Question about Toro Garden
Why doesn't my toro z turn go forward or in reverse?
My toro z turn timecutter 4325 mower will not go forward or reverse. What should I do to correct this? It starts fine and blades engage.
jgwhomeequip
  • 1902 Answers
SOURCE: toro timecutter spits and sputters when blades are engaged
Did you drain the fuel before you put it away? If not then you should drain the fuel and clean the carb. Gas when in lawn mowers and any other small gas engine will turn into a slim in a way and will block the carb. Drain the fuel and clean the carb system will run great when that is done
Posted on Feb 19, 2009
  • 205 Answers
SOURCE: Troy Bilt ride-on mower will not move in either fwd or reverse
Is the parking brake on? Or if it's a hydrostatic (automatic) there is a release lever to push the unit around when it isn't running. Most of those releases are on the back of the machine, and you just push it in for drive and pull it out to push.
Was this helpful?
yes
no
Posted on Mar 21, 2009
  • 109 Answers
SOURCE: Mower starts but when the blade is engaged it stalls
Check the pulleys on the deck...one of them is jammed or rusted to the point that will not turn.
Posted on Apr 16, 2009
  • 6 Answers
SOURCE: need help installing drive belt on lawn
look at the back and see if there is a lever.
it might solve your problem.
Posted on May 10, 2009
SOURCE: Stalls when engage blades in forward, but cuts fine in reverse
Did you try to disengage the safety feature that should shut the tractor off when the blades are engaged and the tractor is placed in reverse? I believe that it is located under the shift leaver
Posted on May 15, 2009
Toro Timecutter MX5050 74770 won't move forward or reverse.
find a breakdown of the parts diagram. that may help.
Sep 25, 2016 | Toro Garden
What's wrong, No hydraulics on toro timecutter z480?
answered prevoisly look at buying new pump
Aug 25, 2014 | Toro Garden
Time cutter hydro does not move but i can hear it whine
Did you check the could have air in the system, did you check the hydro oil level? In my experience with toro hydro systems is when i change the oil air gets in the system. At low rpm move control handles forward and reverse several times until air works itself out. if this doesn't work more than likely there could be internal pump problems.
Sep 02, 2013 | Toro Riding Lawn Mower. TimeCutter SS4235...
Timecutter 4235 pulls to the right
first check the air pressure in the tires make sure they are the same then move the linkage rods on the slower side to balance the speeds out if it doesn't balance out you might have a pump or drive motor failing each side has its own pump and drive motor assuming you already check the fluid level
Aug 11, 2012 | Toro Lawn Mower With Toro Power Tools
Toro cutting off
Maybe low oil level, all mowers have a low oil cutoff. 30w oil.
Aug 07, 2012 | Toro TimeCutter Zero Turn Lawn Mower...
How to reinstall the main drive belt on a Toro Timecutter 42" zero turn mower.
Jump onto www.toro.com and download the free service manual for your machine. Note down all the details on the ID plate on the mower, you will need it to find the correct manual..
Apr 28, 2011 | Toro Garden
The steering levers quit working on my zero turn Toro Timecutter 16-44.
My steering levers on my zero turn toro quite working, The mower wont go forward or in reverse any ideas on how to fix this.
Jun 12, 2010 | Garden
Garden Logo
20 people viewed this question
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
Mike Squire
Roland W VanLue
Roland W VanLue
Are you a Toro Garden Expert? Answer questions, earn points and help others
