Question about Jandy Laars LX Pool Heater / 400,000 BTU / Natural Gas
How to replace a raypak 405a burner tray? - Jandy Laars LX Pool Heater / 400,000 BTU / Natural Gas
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Jandy Master
  • 1,448 Answers
Remove gas line then remove screws to the bottom front it should pull out
Posted on Nov 06, 2014
What holds the burners in the burner tray in my rapak pool heater?
there are mounting screws at bottom of burner tray
Aug 14, 2014 | Raypak Pool & Spa
How do I remove my Raypak 406 elec. burner tray?
turn the gas off at manual shut off valve. undo the union in gasline. remove gasline from the gasvalve. undo the hex screws that support the bottom of the burner assembly. undo the support screws around gasvalve to the firewall. slide the burner assembly out
Aug 05, 2013 | Raypak Pool & Spa
The burners on the left side of my burner tray do not come on? Getting out the burner tray seems difficult. What should I do?
Has water from rain or sprinklers gotten on the heater? Sounds like one of the following:
  1. Plugged burner orifices
  2. Plugged burners
  3. Low gas pressure
  4. Bad gas valve
  5. Poor venting
Your best bet is to remove the burner tray. It really isn't that difficult. Follow the owners manual. If you do this yourself, be sure to leak test all gas fittings.
Jun 26, 2010 | Raypak BURNER TRAY W/VALVE NAT 335
Rol symbol and a service notice
This indicates the flame roll out safety switch is bad. This part is usually mounted right above the burner tray. It is a white ceramic piece with two wiring terminals and an external part that looks like a resistor. This part detects flame/heat coming out from the burner tray. When replacing it, be sure to check for blockage at the burner tray, heat exchanger and the flue if vented with duct work. This is a critical safety device so do not bypass it.
Jun 19, 2010 | Raypak Free Hydraulic Lift Gate Delivery -...
ROl Code is on, and heater won't fire
Jun 19, 2010 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
Service code ROL raypak pool heaters p-r-266a-en-c
May 29, 2010 | Raypak 130,000 BTU Propane Gas Pool...
Back flare on Raypak pool heater
You will need to pull the burner tray out and clean and blow out the burners. Then you will need to pull the orfaces from the gas manifold and clean each one and blow out the gas line. Then with a mirror you will need to check the fire brick inside the burner box. Then you will need to replace anything that is damaged. Good luck.
May 15, 2010 | Raypak 130,000 BTU Propane Gas Pool...
I HAVE A RAYPAK VERSA, PILOT IS ON , BURNERS DONT COME ON
check mv output of thermopile ,unless you have 350-500mv it is not enoughvoltage to power valve
Jun 07, 2009 | Raypak BURNER TRAY ASSEMBLY
I have a raypak heater with robertshaw 7000 gas
Remove the wires from the gas valve and call for it to light. While it is trying to light, take a voltage reading on the wires that go to the valve. If it is sending voltage to the valve and it won't energize the valve then the valve is defective. Just make sure that the valve is being told to come on. It could just be a limit switch. Double check the manual reset limits also before doing the vavle check. Hope this helps.
Mar 21, 2009 | Water Heaters
Jandy Laars LX Pool Heater / 400,000 BTU / Natural Gas Logo
37 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Pj Kiley
Pj Kiley
Level 1 Expert
Bill Jordan
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
