Question about Sony (109480) Computer Speakers
Incorrect voltage input
I accidentally plug the 110 Volts source input into 220volts after that the speaker is nopt working anymore
  • 221 Answers
Check the fuse. Otherwise there's another fuse at the low voltage transformer itself. it will be covered with plastic tape on the primary winding of the transformer. Just replace it and enjoy your music
Good luck
Posted on Jun 23, 2009
  • 3,267 Answers
The power supply unit has got fried with the higher voltage. Get the power supply for the speakers changed..............sodeep
How to fix couple of DELL desktops where I plugged them into 220 volts Power supply when they were set for 110 volts? More details below.
you could try replacing the power supply. if it still does not work, you probably fried the processor or motherboard. (or both). just make sure the replacement power supply has the same type of connectors on the power leads to the motherboard, hard drive, etc.
Aug 15, 2015 | Dell OptiPlex Computers & Internet
Can i use 220v source to energizer charger chvcm4
you will need a reducing transformer 220volts to 120 volts, you can find one at Radio Shack or Fry's Electronics., European countries uses 220volts, and the plug configurations are different from those of the USA.it is recomended to take one of these transformers with you when you travel abroad.
Apr 13, 2013 | Energizer Rechargable Battery with Charger
I plugged 110 volts xbox 360 into 220 volts outlet. and it's dead. what will i do?
Unless the item has internal fuse, it is burned up.
Look for product manual.
Many times, there is a glass fuse rated for unit voltage.
Replace fuse.
Each fuse has specific markings.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Oct 17, 2012 | Microsoft Xbox 360 with Kinect
UPS does not supply power under 150~ volts
UPS will provide constant voltage out put.
The average working condition of UPS is 170 to 270 volt.
Below the level may not work.
Jul 20, 2012 | Computers & Internet
I accidentally plugged computer avr 220v to 110 could it affect my power supply
If the computer power supply is a 240 volt unit and you plugged into 110 volt mains the the computer should be OK.
Some power supplies have a voltage selection switch on the back of the power supply switch to 110 volts and it should work.
If the power supply is 110 volts and you plug it into a 240 volts mains then you will damage the power supply and possibly the computer as well.
Mar 14, 2012 | HP Pavilion a465w-b PC Desktop
My drier 110 volts was accidentally plugged to 220
The least of your problems would be a burnt out relay or internal switch which can be replaced at reasonable expense. In a worst case the motor or heating element "fried" and it'll be cheaper to buy a new dryer.
BTW 110 and 220 plugs are entirely different and a 110 plug cannot be plugged into a 220 outlet.
Apr 16, 2010 | Whirlpool LGR5636L Gas Dryer
I own a velleman K4040 6550B it requires 220Volts to operate but i would like to turn it to 110-120 Volts operation, any recomendations?
Rather than modifying the unit (which may not be possible), you should be able to locate a voltage transformer that will convert the 110 into 240. Many of these types of units utilize different power transformers depending upon the source voltage. If you'd rather not use an external transformer, request a source voltage change kit from Velleman. If they utilize different parts, the required parts will be included in the kit.
Dan
Sep 19, 2009 | Velleman Audio Players & Recorders
Accindentally pluged it to 220 volts instead of 110 volts
hello , i suggets you replace the power supply with a 110 v input boerd .
or do this if the damage is big replace the all sytem with a new one then get a voltage step down ie 220 to 110.
thank you
May 06, 2009 | Yamaha DVR-S120 DVD Player
Hcd bc150 main power
Please check Input Voltage 110 ~ 240 volts AC at rear or bottm side of unit. If same is written there, its Auto Voltage Operatable and can be use on 220Volts.
Aug 31, 2008 | Sony DAV-BC150 System
Sony (109480) Computer Speakers Logo
173 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
