Question about Beko Refrigerators
Were is the control bord cda539fw - Beko Refrigerators
How do i pass the controling bord
you can not do it .use you head .
Sep 29, 2015 | Refrigerators
Error 49.2F9D
the printer CB(control Bord) is detected change control Bord ather wise tern off and on
Jun 05, 2012 | HP LaserJet P3005dn Printer
I get an error F1 on this washing machine. What does this mean??
f1 means your rotor or main pc.b bord has a fault i would start by having the p.c.b control bord replaced there $ 120 in australia
Jun 21, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Unit will not shut when the thermostat is placed in the off position
is this a digital thermostat? if so this is the problem if not the control relay on the control bord is sticking (bad bord) this is a 150.00 fix...
Jan 17, 2010 | Intertherm P3RA-048K Air Conditioner
Maytag mde6800ayw dryer. no power at all. light works inside and im getting 220v. im told that there was a power outage and when it came back on the dryer was dead. im guessing the control board.
your guessing right then,,,
often if the power is cut off when its restored the sudden punch of power can blow the bords chips up,
its nothing new,, if they has a soft start it would not happen to them,,
sorry you need a new program bord
Oct 31, 2009 | Maytag Neptune MDE6800 Electric Dryer
The control circuit board for my toasteris cracked. I need to get a replacement. The no on the board is PCB016
if your realy handy with a soldering iron you could re-solder all the joints and put a bit of wire over them too, if the circuit bord is in two bits clue it together first then skrape off any paint oner the copper tracks that need to be solderd before soldering them together again its worth a try a new bord would cost more that a new toster?
Oct 30, 2009 | DeLonghi Classica CT14 Toaster
There is no sound!~please help~~
it hink u have sound mute problem check in multimidia key bord key on kew bord it mute or not.
Also check other program on which u play sound not mute sound.
Apr 06, 2009 | Computers & Internet
Range problem
the control bord may be bad or the receptical where the probe connects may be bad and grounding out agenst the body of the oven. I would remove the plug and make sure the wires are good and its not grounding out. If it checks out ok replacement of the control bord should solve the problem
Jul 19, 2007 | GE Profile JB968 Electric Kitchen Range
Refrigerators Logo
13 people viewed this question
Top Beko Refrigerators Experts
AJMAL KHAN
ray gallant
Are you a Beko Refrigerator Expert? Answer questions, earn points and help others
