drain pump. Also check if the clamp connecting the drain filter and hose is tight. Also check these things for leaks---
Pump - If the pump leaks, you can probably spot the leak when the tub is full of water. The pump has two or more black rubber or plastic hoses attached to it and usually has a drive belt that spins the pump. If the pump is leaking, you'll need to replace it.
Please do rate this solution as FixYa if found useful and revert for further assistance.
Thanks
Rylee
Apr 21, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Nov 12, 2008 | GE WDSR2080D Top Load Washer
Outer tub seal
Nov 03, 2008 | Kenmore 24032\24036 Top Load Washer
Leaking tub seal, slow spin cycle
It's not worth fixing!
If it's 10 years old or more, better off replacing it with a newer machine which will be much more efficient!
Not worth the money to fix!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Try You should call service.:
A&E Factory Service
1-800-905-9505
Nation wide / 7days/24 hours
Good work
Please give me a "Solution Solved Rating", in this site!
Thank You
Neil
Jul 31, 2008 | Frigidaire FEX831CS Top Load Stacked...
Leaking washing machine
The cost will depend on what part of the country you live in and what repair service you use. I would suggest you call some local services and get estimates. I work in the mid-south area for a nation wide service company. The cost for us to do this job is $300+.
I have run into several that could not be taken apart due to years of detergent buildup causing the seal nut to seize to the transmission housing..
Hope this helps.
Nov 13, 2007 | Washing Machines
Washing Machines Logo
24 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
