Question about Kenmore 62802 Electric Dryer
I have a Kenmore Electric Dryer Model 66812. The motor runs, but the heat doesn't come on ... so it's not drying. What's wrong? Is it worth fixing? Estimate to fix?
  • Kenmore Master
  • 5,323 Answers
ELECTRIC Dryer no heat or little heat:
Check your venting and lint basket. Check blower for lint build up and blower wheel obstruction., test by trying to turn the wheel manually by hand (should be easy) May have to remove cabinet or front/back plate to get to it)
Next check the heating element itself with a meter for continuity OHMS CLOSED CIRCUIT. If not its defective.
Check dryer Terminal block prongs both outside prongs should give combined 220, and 110 each if u check 1 outside & 1 center (ground) prong. Also check house electrical outlet for full voltage. 220 because if u only get half or 110 volts you will be able to run the machine which uses only 110 to run motor but not the heater which uses a full 220,
Check the thermal cut off, the cycling and the hi limit thermostats.
For continuity or OHMS. If no ohms or resistance they need replacement.
Lastly check your moister sensor. ( located inside the dryer door usually) Especially if machine seems to shut down early and clothes are still wet.
Test with a meter at room temperature and it should show continuity.
Posted on Mar 31, 2015
SOURCE: Kenmore dryer (electric )
NOT ELITE HE4..... Model 96595400. Replaced thermistor and Hi-Limit Stat. Probably the thermistor.
Posted on Jun 29, 2008
  • 686 Answers
SOURCE: Kenmore 70 Series Dryer Model# 110.64742400
check the thermal fuse if it is blown also change the high limit thermal cut-off fuse www.repairclinic.com shows your parts. go there and enter model number. Also check the heat element. to get into it remove the lint filter and the two screws you'll see there then pry the top up at the front corners. And through the back you should find the heat element and blower housing and thermal fuse and high limit fuse and cycling thermostat.
Posted on Apr 06, 2009
  • 97 Answers
SOURCE: kenmore electric dryer (model # 110 60202990)
Hello Friend, Your problem is very simple to fix. You need a thermal fuse, very simple and affordable to replace. To replace the thermal fuse just remove back cover of dryer and look down where the air blows out. Now, just to the left where all the wires are you will see a white plastic part with two wires plugged into it. This part is called a thermal fuse. Just remove these wires and replace the thermal fuse. Your dryer will run like new. Happy to help, Tim.
Posted on Jun 25, 2009
jsrock516
  • 5911 Answers
SOURCE: Kenmore electric dryer. No hot air. Drum spins
If the dryer runs, but does not heat, the following link explains how to troubleshoot an electric dryer with a no heat problem:
http://www.fixya.com/support/r630242-dryer_runs_but_not_heat
First, begin by unplugging the dryer and verifying the voltage at the wall receptacle. You should read 220-240VAC across the two Hot terminals (left and right slots). If the voltage is incorrect, check to make sure you don't have a breaker tripped. Some homes use 2 separate 120VAC breakers to provide power to the receptacle vice using one 240VAC breaker.
If the voltage IS correct, leave the dryer unplugged and remove the cover plate on the terminal block in the back of the dryer (this is where the power cord is installed). Plug the dryer back in and take a voltage reading across the two hot (RED and BLACK) wires at the terminal block. You should read 220-240VAC. If the voltage is good, you have an internal heating problem. If the voltage is bad at the terminal block, but good at the receptacle, you have a bad power cord.
NOTE: If the wires at the terminal block are not color coded, the outer two wires (left and right) are the hot leads. The center conductor is neutral or ground.
The reason a dryer will still run if the input voltage is incorrect, is because the drive motor only uses a portion of the 220 service. The motor runs off 110-120VAC, while the heating circuits require 220-240VAC. So, if you are missing 1/2 your input voltage due to a tripped breaker or bad power cord, your dryer may exhibit these symptoms.
If you determine the problem to be internal, the heating circuits will either be located in the rear of the dryer on the right hand, or under the dryer drum on the right hand side. Usually, an easy way to determine is by the location of the lint screen filter. If the filter is on top of the dryer, the heating circuits are in the back of the dryer. If the lint screen is in the door, the heating circuits are located under the dryer drum.
All dryers are not constructed the same. However, the Heating Element is located inside a heater box. The Thermal Cut-Out (TCO) will be located on the outside of the heater box on the end opposite the heating element terminals. The Hi-Limit Thermostat will be located adjacent to the heating element terminals.
If either the TCO or Hi-Limit Thermostat are determined to be bad, replace BOTH components at the same time. That is why these components are commonly sold as a set. Failure to do so may result in premature failure of any parts you replace.
Replacement parts can be found at appliancepartspros.com, searspartsdirect.com, pcappliancerepair.com, or repairclinic.com. The average cost of these components varies, so shop around for the best price.
The heating circuitry is usually located under the "Bulkhead Parts" section.
If you have any questions, or require additional assistance, please post back with your complete model number (usually located on a nameplate around the door opening) so that I may be able to provide you with better assistance. I hope you find this helpful.
Posted on Nov 10, 2009
marka19
  • 1430 Answers
SOURCE: 80 series kenmore electric dryer runs but no heat
This could be the heating element or several other parts more likely the thermal fuse. There is a video on troubleshooting a similar model at www.appliancehelponline.com/servicemanual.html this will walk you thru troubleshooting your problem.
Posted on Mar 28, 2010
11076812693 drum won't turn.
Kenmore Dryer Model 110.76812693 (11076812693) Drum ...
www.repairclinic.com/.../Model-11076812693-Kenmore-Dryer-Drum-T...
Kenmore Dryer Model 110.76812693 (11076812693) Drum & Tub Parts in stock. One million parts for 125 brands. Guaranteed same-day shipping. Call 7 days ...
Kenmore Dryer Model 110.76812693 (11076812693) Motor ...
www.repairclinic.com/.../Model-11076812693-Kenmore-Dryer-Motor-...
Includes pulley for dryer drum drive belt. Other shaft has reverse threads for blower wheel. Common symptoms of a bad drive motor are: -Dryer stops turning ...
Kenmore, Whirlpool Dryer Repair - Heats properly, drum will ...
? 6:29
https://www.youtube.com/watch?v=bOShDc4kLfk
Jul 10, 2013 - Uploaded by ApplianceVideo.com
Service a Kenmore Dryer with some of the following issues: Heats but ... Kenmore, Whirlpool Dryer Repair - Heats properly,drum will not turn - 11068202794 ..... Whirlpool Kenmore Maytag Amana Dryer Won't Start - Easy Fix ...
How To Fix Dryer That Won't Tumble ' Dryer Repair
www.partselect.com/Repair/Dryer/Will-Not-Tumble/
Feb 08, 2016 | Kenmore Dryers
Kenmore electric dryer won't dry clothes. The
What is the model number of your unit?
Nov 17, 2012 | Dryers
I have a kenmore elite model #110.95088400 that doesn't heat when drying. I checked the thermal fuse and it goes to continuity. I checked the hi limit thermostat and it was continuity, the thermistor...
Hi,If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly.if you dryer is gas check out this gas no heat tip....If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 24, 2011 | Dryers
I have a Kenmore Stackable washer & dryer Model # 417.93702200 and my dryer will come on and spin but it doesn't get any heat to dry my clothes. what could be the problem? Where can I get the...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 19, 2011 | Dryers
I have a kenmore elite, model# 11062952100. Everything works fine but there is no heat on any cycle. it is about 5 years old. Whats wrong, cost to fix, is it worth fixing
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Dec 28, 2010 | Kenmore Dryers
I typed in 66812 not the number that is showing - I need to know what receptacle to use with the Kenmore 66812 electric dryer. Thanks for any help you can give me.
on the front of dryer open the door there should be a tag or on the rear where the cord goes into the dryer there should be a tag to tell you what the voltage is
should be a 250 volt plug and outlet to match
nema # plug-S42 AND THE OUTLET # 6-30 OR 6-50
Oct 17, 2009 | Kenmore 62602 Electric Dryer
Kenmore dryer. Heats up intensely
Hi, It's an over heating motor that's cousing the thermal switch to trip, on the motor.
Motor retails for $150.
Labor for putting it in is $90.
It might just be worth replacing it.
Sorry for the bad news :(
Best of luck.
Sep 13, 2009 | Kenmore 64902 Electric Dryer
Dryer wil not spin
Hope this info helps, ps don't forget to give me a rating thanks!!
For an electric dryer that runs but doesn’t heat, follow this repair roadmap:
Flip the circuit breaker off and then back on. Electric dryers run on a two-pole, 240v breaker. A common problem is for one of the legs to break which cuts the 240v that the elements need to heat up but it still supplies the 120v for the motor. The result is that the dryer runs but doesn’t heat.
If the breaker checks out, then it’s time to do some surgery. Unplug the dryer and open it up.
. Use your ohm meter to test the thermostats. All should show continuity.
Measure the resistance of the heating element with your ohm meter. Normal readings are in the neighborhood of 30 ohms.
In rare cases, the centrifugal switch in the motor can fail which breaks the power circuit for the heating elements. If this is the case, then the entire motor must be replaced since the centrifugal switch is built into the motor.
May 08, 2009 | Dryers
I can hear it running--but it doesn't spin
your belt is broken the heat should still work.
Aug 29, 2008 | Kenmore 62802 Electric Dryer
Motor runs, but no spin on Kenmore front load dryer
more than likely your belt has come off there is a panel in back remove it and look inside now the wheel that keeps the belt tight has a habit of coming off if some yahoo didn't put it on right find it and look for two slots in the floor of the drier it slips into put it in the slots and pull it down then put the belt on top of it should fix the problem
Jan 01, 2008 | Kenmore 62802 Electric Dryer
Kenmore 62802 Electric Dryer Logo
80 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
