Question about Hozelock 2490 Auto Reel 20m Hose 12.5mm
Hozelock auto reel - Hozelock 2490 Auto Reel 20m Hose 12.5mm
4 Suggested Answers
SOURCE: Hozelock Auto Reel
I took it apart by unscrewing the 2 halves of the plastic cover making sure the hose was fully wound up as the spring mechanism can be dangerous. Extreme care must be taken. I can now get lubrication on to the spring. The manufacturers will not tell you how to do this due to health and safety rules.
Posted on Sep 30, 2008
SOURCE: how do you assemble 2in1 hozelock wall mounted
how do you assembly the 2in1 hozelock compact reel
Posted on Jun 16, 2010
  • 2910 Answers
SOURCE: my hozelock auto reel is only retracting 90 percent of the way in, how do i fix this?
This sort of problem affects all sorts of retractable things as they age - tape measures, vacuum cleaner cords, car seat belts...
Mostly such things contain a very long flat steel spring that is coiled inside and pulling out the hose, tape measure, etc. coils the spring more tightly storing energy to rewind when needed. Unfortunately few such designs use a spring that is strong enough to overcome the additional friction that accumulates with age and use. Lubricant applied when new loses effectiveness, smooth surfaces become less smooth and use produces dust that has a further negative effect and things like cables and hoses lose flexibility and smoothness meaning they need more power to rewind effectively.
Over the years I have variously taken such items apart to clean, lubricate and retension the spring. Sometimes I have drilled a small hole in the casing to the spring chamber and sprayed a lot of WD-40 in there while working the mechanism. With seatbelts and cables I find a dry silicone spray to make the belt or cable and it's guides slippery works well without disturbing the spring.
My final advice is if you remove the cover of the spring chamber always keep at least one hand on the spring. Do not put it down and do not let it go or you could believe for a second you are being attacked by an angry cat and rewinding those springs by hand is hard and tedious work...
Posted on Mar 23, 2017
My hozelock auto reel has stopped locking. Have tried pulling it all the way out and then releasing but it does not solve the problem.
40 meter Hozelock auto reel would not lock when winding back into the drum.
1, Make sure the Hozelock hose has fully retracted into the drum.there should be no tension on the hose reel spring.
2, Use a Black & Decker Workmate.
3, Carefully opened the side cover taking out all of the Torx screws (10 in total) remove handle.
4, Turned the reel over and placed the auto reel onto the Black & Decker Workmate.
5, Placed a socket into the Workmate vice then line up the centre shaft bolt on the auto reel onto the socket, this will hold the steel spring in place so that I could undo the 2 security Torx screws. Slowly remove the 2 screws- there will be a little spring tension when removing the 2 screws, take care.
6, Lever up the centre shaft up out of the reel to expose the internal hose reel, take note the rotation of the plastic cog inside the cover.
7, Remove the brake locking arm from the side cover.
the arm had broken in half, I used a soldering iron to weld the two halves of the brake lever back together.
8, Rebuild in reverse order.
8, When rebuilding the auto reel use the ratchet and socket to tension the steel spring, I unwound the hose out of the drum then slowly wound the spring using the ratchet and socket. This wound in the hose onto the drum up to the hose stop then a couple more turns on the ratchet for a little more tension.
9, Whilst holding the ratchet keeping the tension on the spring. Replace the 2 security screws on the centre shaft .
10, This link on Youtube I found very helpful (46 sec into video) you can see the internal working and the brake lever.
Apr 24, 2015 | Hozelock 2490 Auto Reel 20m Hose 12.5mm
Auto reel will not rewind anymore
then you will have to repair it the spring has no doubt broke
Mar 22, 2015 | Garden
How can I fix a hozelock hose reel that has been pulled out too much and jammed?
you have to take the cover off and redo the hose you can re reel back in
Jul 19, 2014 | Hozelock 2490 Auto Reel 20m Hose 12.5mm
Hozelock
There is usually a retensioning screwdriver slot at the center of the back., you have to take off a small cap at back.
Jul 09, 2013 | Garden
How can i fix a leak inside my hozelock auto reel
adcccc13-7653-4a1a-83fe-508669c9a82e.jpg3187e97b-8b8e-4ed3-a2a0-0cad5211d982.jpg94e5325e-ed0d-4067-ba2e-15c982ded717.jpg350c6d53-8941-4e5f-937d-9425b18f4c89.jpgb9a1ffa9-99fa-4f32-9be1-717dd9251c09.jpg961cd592-0df3-420b-b7df-1b0ff17df252.jpg79809fc2-3e1f-4099-a3c7-00615892aa40.jpgd539f880-39af-40f4-850d-ad70e7f5948f.jpg7ce9923d-118a-4f30-9f13-20afc72d3ee9.jpg6d0fe000-779a-4d41-b1cc-81a243223d36.jpg2123ca49-4e92-4d43-a6cb-d6dab2644c3d.jpg9bcb85f0-f600-42e0-a249-d54524038b72.jpgea7bcfd2-840a-4496-a010-53e4229d922a.jpg6b9a17a9-5cc9-4ef8-8b28-3ddaee1a2172.jpgf3a3c78c-6856-4c78-bf68-90484825b7a0.jpgJust replace the O-rings inside. See pictures how to take it apart.
Jun 01, 2012 | Hozelock 2490 Auto Reel 20m Hose 12.5mm
Lost return tension when replacing hose
Where can I get a replacement tension spring for my auto reel hoselock 2490 ? I have tried everywhere but without success. Any help is much appreciated
Mar 19, 2012 | Hozelock 2490 Auto Reel 20m Hose 12.5mm
How do you assemble 2in1 hozelock wall mounted compact reel
Mar 10, 2010 | Hozelock Garden
Hozelock Auto Reel
Sep 29, 2008 | Hozelock Garden
Hozelock 2490 Auto Reel 20m Hose 12.5mm Logo
Top Hozelock Garden Experts
richie46
Bill Boyd
Vernon Taylor
Are you a Hozelock Garden Expert? Answer questions, earn points and help others
