Question about LG 42LC2D 42 in. LCD HDTV
Lg tv and dvd
Lg tv and speaker system with dvd player (sounds great) but how do i get tv sounds through speaker system please help?
Re: lg tv and dvd
Please connect the RCA wire yellow,red,white with TV set's output connections and other side connect with speaker systems input connections that's all
Posted on Nov 04, 2007
0 characters
3 Points
I want to add external speakers. How do I do it and what speakers do you reccomend
Hello jazzolino,
there any several ways you can go about this and they can range in quite bit in your budget. Anywhere from $60 to $5000 or more. The $60 one's im talking about are just small computer speakers that you could connect to your tv. Or a home theater in a box (HTIB's), or buying every speaker individually. The last choice is the best way to go but will be the highest budget.
First off figure out how many speakers you would like. You can go all the way up to a 7.2 channel. 7 means 7 speakers and 2 means 2 subwoofers. Some people dont like speakers everywhere and want very simple speakers. You can get a soundbar. Its one speaker that may or may not come with a subwoofer (usually wireless subwoofer) depending on your selection. They can have excellenet audio but it will not give you the full surround sound experience if that is what you are looking for. If you do want that, you can look for a 5.1, 7.1, or 7.2 surround sound. Some HTIB's can come with dvd player or a blu-ray player. They usually are lower cost in budget wise but I usually don't recommend this people just because if the dvd player goes wrong, you may lose everything. But again they can give you the surround sound experience and has excellent audio. The other one's do not have a dvd player but just a reciever. I recommended getting one with a reciever (onkyo is my favourite but a beast looking one for sure). Harmon/Kardons have excellent design on them and are just as great. Most of the speakers are use speaker wires and need to be powered by the reciever. There are speakers out there that are powered by the subwoofer. Generally these are 2.1. (If you want 2.1, I suggest the bose speakers GS series II or series II).
The other option is to get everything individually. If you do this keep in mind of the power that you are looking for. Some have 200 watts and some have 1000 watts. For example for a 5.1, if you get a reciever that powers 1000 watts and you get speakers that can only 50watts per channel (per speaker), the receiver can potentialy over power the speakers and lead to distored audio or speakers blown up. Since this speakers only need a total for 250 watts (50 watts x 5 speakers), you only need like a 300 to a 500 watts reciever. Keep in mind the subwoofer is powered by itself.
Once you get the sound system, I suggest you plug all your cables, like dvd player, satellite or cable, game systems all on to your reciever and then one cable to your tv. This is because tv's usually dont have enough inputs in the back and you could run out quick, that is one of the reasons why I recommended a reciever. Reciever's have lot of input on the back so most likely you will not run out. I suggest plugging in an HDMI cable from your reciever to your TV. HDMI will give you both audio and video from one cable. This way when you have your dvd player plugged into your reciever, you will get picture to the tv. There aren't many wireless home theater systems but there are wireless system to make the back two speakers wireless. Generally, having wires running along the length of your place seems to be the biggest inconvience. They can cost about $200.
Brand name speakers JBL, Harmon/Kardons, Onkyo, and Klipsch. Now other people will recommend something else, so look into it. See which is best suitable for you.
I know this is only a quick run down and I could keep going but it would be pages and you would lose interest. I hope this helps. Good luck.
Aug 29, 2011 | LG 32LG30 32 in. LCD HDTV
Connected PC to LG with HDMI. Wonderful pic but NO sound. PC HDMI audio test works great and sound is clear thru TV. When movie is played from PC to TV there is no sound.
How do you get HDMI out to tv, through a graphics card? Is Is it HDMI direct out of the card or DVI adaptor? I believe you will get a ping even if the volume is turned down and when playing a movie you would have volume control throuh the DVD player, the computer and the tv. Make sure your volume is turned up on dvd player and right click on your speaker icon in taskbar, at lower right of screen and make sure that volume is up. When you do the ping are you checking a "HD" audio driver. Look in 'device manager" in "sound audio and game controllers" and right click on "HD" devices and make sure they are enabled. Let me know what happens. When you look at devices in device manager you also may see a warning. If so click on the symbol, ? ,!, or triangle and follow proceedure.
Apr 06, 2011 | LG 42LC2D 42 in. LCD HDTV
I have attached a DVD Player to my LG TV, using the appropriate cables. I have sound and a black & White picture. What have I done wrong please?
It is very simple, the mode of your DVD or TV is not correct. Check the NTSC/PAL setting's on your remote control for the DVD player. If your DVD player is on PAL system, then you TV should also be on PAL system. Likewise for the NTSC system, possible to put both on AUTO mode then do it. Don't get confused it is just a simple setting which you can do it without any problem, and in future you can do it for others.
Mar 04, 2011 | LG Flat Panel Televisions
How do i get the sound for my LG LH70 TV to come through the speakers from my LG554 DVD system player ?
try plugin in the yellow cord from your dvd player to your tv properly make sure it goes in the correct yellow spot.
Aug 27, 2010 | Flat Panel Televisions
I have a brand new LG 37" television. Picture quality is perfect but the in-built speakers vibrate heavily to a deep bass sound. I played "Close Encounters of the 3rd Kind" through the dvd player and in...
i also have this tv.same problem too.i bought two multimedia bose speakers for 100$. they are actually designed for a laptop but trust me....they are better than most so called surround sound speakers designed for tv's.these tv's are not known for their built in speakers.
Aug 17, 2010 | LG 37LG50 37 in. LCD HDTV
55HDX99 TV with Sony DAV-HDX500
Connect RCA Red-White audio cable to INPUT of DAV-HDX500 and hook it to TV AUDIO OUT pins at back of TV.
Now select INPUT in DAV-HDX500 to get TV sound in Sony system speakers.
Apr 19, 2009 | Flat Panel Televisions
Audio problems with surround speaker system on
I have had the same problem on my home theater maybe you should try to wiggle the speaker cord it could be loosly hooked up to your home theater
Nov 22, 2008 | LG Flat Panel Televisions
Hooking up the dvd player surround sound to be able to hear the television thru it
Name & model # of television & DVD player, Please.
Usually if the DVD player is not an Amp, then the surround sound comes from the DVD player through the TV out through the speakers??
Jun 15, 2008 | LG 42LC2D 42 in. LCD HDTV
Home theater system connections
I have the same tv but my dvd surround is a toshiba, that shouldn't matter though. When I watch a dvd I go to component 2 which is where I have my dvd connected on the input of the tv when I watch tv and want the surround on I go to component 1 which is the tv input then on my dvd player I go to auxillary and I can watch tv in surround. I don't know the LG home theatre system but you should be able to select your inputs like between dvd, tuner, aux. Flip between them and you should get sound. hope this helps.
Oct 15, 2007 | LG 42PC5D Television
LG 42LC2D 42 in. LCD HDTV Logo
256 people viewed this question
Top LG Flat Panel Televisions Experts
Are you a LG Flat Panel Television Expert? Answer questions, earn points and help others
