Question about Printronix Office Equipment & Supplies
Manual se 5010
Printronix 5010 Printer gives replce shuttle cover error
    Scholar:
  • 111 Answers
If you removed the black shuttle cover please put it back. If you removed the cover and dropped the magnet on the right hand side then please find and replace.
Posted on Feb 04, 2015
2 Suggested Answers
  • 38 Answers
SOURCE: "Shuttle jam" see manual problem on Printronix line matrix P 500E printer
Verify that there is nothing clamped between the platen and the shuttle.
Last time I had this fault, it turned out to be a broken wire in the harness that connects the CMX board to the shuttle module.
Other possibilities include a failed shuttle or CMX board.
Steve W
LazerTek LLC
Posted on Jul 17, 2008
Printronix p4280 making noise
Depending on the specific circumstances, of course, the most likely culprit is the shuttle assembly. It could either be the motor in the assembly or the bearings in the shuttle assembly.
Put in hold mode. (Press Enable/Hold button)
Remove the shuttle cover assembly. (leave the screws in the cover itself when you remove it). On the middle-right side you will see a cover sensor -- you will need to fool this with a magnet.
Run a test print (Print Test button). (With the hood up/) Listen for the source of the noise. Is it the motor or the shuttle assembly bearings. (If the noise stops when you turn off test print and the motor is winding down then it is the shuttle assembly bearings.) Or is the noise elsewhere?
If elsewhere move around side to side to differentiate and locate the sound.
Here is a link to the part of the manual that describes replacing the shuttle assembly.
Please note that the motor itself is not really considered a separate field replaceable unit -- it is considered a part of the shuttle assembly. I only mentioned it separately above as part of the troubleshooting to consider the noise source. http://www.theprinterplace.com/printronix/P4280_Shuttle_Replacement.pdf
Jul 21, 2012 | Printronix P4280, P5005, P5008, P5009,...
A have printronix p5005 printer but printout not clear
Remove the black cover over the shuttle and look for a phase number hand written in blue marker on the right side of shuttle. Press the up and down arrows at the same time to unlock the control panel. Press left arrow to go to diagnostics. Down arrow and right arrow until phasing. Set phasing number same as what was written on shuttle assy.If it is making noise then the shuttle is bad.
Sep 13, 2010 | Printronix Line Matrix P5005B Printer
Shuttle jam appear
www.oki.com.tr/binaryData/13882/OKI_UM_250011A.pdf
in this pdf u have got the problem solve the shuttle jam problem
Apr 01, 2009 | Printronix P7010 Printer
Hardware may be
first of all do one thing and that is keep your platen marked A,B,C in b or c position then start printer if it prints then it means your shuttle gets very much tight in position A, for that please switch off the printer remove paper and loose your shuttle and adjust your shuttle according to the movement of paper. also do one thing that is clean your shuttle senser also.
Feb 19, 2009 | Printronix Line Matrix P5005B Printer
058 SHUTTLE JAM "ERROR"
See this post:
http://www.fixya.com/support/t746596-shuttle_jam_see_manual_problem
Jul 09, 2008 | Printronix Line Matrix P5210 Printer
Steve W
LazerTek LLC
Jul 06, 2008 | Printronix Line Matrix P5005B Printer
Table Mismatch Download Again (Printronix P5215)
hi
i have an error " tabel mismatch download again" on my printonix p1000q1
how can i solve it please help me as soon as Possible please help
Sep 14, 2007 | Printronix Line Matrix P5215 Printer
29 people viewed this question
Top Printronix Office Equipment & Supplies Experts
Chinmay Joshi
Chinmay Joshi
Cliff
Are you a Printronix Office Equipment and Supply Expert? Answer questions, earn points and help others
