Hi I have a HP G6000 laptop which won't boot. It will switch on for 2 seconds, goes off for 5 and then starts again. There is nothing on screen and it won't get to POST. I've tried with just the power supply, just the battery and using the power supply with the battery in. Anyone any ideas?
  • richardmgree Jun 23, 2009
    But the battery is fully charged and the problem persists just with the battery installed.
  • 3 Answers
Hi there, i had the same problem with my g6000. the problem is caused by the video chip overheating. only fix is by getting video chip repaired(technician required) or replace motherboard(approx £100). hp are aware of the overheating chip and in us have extended warranty to 2 years to cover this problem. hope this helps you
Posted on Sep 04, 2009
  • 255 Answers
Change your charger, your charger has problem.
Posted on Jun 23, 2009
  • Mohammed Ehsanullah
    Mohammed Ehsanullah Jun 23, 2009
    change your battery
    Mohammed Ehsanullah Jun 27, 2009
    1.do you have windows xp booting cd
    2. you can boot from cd and check whether your computer is working for morethan 5mts...
    3. sometime if harddisk have problem, then system will reboot or switch off or hang.
    4. press F2 for bios setup and set all the settings to default value and restart your computer...
I switch the power on power light comes on fan starts as if to boot then nothing, no screen and no keyboard lights
Does BIOS messages appear, or is the screen absolutely black?
If you see BIOS messages and then black screen, you should go to BIOS and choose your boot devices correctly. If there is no screen do the following tip:
1) Turn off the laptop.
2) remove the battery.
3) click and hold power button for about 30 seconds to discharge the circuit from motherboard.
4) then install the battery again
5) and click power button.
See what happens. In many cases it helps.
If there is still black screen, you should check your laptops RAM. In many cases removing and then installing back the RAM helps.
Oct 19, 2013 | HEWLETT-PACKARD HP 630/P6200 Notebook
JUST BOUGHT LAPTOP ON 2/22/11 AND TODAY THE SCREEN IS BLACK - G62-407DX AN HP WAS WAITING FOR FARMVILLE TO UPLOAD AND THEN NOTHING.STILL SOUNDS LIKE IT IS RUNNING WHEN SHUT.WHAT COULD THIS BE?
Hold down the power button until the laptop turns off. Wait 5 seconds and turn it on again. Do you see the slash screen as it powers up? Hopefully it will boot into the OS. If it's black the whole time, the video card may be dead. But if you do see a splash screen and it goes black after booting into the OS, you may have caught an infection. Try to boot into safe mode w/ networking and downloading scans to remove a possible infection. I use 3 scanners to remove infections. If the 3 do not clear it, the OS is hosed and needs to be wiped and reloaded. 3 scans: Combofix, SuperAntispyware and Malwarebytes. Good luck.
Mar 11, 2011 | HP Computers & Internet
Hi my HP G6000 laptop wont turn on, when i press the power button on the lights flicker for a second and then nothing
1. Check your power cord & adapter.
2. If its working then check the battery, reseat the battery & check.
3. If available then check with another battery
4. If no, then remove the battery & switch on the PC in AC mode.
5. Check if battery charging indication or AC power on indication is glowing. if not then need to change ur motherboard.
6. If indication is OK, but could not power ON then check ur RAM for any loose connection or dust. clean & reinstall.
7. If still no display, connect an external monitor, check if display is comming.
8. If Display is coming then your LCD is faulty and need to replace.
Aug 23, 2010 | HP Pavilion dv6000z Notebook
HP G6000 laptop wont start
Extract your battery from your laptop for 12 min, then start your computer using your power cable (don't use your battery), if not try pressing F2 rapidly when opening, after you open your operating system try changing your graphics card drivers.
Jan 31, 2010 | HP Pavilion dv6000z Notebook
When laptop hp g6000 is switched on the screen says start window repair (recommended)when this is activated the screen just goes blank and nothing happens. Any advice would be gratful
to avoid this, you need to run system restore on your system.
Restart your system and press "F11"
The system will begin the restore after you press F11. Just follow instructions and your system would be restored.
take care.
Jan 12, 2010 | HP Pavilion dv2210 Notebook
My laptop will not boot up
Try soft resetting the laptop .
1. Disconnect the Ac adapter
2. Remove the laptop battery
3. Press and hold the power button for 10 seconds
4. Reconnect the power adapter only and power on .
5. If the laptop starts fine , reinsert the battery back
Thanks
Proton
Jan 10, 2009 | HP Pavilion dv4000 Notebook
Acer Extensa 5210 laptop wont boot
Try the following:
1) Remove power cord, battery and hold the power switch down for at least 30 seconds.
2) Remove and reinstall your memory module(s).
If those don't do it, get back to me for more ideas.
Thanks!
Ron
Dec 14, 2008 | Acer Computers & Internet
Computers & Internet Logo
662 people viewed this question
Alun Cox
David Payne
David Payne
