Question about Tablets & eReaders
Proscan tablet plt7223g
The tablet turns on only when its plugged into the charger and i'm using a usb charger that can plug into the power outlet as the charger that came with the tablet has a shortage also when i'm using the tablet it will shut off and go back to the charging screen and sometimes when i'm playing the sims freeplay it will stick and the screen will got an array of colors displayed on it wont be responsive n shut off. then i will unplugg the charger n plug it back in to bring it back on and it will work sometimes but now it wont work its not even going to the charging screen
  • 24 Answers
SOURCE: TC1000 Stopped working
Whatever happened? Fixed? still not up? Trashed?
Posted on Apr 05, 2008
  • 394 Answers
SOURCE: Ii have the Coby 7005
Hi, I am Steve, lets help solve your issue.
I am afraid the information you have been given is completely wrong. There is not such thing as plug and play in the android world. Android was initially developed for use on embedded devices and as such had no need to recognise external devices automatically. Version 2.1 (as installed on your device) is now quite old and cannot support it. Even the new version (froyo -2.2) does not support it.
Your device does come with a built in wireless adaptor, so you don't need a USB wireless adaptor.
Posted on Jan 15, 2011
  • 39403 Answers
SOURCE: charger gets hot while plugged in and does not charge tablet. tablewt is dead wont turn on.
The battery may be unable to charge
Posted on Sep 29, 2012
SOURCE: fujitsu siemens stylistic M532 tablet not charging battery
I have just had same problem. Battery on M532 absolutely refused to charge from flat.Tablet worked when plugged in so I downloaded an app killer from android market and killed all but the essential apps then tried again and it seemed top work! Maybe background apps draining battery at faster rate than could be charged?
Posted on Feb 20, 2013
  • 183 Answers
SOURCE: I have an Asus Memo Pad HD 7 which I purchased 3
the more programs you install and run in the back ground the more the battery is drained. It comes to a point where there are so many programs running the gadget cannot run & charge at the same time. It might charge better if you uninstall a lot of programs or do a factory reset but that is drastic
Posted on Oct 30, 2013
Testimonial: "I did do a factory reset but the icon is still not showing and it still is slow at recharging. I didn't really have many programs anyway, a few simple card games, crossword puzzles and some weather apps. Right now, I think I have maybe 4 simple apps on the tablet and it is still not charging when on. I checked the battery status in settings and it says "not charging". However, if I turn it off and then plug it in, a red battery indicator shows it as charging."
I CANNOT CHARGE THE TABLET THRU EITHER PORT- THE REGULAR CHARGING PORT OR THE USB PORT THAT I FOUND ALSO CHARGES IT. WHAT COULD BE WRONG AND WHAT ARE POSSIBLE SOLUTIONS?
could be software issue reset it would fix it:?
damage to ports both broken sounds unlikely
try usb plug into a different computer
the cables inside the tablet are loose or not connected
check for damage to ports and loose connections inside device
Jun 29, 2015 | Proscan PLT7223G 7" 4 GB Wi-Fi Black...
WHAT DRIVERS DO I NEED ON MY LAPTOP, SO I CAN CONNECT TO MY LAPTOP AND TRANSFER MUSIC, FILES, ECT...!
Here is link to manufacturer download pages for PLT7223G models.
You may need additional code numbers
http://www.proscanvideo.com/products-search.asp?itemnmbr=PLT7223G&Submit1=search
Drivers are generally USB and would be computer operating system dependent. ( Android devices use "ADB" ).
Hope this helps
May 08, 2014 | Tablets & eReaders
PLT7223G power pin broken
Try charging it with the USB cable from the computer. It could be your charger pin is faulty. This happens from frequent in and out charging. The pins on the charger tip get worn out. If it charges with the USB cable then get a new charger.Charging from the computer is slower but it works.
Mar 03, 2014 | Proscan PLT7223G-K 7in Android 4GB Tablet...
Tablets & eReaders Logo
43 people viewed this question
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
