Question about Jabra GN9350e Wireless Headset
Jabra GN9350 fast busy - Jabra GN9350e Wireless Headset
2 Suggested Answers
shanks_simon
SOURCE: jabra gn9350 base lights are not coming on.
There are a number of steps you can try to fix this issue:
1. Confirm the power supply is plugged in correctly, and the power socket to which it is connected is turned on and receiving power.
2. Remove the battery from the GN9350 headset and ensure the copper contacts on the battery and the headset itself are clean - a quick blow on both parts will be OK. You remove the battery by taking off the earhook or headband, and sliding the speaker section down towards the microphone boom - it will unclick. Reconnect the battery after you've blown on the contacts and re-pair the device as per step 3.
3. Re-pair the headset to the base: ensure the headset is docked in the base. Locate the button with two grey arrows pointing towards each other which is located on the side of the circular base section. Hold this button down for approximately 5 seconds, until you see a blue light flash on the headset itself - you can release the button once the light flashes. The headset is now paired again.
4. If the lights are still not showing up you may have a faulty battery, or a faulty headset/base.
Posted on Oct 31, 2012
Is the rechargeable battery in the Jabra BT500 replaceable?
  • jabra headset battery swap - YouTube www.youtube.com/watch?v=MMLocSWjq8Q
    • BY THEDIECLAN2004
    • 3 MIN
    • 24K VIEWS
    • ADDED 2011-12-10
    Video embedded · jabra headset battery swap theDIEclan2004. Subscribe Subscribed Unsubscribe 15 15. Loading ... Plantronics Pro battery replacement - Duration: 9:15.
  • Jabra BT500 Bluetooth Headset - Newegg.com www.newegg.com/Product/Product.aspx?Item=N82E16826552001
    • 4/5
    • 69 REVIEWS
    Buy Jabra BT500 Bluetooth Headset with fast shipping and top-rated customer service.Once you know, you Newegg!
  • Jabra SPORT Bluetooth Battery Replacement - YouTube www.youtube.com/watch?v=Sm8cSkyTmfA
    • BY GREG PAJAK
    • 2 MIN
    • 27K VIEWS
    • ADDED 2013-09-23
    Video embedded · A quick video showing the ease of replacing the battery in the Jabra Sport bluetooth headphones. Jabra says when it it out of warranty they cannot be ...
  • Jabra BT-350 Disassembly and Repair - Instructables www.instructables.com/id/Jabra-BT-350-Disassembly-and-Repair Intro: Jabra BT-350 Disassembly and Repair. I wooted a few of these dandy devices a while back and they work great but the volume buttons are weak and the solder ...
  • Jan 26, 2016 | Jabra BT500 Wireless Headset
    Auto connect/disconnect
    Hi. To turn Voice Guidance off, press the Option button. To find the settings, press up or down slowly until you hear a beep. Press OK to enter the voice guidance menu. From that his menu: Voice Guidance On/Off: Use arrow keys on remote to toggle on and off. NOTE:This menu is spoken even when voice guidance is turned off.
    Read more: Turn off voice guidance Jabra extreme 2? - Software to turn off voice guidance of jabra extreme 2 :: Ask Me Fast at
    Jun 14, 2013 | Jabra Extreme2 Bluetooth Headset
    Jabra gn9350 base lights are not coming on.
    Aug 30, 2012 | Jabra GN9350e Wireless Headset
    Pin # i need
    Jabra Bluetooth pin code is generally 0000. If this does not pair your device, please respond with the specific model.
    Jan 19, 2011 | Jabra Bluetooth?® Business Headset...
    Jabra GN9350e - my voice echo's back to me but the user hears me fine, is there any way to change the feed back?
    Here's what fixed it for me (running Windows 8.1 on a Surface Pro 3):
    1. On your taskbar, right click on your volume control options (the little speaker icon), and choose "Recording Devices." ALTERNATIVE: You can also get there from Control Panel, searching for "sound" and selecting "change sound card settings," then go to the "recording" tab.
    3. Right click on the GN9350 and select "Properties."
    4. Go to the "Listen" tab.
    5. Unclick the "Listen to this device" checkbox.
    6. Save and exit.
    Oct 28, 2010 | Jabra GN9350e Wireless Headset
    My GN9350 is not recognized at all under Windows 7 (it was however, under Vista)! Where do I find the drivers for a proper installation?
    Early GN9350 models are not compatible with Windows 7. The usb audio device driver for Windows 7 requires signed drivers, but the original GN9350's are not compatible as the drivers are hardcoded in the firmware.
    I was able to confirm this with Jabra support. The option they offered me was to send in my existing unit and they would replace it with a new (likely refurbished) newer model for $110. I've sent it in as that is still a lot less thana new unit.
    Dec 09, 2009 | Jabra GN9350e Wireless Headset
    GN 1000 lifter/GN9350 headset with Nortel NTDU92 phone
    I was wondering if you had installed the external ring sensor, this sensor most be over the telephones speaker, if the speaker isn't under the handset. hope this can help.
    Feb 19, 2009 | GN Netcom GN 9120 Professional Headset
    Sigamtel S4 and Jabra BT125
    SET YOUR BT125 JABRA  in pairing mode then try to seek in mobile
    or reset your mobile
    Sep 16, 2008 | Handmark Software MobileLists (950142) for...
    Jabra BT350 Bluetooth Headset
    This is what I did:
    1. open the headset by following these steps:
    http://www.instructables.com/id/Jabra-BT-350-Disassembly-and-Repair/
    2. measure the voltage of the battery. If it is too low, the internal charger circuit may not like it. Mine was 2.6v.
    3. Charge the battery "manually" by connecting to 3 serially connected rechargeable batteries (final voltage should be around 3.7v). Three NiMH AA batteries are fine.
    4. Reassemble and hope your headset is back to business.
    May 10, 2008 | Jabra BT350 Bluetooth Headset Headset
    Jabra GN9350e Wireless Headset Logo
    Top Jabra Radio Communications Experts
    TO Lady
    Greg Cann
    Greg Cann
    Michael Vincent Cruz
    Are you a Jabra Radio Communication Expert? Answer questions, earn points and help others
