Question about Samsung RS267LBBP 26.1 Cu. Ft. Side by Side Refrigerator with Twin Cooling System & CoolSelect Zone
Samsung schematic I have isolated a water leak coming from the plastic cooling coil that is used to cool the cool select zone drawer. Is this a common problem? Can I order the replacement and repair this myself?
5 Suggested Answers
dr appliance
  • 266 Answers
SOURCE: Our Samsung RF265AB (bottom freezer) is leaking
have a water tank or line leak for water dispensor
Posted on Jan 27, 2011
SOURCE: Water is leaking inside my
It maybe need some maintenance like cleaning the filter on the bottom, also check the position of the fridge it needs to lean backwards a little bit.
Posted on Feb 28, 2011
Testimonial: "Very helpful :-) will give it ago. Thank You :-)"
ginko
  • 19396 Answers
SOURCE: I have a Samsung RFG297AABP
Hi.
If the leak is not too big, then water comes from condensation. Water condensing inside the fridge is supposed to be conveyed toward the drain hole inside the fridge. From there the water should normally go to the drain try located in the compressor assembly.
What usually happens is that the drain hole gets clogged with frozen water, and the condensed water ends at the bottom of the fridge. The problem is fixed defrosting the fridge. In some sporadic case it is necessary to remove drain hole blockage using a thin and flexible drain rod.
Do a complete defrost, that should fix the problem.
Here all parts and diagrams for this fridge.
Regards.
Ginko.
Posted on Apr 15, 2011
  • 1116 Answers
SOURCE: Samsung RFG 297 has ice build up under the Cool
• Check if the set temperature on the digital display is too low.
• Try setting the refrigerator to a warmer temperature.
• Is the temperature in the room too low? Set the refrigerator warmer.
• Did you store the food which is juicy in the coldest part of the refrigerator? Try moving those items
to the other shelves in the fridge instead of keeping them in the colder areas or bins.
• Is the air vent blocked? Remove any obstructions so air can circulate freely.
• Allow sufficient space between the stored foods for efficient air circulation.
• Is the freezer drawer closed properly?
There is a ton of information regarding your fridge at the link below, including asking Samsung support questions and getting responses and assistance from their techs:
http://www.samsung.com/us/support/owners/product/RFG297HDBP/XAA#
In case of a problem or clarification or my solution was insufficient, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Posted on Jun 05, 2011
Why is water leaking into cool (deli) drawer?
Hi,have you got a drain at the back of the fridge just above the veg draw,if yes is there eney food above that that is tuching the back wall of the fridge above the veg tray,if so then the water that runs down the back wall will be going onto the food that it tuches and into the veg draw,hope this was some help,all the best.
Sep 16, 2015 | Refrigerators
Model #FFLE2022MW0 Frigidaire washer leaking water at bottom
pump housing cracked by coins or wires leaking
or rubber somewhere
if you isolate the water and waste and mains
the lay it over on the side away from the soap drawer
it wont leak
and you can access under it
and investigate where the water is coming from
bet you its the pump plastics cracked ,..
i would do this now dont use it for now
and fix it
this type of error can cost you a controller board ...
you can save lots of time by checking round the door seal of rubber issues inside its folds etc
but i still think its the pump or some rubber hoze loose
see in being one of the intakes or perhaps the drum from drawer rubber ... so
lay it over and check
no chance of fload if you lay it over on the side away from the drawer with the door closed
Apr 28, 2015 | Frigidaire Washing Machines
KFCS22EVMS leaked once made noise
Watch to see if 1) the water dispenser freezes 2) if you end up with ice build up. What you might have heard was a heater element pop. If that is what happened, then the cooling coils will freeze, no air will flow through the coils, and the freezer will not get very cold. If you can find a diagram of your unit, it may be worth taking a look to determine if the heater element is ok and/or if the cooling coils are packed with ice.
Oct 18, 2012 | Refrigerators
Samsung french door refrigerator ice maker no dispenser defroster leaking water into bottom and produce drawers
If it is a frost free unit the water collects in a well at the compressor , there is a heater element in the well that boils off the water , this is were the fault is.
Jun 04, 2017 | Samsung RF217ACPN - 20 cu. ft. French Door...
Water is leaking inside my fridge, which looks like its coming from underneath the Cool select zone, what could be the problem?
Feb 28, 2011 | Samsung Refrigerators
Car: honda CRV 2001 (2nd generation) my cooling coil is leaking. one guy told me if i want to replace that cooling coil, need to take out the dashboard first. so, i need the dashboard schematic that can...
cooling coil??? you mean the evaporator to the air conditioning. if it is leaking water onto the ground there is nothing wrong with it. changing an evaporator is a big job,and you must be certified to handle the freon. This one job that should be left to an expert. Plan to spend at least 900 bucks.
Oct 19, 2010 | 2005 Honda CR-V
Samsung rs21wcns has a leak
I found my leak, after checking all lines, connectors, couplers, behind the second to bottom drawer from what appears to be a cooling resevoir. It appears the seams are slightly leaking on both sides. I found water pooling under the bottom drawer and then leaking out the front and followed it back. My Samsung is model RS2556SH
Jul 04, 2008 | Samsung RB2155SH Bottom Freezer...
Samsung RS267LBBP 26.1 Cu. Ft. Side by Side Refrigerator with Twin Cooling System & CoolSelect Zone Logo
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
