Question about Pride Celebrity X 4-Wheel Electric Scooter
My golden companion mobility scooter goes one slow speed only
2 Suggested Answers
eanday_com
  • 923 Answers
SOURCE: I have a Go-Go & Pride Travel Mobility Scooters and get a Speed Pot error. Where do I buy a Speed Pot with Harness for Go-Go & Pride Travel Mobility Scooters in Canada?
Hi again ring 888-570-1113 pride spares in canada. MONSTER SCOOTER PARTS PHONE ..800-798-0325 .cheers
Posted on Oct 25, 2016
Testimonial: "The problem with Monster Scooter parts is that it's from toe U.S. therefore S&H is almost 3 times of the product"
GOLDEN COMPANION SCOOTER HAS NO POWER TO MOTOR UP EVEN VERY SLIGHT GRADES OR HILLS
If batteries are ok. I would check motor brushed. Make sure they are long enough. Clean and make sure they don't stick. Check colour of comm in motor. Check all connections are tight.
Oct 05, 2014 | Golden Technologies Companion II 3 Wheel...
My golden companion 2 Gc 321 goes forward when i push reverse and goes reverse when i push forward
Sounds like the motor cables are in reverse at the controller. Check that the red is in the positive and the black wire is in the negative on the controller.
Aug 12, 2014 | Golden Technologies Golden Companion 2 -...
Where can I get a replacement key for my golden companion 2 scooter? Mine is lost
You could use the search function on the Golden Technologiesto find your nearest dealer:
http://www.goldentechdealer.com/
or you might try contacting the Golden Technologies Technical Support Center directly at 1-800-624-6374 to inquire about a replacement key for your scooter.
May 22, 2011 | Golden Technologies Companion II Travel...
My Golden Companion II scooter had to be left out when it rained - I went camping - and it stopped running. Then, a little later, when it had thoroughly dried out, it ran sporadically. Now, it doesn't...
Hi. Most speed problems on scooters, can be the throttle pot ( wig wag ), or the motor brushes.
Also check all battery lead connectors, and the motor lead connectors.
While you are driving along, try moving the speed lever slightly up and down, not in and out as you normally do. If the speed changes, it is probably a faulty pot.
Do you have a high/low switch, or an indoor/outdoor switch that changes the speed? These sometimes cause speed changes. You can fit a new switch or by-pass the switch, and have it on high all the time.
Good luck. Neil.
Jun 15, 2010 | Golden Technologies Golden CompanioN II -...
Golden Companion Scooter not moving - diagnosed via owner manual
Hi. Many scooters will display this fault code if the potentiometer is not exactlly centred when you turn on the key. The pot is not always faulty. Some scooters also have a smaller additional pot to controll the speed. If this pot is faulty it will cause the same fault code. Any other switches such as indoor/ outdoor switches. I have had a few machines fitted with curtis controllers where the fault is in the controller.
Check the wiring and plugs and connectors.
Good luck. Neil.
May 09, 2010 | Golden Technologies Companion II Travel...
Not moving and green light is flashing
this is batteries
if slowed down first then stopped
mobility centre penge
Apr 14, 2010 | Golden Technologies Companion II Travel...
Golden Tech Companion II: Doesn't go, batteries
Accessibility Specialists Inc
1815 Corporate Sq Blvd
Ste 200
Jacksonville, FL 32216
(904) 725-0601
Nov 21, 2009 | Golden Technologies Companion II Travel...
Moving problem
More than likely its the speed pod or engager (paddle assy. This would need to be replaced.
Jun 26, 2009 | Golden Technologies Companion II Travel...
Golden companion 2 scooter moves slow in reverse
i would suggest there is either a loose connection or the speed control has failed, the scooter will still run but at a slow speed, the part is fairly standard in all scooters. if i can be any furthur assitance please email me rick @ lxrixta.co.uk (remove the spaces)
Mar 23, 2009 | Golden Technologies Companion II Travel...
Pride Celebrity X 4-Wheel Electric Scooter  Logo
50 people viewed this question
Top Pride Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Colin Taylor
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
