Question about Chamberlain CLLP1 Laser Parking Accessory
What is the dc input for the Chamberlain CLLP1 Laser Parking
    Scholar:
  • 86 Answers
On the back of the motor unit. These laser parking units work with the Chamberlain Liftmaster openers and function when the door is actuated. If you do not have a Liftmaster unit, the lser unit may not work. You need to look at the back and see where the slots are for the output; they are clamp type and there are several sets, one for the door sensors and another for accessories such as this.
Posted on Nov 23, 2014
Error Code: E197 0000 in cannon 2900 printer
Printer engine communication error
Erroneous communication between the DC controller PCB and image processor PCB was detected.
- Check the connectors of the DC controller PCB and image processor PCB.
Replace the DC controller PCB for normal connection. - Replace the image processor PCB.
E197 0000 Laser Driver PCB communication error
Description :
Description Error in communication with the Laser Driver PCB (communication data failure)
Causes :
Solutions :
Remedy
1. Check the Laser Scanner Unit connector.
2. Replace the Laser Scanner Unit.
3. Replace the DC Controller PCB (PCB1).
Nov 16, 2017 | Cannon Office Equipment & Supplies
Can a Chamberlain CLULP1 laser parking assist be made to work with a Genie Garage door opener
I don't see why not. Im sure if you plug the black and white wires accordingly it should light up. There isn't any programming involved so it maybe possible. It may not work like it should but idk ive never tried it before.
Jan 27, 2016 | Building Materials
Erreur 100
error 100 ia for
When the scanner motor is started up, the BD input signal does not arrive within a specific period of time.
When the scanner motor is started up, the motor rotation is too fast, and fails to reach a specific revolution within 20 sec at time of deceleration.
While the scanner motor is rotating at a specific speed, the BD input signal cycle is not within a specific range (±2%) for an equivalent of 10 mm (print distance).
While the scanner motor is rotating at a specific speed, the BD input signal cycle is not as indicated (±2%).
During the WMUPR period after the power switch has been turned on or the front cover/left cover has been opened/closed, the drum unit is absent.
Possible cause: The wiring is faulty (short circuit, open circuit). The laser scanner unit is faulty. The DC controller PCB is faulty. The drum unit is not installed.
Nov 26, 2010 | Canon imageCLASS D680 Laser Printer
IMAGERUNNER 2000 SYSTEM E100
This can be caused by the following....
*When the laser scanner motor is started up, the BD input signal does not arrive within a specific period of time.
*When the scanner motor is started up, the motor rotation is too fast, and fails to reach a specific revolution within 20 sec at time of deceleration.
*While the scanner motor is rotating at a specific speed, the BD input signal cycle is not within a specific range (±2%) for an equivalent of 10 mm (print distance).
*While the scanner motor is rotating at a specific speed, the BD input signal cycle is not as indicated (±2%).
*During the WMUPR period after the power switch has been turned on or the front cover/left cover has been opened/closed, the drum unit is absent.
Possible cause:
  • The wiring is faulty (short circuit, open circuit).
  • The laser scanner unit is faulty.
  • The DC controller PCB is faulty.
  • The drum unit is not installed.
Remedy
1) Drum unit
Is the drum unit installed in host machine?
NO : Install the drum unit.
2) Connection
Is the connection of the connector (J908) on the BD detection
PCB, connector (J907) of the laser unit, and connector (J102) on
the DC controller PCB normal?
NO : Correct the connection.
3) Laser/scanner unit, DC controller PCB
Try replacing the laser/scanner unit. Is the fault corrected?
YES : End.
NO : Replace the DC controller PCB.
Apr 15, 2010 | Canon imageRUNNER 2000 Copier
I got canon ir1600 i am receiving an error msg as error 100
as sm -
E100
distance).
Possible cause
Remedy
1) Drum unit
2) Connection
YES : End.
Jun 04, 2009 | Canon ImageRunner 1600 Copier
How to add additional garage door opener safety sensor
cant be done. put parking bumper on flor so you know you pulled in far enough. you are only one I know who installed parking laser. I don't. If customer isnt home when I install gdo, how do I aim laser. What about when they get new car. They want you back for free to adjust, No way.
Nov 24, 2008 | Sears Craftsman LiftMaster Chamberlain...
52 scanner error
HP LASER PRINTER ERROR CODE 52 – INCORRECT SCANNER SPEED ERROR
HP LASER PRINTERS 2, 2D, 3, 3D
1. Defective cable laser scanner to dc controller.
2. Defective laser scanner assembly.
HP LASER PRINTERS 2P, 2P+, 3P
1. Bad scanner motor.
2. bad dc controller.
HP LASER PRINTERS 3SI, 4SI, 4V
1. Faulty cable assembly.
2. Scanner motor problem.
3. Defective laser scanner assembly.
4. Defective dc controller.
HP LASER PRINTERS 4, 4+, 5
1. Faulty laser scanner cable.
HP LASER PRINTERS 4L, 4P, 5P, 5L, 5SI
1. Temporary error. Scanner startup failure.
2. Improperly fitted scanning assembly.
3. Scanner cable problem.
4. Defective laser scanner assembly.
5. Defective dc controller board.
HP LASER PRINTERS 1200, 2200, 3100 FAX, 3200 FAX, 4100
1. Temporary error. scanner rotation error.
2. Replace contact image sensor.
4. Replace laser scanner.
5. Replace cables to laser scanner and engine board
HP LASER PRINTERS  1100, 2100, 4000, 4050, 8000
1. Scanner start up error
2. Replace scanner cable to the D.C. controller and back to scanner. Or replace scanner cable from engine board to scanner ***'y.
3. Replace scanner ***'y.
4. Replace the engine board.
5. Replace the D.C. controller only on the 8000.
HP LASER PRINTER 2300 ERROR 52.X
1. A temporary scanner start up error.
2. This can also be the shutter tab on the print cartridge. Replace the toner cartridge.
3. Replace the scanner ***'y.
HP LASER PRINTERS 4200, 4300 ERROR 52.XX
1. Printer scanner speed error has occurred.
2. Replace laser scanner ***'y
3. Replace the D.C. controller ***'y
HP COLOR LASER PRINTER 4600, 5500 ERROR 52.XK, 52.XC, 52.XM, 52.XY
1. Error code K - No Black Color.
2. Error code C - No Cyan Color
3. Error code M - No Magenta color
4. Error code Y - No Yellow color
5. Replace laser scanner ***'y
6. Replace the D.C. controller ***'y
HP LASER PRINTERS 5000, 5100
4. Replace cable ***'y from scanner to D.C. controller.
HP LASER PRINTERS 8100, 8150
1.Laser scanner error/start up/rotation error
2.Replace laser scanner ***'y.
3.Replace D.C. controller board.
4.Replace cable ***'y from scanner to D.C. controller
HP LASER PRINTER 4500, 4550
1. Temporary error. Laser scanner error/start up/rotation error
2. Replace laser scanner.
3. Replace D.C. controller ***'y
HP COLOR LASER PRINTERS 4600, 5500
1.Laser scanner error/start up/rotation error.
2.Take the toners out and reseat them, or replace them
3. Replace laser scanner ***'y
4. Replace D.C controller board.
HP LASER PRINTER 8500, 8550
2. Replace laser scanner motor.
HP LASER PRINTER 9000
1. Temporary laser scanner error/start up/rotation error
3. Replace upper cable guide assembly.
4. Replace DC controller.
Oct 22, 2008 | HP LaserJet 2840 All-In-One Printer
Canon Imagerunner 5000 error E000001-0000
Sort of, since both are fuser temperature related. First, the error needs to be cleared. Turning off/on won't do that.
You could go into service mode and clear the error (*28* > copier> function > clear > err > ok. Then turn the copier off, then on again and watch it heat up. I always monitor the temperature to make sure it's in the acceptable range (190 C or around that range).
If it happens often I'd have the thermistors changed. If it still happens, check the connectors in back of the fuser. They may need to be shimmed.
May 18, 2008 | Canon imageRUNNER 5000 Copier
Chamberlain CLLP1 Laser Parking Accessory Logo
67 people viewed this question
Top Chamberlain Home Security Experts
Norm Pearl
Tom Chichester
Bill Boyd
Are you a Chamberlain Home Security Expert? Answer questions, earn points and help others
