Question about Garden
What is the gas/oil mix ratio for 25cc Craftman Weedwacker?
AlmostBob
  • 550 Answers
SOURCE: Gas/oil mix ratio for Ryobi Trimmer
50:1
Posted on Oct 10, 2008
  • 246 Answers
SOURCE: I need to know the gas mixture ratio for a craftsman weedwacker
Hello mcguilmd:
>>All Two Stroke Engines will use a 50 to 1 Ratio using Today's Two Stroke Oils. I once had an Old Chainsaw probably from the 1950s, maybe Earlier 70s that had a sticker on it that said to use a 25 to 1 Fuel/Oil Ratio, but that would have been using Two Stroke Oils of the Time Period the Chainsaw was Manufactured. I was having a Problem with Oil Coming Out of the Muffler and Started Decreasing the Oil in the Gas. I Reduced the Oil Until it was a t a 45:1 Ratio and Decided to be Safe, I would Use a 40:1 Ratio Mix. In that Chainsaw I used 50 to 1 Ratio with no problems. Today's Two Stroke Oils compared to Yesteryears are more Efficient at Lubricating. It is like comparing Today's Synthetic Motor Oil to Motor Oils of Decades ago. All the Equipment I use in Landscaping, anything from a Weed Eater, Leaf Blower, Chainsaw, Hedge Trimmer, use 40 to 1 ratio, and I use all types of makes and models, Stihl, Homelite, Husqvarna, Shindaiwa, and Echo, Sears. I mix up a 5 Gallon Fuel can and use it in all of the Equipment for my Customers and for my Landscaping. I like my Fuel/Oil Ratio a Little Heavy, so I use a 40:1 Ratio. The Following was Copied and Pasted here from and MTD E-mail to me when I Asked for the OEMs Suggested Mixture for this Unit. The mixture, as described by the engine manufacturer, is a 50:1 ratio when using the approved types of 2-cycle engine oils.
50:1 ratio is a mix consisting of 2.5 ounces of 2-cycle oil per 1 gallon of gasoline.
The 2-cycle oil used should be approved and have one or more of the following specification titles: NMMA TC-WII, TC-W3, JASO FB, or JASO FC. NOTE: If unsure of the 2-cycle oil specifications, or the oil is not approved, use a 32:1 fuel to oil ratio. This ratio consists of 4 ounces of oil per one gallon of fuel.
NOTE: Always mix 2-cycle fuel oil and fuel in an approved gasoline safe container prior to filling the engine. Make sure to use a separate gas can for this 2-cycle fuel mixture and label it accordingly. Keep in mind that the fuel capacity of these engines normally is less than a gallon, therefore you will have to use this extra oil mixture for multiple fuel fills. Adding a fuel stabilizer will also help to increase the shelf life of fuel.
>>I Suggest Using a 40:1 Ratio and if Oil Starts Coming Out the Muffler then go to a 50:1 Ratio.
Please, Do Not Hesitate, If I Missed Something or you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
Posted on May 14, 2009
  • 391 Answers
SOURCE: Craftsman 17" 25cc Trimmer...pull cord stuck
it's doubtful that bad gas caused this, it sounds like the cord was back-lashed and partially came off the recoil pulley. Remove the recoil cover and ensure the cord is all on the pulley, make sure the rewind mechanism works smoothly before re-installing.
SOURCE: Craftsman gas 25cc weedwacker starts, runs a few secs, then dies
The gas take up line is disconnected or is broken. I have the same problem and need to find a diagram to fux it.
Posted on Aug 28, 2009
SOURCE: What is proper gas/oil fuel ratio for TORO Model
50:1
Posted on Jul 02, 2010
What is fuel mixture on 25 cc craftsman weedwacker
This small engine needs a 40:1 ratio. Use only 2 cycle oil, not motor oil. If you are mixing one gallon of fuel use 3.2 ounces of the 2 cycle oil. This should give correct mixture so you do not get lots of smoke when you start. Take the time to measure. Note: there should be a marking somewhere on the engine about the mixture.
Sep 21, 2014 | Craftsman Convertible 25cc Curved Shaft...
Need oil mix ratio for 25cc homelite gas trimmer
Hi anon the mix ratio is 50:1. That's five litres of unleaded and 100 ml of 2 stroke oil
Sep 10, 2014 | Craftsman 25cc Gas Line Trimmer
My weedWacker don't star I change the spark nothingh happen
Check age of gas. Cannot be more than 30 days old. Make sure to use fresh gas w/synthetic 2-cycle oil @ 40:1 ratio (1 gal.) Gas to 3.2 oz. Oil). Do not use old or stale oil/gas mixture. Always use the proper oil/gas mix. If you do not, your engine will suffer rapid, permanent damage. May need to clean or replace carburetor.
Aug 19, 2011 | Craftsman 27cc 2Cycle Full Crank Curved...
SEARS 25CC WEEDWACKER, 17" FUEL
all 2 stroke engines are 25-1 which means 25 parts fuel to 1 part oil the best way to measure this is to get a plastic pot thats allready marked you can get one from most dealers
hope this helps
John
Mar 31, 2011 | Garden
For a craftsman weedwacker a gas operated trimmer. my question is does it need oil?? (In the motor in the cylinder)
Yes it needs oil. you have to mix the oil with the gas.you will need too buy some 2 cycle oil.Mix it at 32:1.that would be 4oz. of oil to 1gal.of gas.
Dec 28, 2010 | Craftsman 25cc Gas Line Trimmer
Homelite 25cc 2cycle trimmer.built in March of 1999. what is the proper oil to gas ratio?
If you use a synthetic 2-stroke oil, you can easily get by running a 40:1 ratio mix...that is 3.2oz oil/gallon of gas. A richer oil mix won't hurt either (say 20:1 (2X the oil of 40:1). I recommend synthetic always be used alongwith Stabil fuel treatment because after about 30 days, gas loses its volatility and begins to breakdown without it...causing fuel problems.
Sep 11, 2010 | Homelite Garden
Need to know the 2 cycle oil to gas ratio for a craftsman 32cc weedwacker trimmer
My Craftsman 31cc 2-Cycle Gas WeedWacker Model C216.51318 manual calls for a Fuel Mix (gas:oil) of 32:1
Jul 11, 2010 | Garden
Would like to know the fuel mixture for this sears 25cc weedwacker
Most units call for a 40:1 fuel/oil ratio. That is 3.2 oz oil ( I recommend synthetic) to 1 gallon of gas. Some newer models may even recommend 50:1 to meet the more stringent EPA emissions standards (esp. in Cal.) buy you can't go wrong with the 40:1 mix.
Jun 13, 2010 | Craftsman Garden
Garden Logo
21 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
