Question about Craig Tower Speaker System For iPod, iPhone, iPad - CHT910
Craig speakers connect to I pad will not play
  • 3 Answers
I had the same problem and I hope this awnser will help because there could be multiple problems, but my solution from experience is that the charger on top of the speaker has been moved forward and even being just a centimeter can mess it up so what I do is when I put my device on it I wedge the system remote begin the device and I'm te hole of the charger pocket where the phone goes, to push the phone forward so it can connect to the speaker
Posted on Jun 27, 2014
How to pair ny mini bluetooth craig speaker to my
Turn on the bluetooth of your phone first: Go to settings>Wireless and Networks>Enable Bluetooth and disable discovery limit in bluetooth settings. After that make sure the bluetooth in your speaker is on and let your phone search the speaker and let it pair with it after that go into your phone's music player and look for its play options and if you see via bluetooth click it. Just let me know if you need further instructions or you could watch this video showing how he pairs his bluetooth speaker from his phone DBEST London Bluetooth Mini Speaker Review
Oct 16, 2014 | Cell Phones
I accidently put the rca wires in the wrong audio input/output on my craig cd graphics karaoke player.Could this be why i have no sound?
The RCA outs are designed to send a signal to an external amplifier. That amplifier, in turn, sends the music signal to speakers.
The RCA inputs are designed to take audio signals from another device (like an ipod, CD Player, or computer) and play it through the Craig System speakers. If you sing into the microphone, the vocals will be mixed with the incoming music. However, in these cases, there won't be lyrics on the screen. If you play a karaoke DVD in a DVD player, connect the red, white and yellow RCA cables from the DVD out to the Craig Inputs, the lyrics should appear on the Craig screen while the music plays.
If you mistakenly plug RCA cables into the Craig Inputs and plug the other end into an amplifier's inputs, neither will produce any sound.
Using RCA outs is only necessary if you want to have louder music than the on-board Craig speakers can handle. Of course, you can run the yellow video cable to a TV RCA input to get a bigger lyrics window and the RED and White RCA to the TV RCA Red and White inputs to hear the music through the TV's speakers.
Aug 30, 2014 | Audio Players & Recorders
How to pair the speaker
That model is wired only and just plugs in.
Feb 28, 2014 | Craig Portable MP3 Speaker - CMA3016 White
When I turn my iPhone Bluetooth on it won't find the Craig blue tooth speaker!
Any Bluetooth device MUST be discoverable for the phone to find it.
Does your Craig have any setup program / configuration where you can set it to be 'discoverable' ?
Feb 17, 2013 | Cell Phones
Making my craig bluetooth speaker discoverable
Through basic hacking, the code 0000 worked for me....
I wish it came to me sooner!
Craig Electronics CMA3532BT is the model number -
A tiny cylinder speaker - sounds pretty good for the tiny $$$ too.
MikeFilosa
Dec 02, 2012 | Craig Portable MP3 Speaker - CMA3016 White
Samsung YP-Z5 has locked up while playing. Cannot exit, or change, or shut it down
This is the same problem I have! Try cleaning the resistive touch-pad (located under the sticker in the center) and the ribbon wire connecting it (green and flat with 4 strips of metal in it) with a bit of Windex or rubbing alcohol. The pad has various wires of different resistances in it and when certain groups are connected (touched) their resistance combines. For this to actually work, the pad has to be super clean and free of any corrosion.
This picture shows the buttons and the ribbon wire:
The pad is under the sticker with the arrows on it:
Jun 21, 2012 | Samsung YP-Z5 MP3 Player
Set-up for portable DVD player by Craig cmd420
Hello
[1] Insert the batteries into the Craig DVD player. Depending on the model you are using, the batteries are either rechargeable lithium-ion batteries or store-purchased AA batteries.
[2] Plug the 3.5mm cable into the headphone jack on the side of the Craig DVD player
[3] Insert the opposite end of the cable into the "Aux" connection on the car stereo. Without this audio-input option, you will be unable to hook the Craig DVD player up to your vehicle.
[4] Power on the Craig DVD player and insert the desired DVD. The video will load onto the display screen while the audio is played through the car's stereo system.
[3]
Oct 18, 2011 | Craig 731398407019 Portable DVD Player
My dd55 work well if i play gently and simple. But if i play something more complicated, then, after a few seconds, it restart power. It look as there some problem with polifone tones and power. Adapter,...
Whatever is the problem is probably vibration sensitive. The adpater connections are notorious and you would have to use test equipment to verify they are OK. Looking at them you cannot verify they are OK. Try to see if the display blinks right before it stops. If it isn't the connections, then it is possible one of the buttons is marginal and is vibrating down and restarting. Instead of complicated stuff, just do everything on one pad at a time to see if you can create the problem. Try different pads as the vibration may need to be neaar a particular point. Myself I would open the unit and inspect for loose wires etc.
Jul 09, 2011 | Yamaha DD55 7 Pad General MIDI Digital...
I have a dell xps M1330. Its mouse pad is behaving weird. If I try using it, it doesnt work but if I keep holding a shortcut key(play/stop/volume keys) while using the mouse pad it works fine. Any help?
hi,
your mouse pad dose not connect to the ground of device so when you keep and hold any
shortcut of keyboard , this connection done , and mouse pad work.
for this you (if you can) or a technician must remove the keyboard and change the flat cable
between mouse pad and devise .
good luck
gorbesia
Jun 19, 2011 | Dell XPS M1330 Laptop
Craig Tower Speaker System For iPod, iPhone, iPad - CHT910 Logo
134 people viewed this question
Top Craig Audio Players & Recorders Experts
odiegh
odiegh
 Grubhead
Grubhead
Gyula Lacz
Are you a Craig Audio Player and Recorder Expert? Answer questions, earn points and help others
